Grooves in HDPE plastic - Router Forums
 6Likes
  • 2 Post By DonkeyHody
  • 3 Post By Nickp
  • 1 Post By cocobolo1
post #1 of 10 (permalink) Old 02-01-2016, 06:49 PM Thread Starter
Default Grooves in HDPE plastic
I'm very new to routing and this is my first project. I'm essentially building a box out of HDPE, which is held by screws.
I'm cutting grooves in 1/2 HDPE plastic board using 31/64" router bit. When I measure the bit, it comes out to 0.4885" and when I measure the board, it comes out to 0.495", so I have about 1/100" difference.
I can't really wedge it in, it should be snug, but removable.
I don't have a micro-adjuster, so I was doing the tiniest bumps on the fence, but it's very imprecise.
Is there a technique I could use to get the precision I need?
Thank you
Dorrumata is offline
post #2 of 10 (permalink) Old 02-01-2016, 07:24 PM
DonkeyHody's Avatar
First Name: Andy
That's how I do it. Try it on scrap wood until you get the fit right.
billyjim and Herb Stoops like this.
DonkeyHody is offline
post #3 of 10 (permalink) Old 02-01-2016, 08:07 PM
Nickp's Avatar
First Name: Nick
Put an appropriate spacer between piece and fence (card, tape, paper, etc), butt to fence, clamp piece, remove spacer, move fence to piece, turn on, make sawdust...
Nick
Nickp is online now
post #4 of 10 (permalink) Old 02-01-2016, 10:24 PM
Honored Member
First Name: pat
2 things.
1) Typically there's no 1/1 relationship between cutter diameter and the cutter pathway width. Way way too many variables to chase here.
and
2) NickP has the solution.
Unless you have something like this:
A fence that adjusts continuously and is monitored x travel gage.
Quillman is offline
post #5 of 10 (permalink) Old 02-02-2016, 12:14 AM Thread Starter
Quillman, that's very impressive fence.
Thank you Nick, I will try that.
post #6 of 10 (permalink) Old 02-02-2016, 08:16 AM
First Name: Keith
Originally Posted by Quillman View Post
2 things.
and
Holy smoke, what a gem. Do you have a name for that thing? Or is it a custom one off?
mbar57 likes this.
cocobolo1 is offline
post #7 of 10 (permalink) Old 02-02-2016, 09:07 AM
mbar57's Avatar
+1 That is awesome!! Where can I get one? What is it called? And what do you use it for? That doesn't matter, I want one!!!
mbar57 is offline
post #8 of 10 (permalink) Old 02-02-2016, 09:11 AM
Garyk's Avatar
First Name: Gary
HDPE -UHMW and most of the poly type of plastic are HEAT sensitive which might be your culprit. Try slowing the speed of the router down a bit.
Garyk is offline
post #9 of 10 (permalink) Old 02-02-2016, 09:13 AM
Honored Member
First Name: pat
"Holy smoke, what a gem. Do you have a name for that thing? Or is it a custom one off?"
It's an evolutionary thing, like last year's car; this year's always sees changes.
That thing started as a router table fence. Then when I understood how to move it back & forth I made a couple of prototypes for the drill press. Then I standardized the parts. It's essentially for drilling and positioning. I call it a Drill Press Fence.
Quillman is offline
post #10 of 10 (permalink) Old 02-02-2016, 09:23 AM
First Name: Keith
You know, considering all the money I waste on food and other essentially useless junk, like gasoline for instance...that's not bad.
Think I would mount mine in an expensive looking glass case with gold trimmed stuff around the outside. I have my thinking cap on.
Fabricating Plastic HDPE Wayne Turner Router Bits - Types and Usage 8 02-04-2014 08:41 AM
Plastic depth gauge on Craftsman router won't tighten. rricardo203 Portable Routing 5 09-16-2013 04:41 PM
Alternative to thin plywood - thin hard plastic? bobbotron Starting Off 10 05-18-2012 11:14 AM
What Router to buy (cutting plastic) stevegriswold General Routing 1 07-03-2005 12:56 PM
