Matching existing Panel - Router Forums
 3Likes
post #1 of 15 (permalink) Old 01-13-2016, 07:34 PM Thread Starter
Default Matching existing Panel
Hi Folks - I'm about to attempt my first shot at cabinet making by trying to replicate one of my kitchen doors. I'm hoping someone can assure me I'm buying the right bit(s) from MLCS!
I've attached pictures of my existing door and looking to purchase an Ogee Fillet raised panel bit (2-3/4 - 1/2 shank). Does this look like the right bit?
I'm also looking at the Mission Style Fillet bit which I'm 99% sure is what was used for the rail/stile. The doors have applied molding which I've come quite close to matching at my local mill. I'm hoping the ogee panel with fit this rail/stile?
Any advice is appreciated! Thanks!
Name:	Screen Shot 2016-01-13 at 8.30.10 PM.png
Name:	cabinet door1.jpg
Name:	cabinet door 2.jpg
Name:	cabinet door 3.jpg
Name:	Screen Shot 2016-01-13 at 8.25.14 PM.png
tobinjm is offline
post #2 of 15 (permalink) Old 01-13-2016, 07:54 PM
Nickp's Avatar
First Name: Nick
I would say that's not the right bit...it will make a step in the panel...then in order to avoid that you would need to lower the bit and then the panel will be too large to fit in the rail and stile without cutting the back.
Don't think that's what you want...?
Nick
Nickp is offline
post #3 of 15 (permalink) Old 01-13-2016, 08:00 PM Thread Starter
Thanks Nick. Any ideas on what type of bit I should be searching out for? Is that an Ogee profile?
tobinjm is offline
post #4 of 15 (permalink) Old 01-13-2016, 08:26 PM
Which bit are you taking about the panel or the rail and stile bit?
Herb Stoops is online now
post #5 of 15 (permalink) Old 01-13-2016, 08:55 PM Thread Starter
I'm concerned about the panel bit and matching the shape. I'm pretty sure they used a mission style bit for the rail/stile.
tobinjm is offline
post #6 of 15 (permalink) Old 01-13-2016, 09:01 PM
I don't believe it to be either...
what Herb says or are you looking for the whole shebang...
Freud 3 Piece Raised Panel Door Sets -justfreud.com
File Type: pdf PremierAdjustableRailandStilePoster.pdf (432.3 KB, 104 views)
post #7 of 15 (permalink) Old 01-13-2016, 09:07 PM Thread Starter
I'd love to find a set to recreate the both the panel and the rails/stile but I assumed that was not possible. If anyone has suggestions of what type of bit for both it would be appreciated. Since there is molding around the door as well I believe the rail/stile is some type of a mission style bit. Thanks again.
-j
tobinjm is offline
post #8 of 15 (permalink) Old 01-13-2016, 09:10 PM
-j
did you look at the links I posted...
post #9 of 15 (permalink) Old 01-13-2016, 09:16 PM Thread Starter
Stick - Yes thank you. I guess the closest I'm going to get would be Freud# 97-260 (last set of bits on that page) ? Its really hard to tell exactly what the rail/stile will look like from that angle of the picture.
tobinjm is offline
post #10 of 15 (permalink) Old 01-13-2016, 09:36 PM
and before I forget again...
welcome Tobin...
cut a profile/template on piece of paper so the your mind's eye can see it better...
that molding on the door appears to be conventional..
Integrating INCRA : Craftsman Table Saw [TS] & Router Part 3 [ii] Bridged X-cut Box SimonHartropp Jigs and Fixtures 1 10-27-2015 11:50 AM
Matching an existing cabinet door hellosf Router Bits - Types and Usage 5 01-14-2014 06:37 PM
Matching existing base molding nzeigler Table-mounted Routing 4 10-20-2012 11:16 AM
Matching existing edge profile, advice appreciated tomsawyer85 Router Bits - Types and Usage 9 07-09-2012 09:14 AM
Reproducing a panel moulding on existing doors paulcomi Table-mounted Routing 3 06-29-2007 12:35 PM
