Can I use a CNC bit on my router? - Router Forums
 3Likes
  • 1 Post By johnvmc
  • 1 Post By curiousgeorge
  • 1 Post By Keith Hodges
post #1 of 7 (permalink) Old 02-17-2016, 02:45 PM Thread Starter
Default Can I use a CNC bit on my router?
Hello. Can I use a CNC ball nose bit on my router(non CNC) for cutting wood? If not, why not? Thanks.
197761 likes this.
johnvmc is offline
post #2 of 7 (permalink) Old 02-17-2016, 04:00 PM
I am glad you ask, I have often wondered. And also wondered if the shanks would fit?
I see your fairly new here ,welcome to the forum.
Herb Stoops is online now
post #3 of 7 (permalink) Old 02-17-2016, 04:55 PM
curiousgeorge's Avatar
First Name: George
I'm no expert, but as long as the bit fits in your router chuck I see no problem. After all, isn't a CNC just a computer controlled router?
Herb Stoops likes this.
George
Fort Worth, Texas
City where the west begins.
curiousgeorge is online now
post #4 of 7 (permalink) Old 02-17-2016, 05:05 PM
kp91's Avatar
First Name: Doug
Again, not an expert...
Shank size and cutter rated speed are your two concerns. If the shank size fits the router, and the cutter speed is rated higher than the router speed, you should be safe.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #5 of 7 (permalink) Old 02-17-2016, 05:43 PM
I noticed that some of the CNC bits I was looking at awhile back were significantly shorter than regular bits.
post #6 of 7 (permalink) Old 02-18-2016, 06:15 AM
Is the ball nose bit an up spiral? If so I've tried to use up spirals in our hand routers and didn't have very good luck seem to be harder to control because of the up spiral
hammerheadmike is offline
post #7 of 7 (permalink) Old 02-18-2016, 06:28 AM
First Name: Keith
The basic question, yes you can. My CNC uses my Bosch, or Dewalt routers. Regular routers. Your spindle CNCs might use different bits. Speeds and feeds will be a concern. On CNCs the router is held by the Gantry, built to withstand all the different forces. Hand routing would be a little more difficult.
Keith Hodges is offline
Helping students make a CNC Router Table bgriggs CNC Routing 21 10-28-2014 04:23 AM
Newbie in using a Router..... Andron General Routing 6 03-20-2013 02:20 PM
