Double top bearing flush - Router Forums
 3Likes
post #1 of 13 (permalink) Old 12-13-2015, 02:29 PM Thread Starter
Default Double top bearing flush
I need to have a large (read wide) bearing surface for a flush/template bit. Is it ok to stack 2 bearings on the shank of the bit?
Futbalfantic is offline
post #2 of 13 (permalink) Old 12-13-2015, 02:44 PM
yes if the bit shank has the room...
don't forget to put a thin spacer washer between the bearings to protect the seals.....
ksidwy and Murtu01 like this.
post #3 of 13 (permalink) Old 12-13-2015, 04:01 PM
RainMan 2.0's Avatar
Welcome to the forum . A first names always nice , and if your really ambitious filling out your profile helps others help you
Ok ,I never insulate
RainMan 2.0 is online now
post #4 of 13 (permalink) Old 12-13-2015, 05:36 PM
Welcome to the forum, good advice what Stick says.
ksidwy likes this.
Herb Stoops is online now
post #5 of 13 (permalink) Old 12-13-2015, 06:01 PM
old55's Avatar
First Name: Ross
Welcome to the forum.
Ross,
old55 is offline
post #6 of 13 (permalink) Old 12-13-2015, 09:38 PM Thread Starter
It was a quick post, I was hoping to get by the woodworker shop today which did not happen. A little back story on the project. I am rebuilding a sewing maching table and used AutoCAD to make a template; which, if the drawing was correct, worked wonderfully. Currently I am laminating two sheets of plywood together. The top sheet has a rectangle with radii cut out. The bottom sheet needs the same rectange but with chamfers. My plan is to secure a guide to the top for the chamfers and use the existing rectangle for the rest of it.
post #7 of 13 (permalink) Old 12-13-2015, 10:44 PM
gjackson52's Avatar
First Name: Gary
Welcome to the Forum !
Gary
gjackson52 is offline
post #8 of 13 (permalink) Old 12-14-2015, 01:07 AM
Welcome Dan. Rough cut out the opening to about an eighth inch from the template. Trying to cut it out with the router is much harder on the bit that just a trim cut. If you put the template on top you can use a pattern (template) bit with the bearings on the shaft. If you put the template on the bottom you can use a flush trim bit with the bearing on the bottom. Either way works. Make sure you have about an inch of shaft in the routers collet.
post #9 of 13 (permalink) Old 12-14-2015, 05:54 AM
First Name: Larry
Welcome to the forum Dan.
Knot working is offline
post #10 of 13 (permalink) Old 12-14-2015, 07:19 AM
schnewj's Avatar
Welcome to the forum, Dan. Looks like you got your answers. These guys are experienced and more often as not you will have one or more solutions in a short amount of time; all for the asking. We all like pictures, so, don't hesitate to show us your work.
Bill
schnewj is offline
Duane's torsion box bench top build thread Duane Bledsoe Tools and Woodworking 152 11-25-2015 04:24 PM
how to setup bearing guided cutters roman ogee in r/table please matey Table-mounted Routing 5 08-04-2012 04:07 PM
My flush trimming split my workpiece ScoFF General Routing 10 08-12-2011 04:16 PM
Office cubicle table top for router top Noob Table-mounted Routing 12 05-23-2009 07:35 AM
