Flush trim bit length - Router Forums
 6Likes
  • 3 Post By Semipro
  • 1 Post By Quillman
  • 1 Post By DonkeyHody
  • 1 Post By Cherryville Chuck
post #1 of 8 (permalink) Old 03-10-2016, 11:32 PM Thread Starter
First Name: Joe
Default Flush trim bit length
I need a flush trim bit bottom bearing to use with some patterns I made for chair parts. Ill be working on the the router table. A 1 1/2 inch cutter length would work as the parts are just less than 1 7/16 inch thick under the pattern . Just wondering if I should simply get a 2 inch cutter length bit instead? Is there any reason not to go with a bigger bit ? Ill be using a PC 690 series router with a 1/2 collet.
Joesf is offline
post #2 of 8 (permalink) Old 03-11-2016, 12:56 AM
Forum Moderator
Semipro's Avatar
First Name: John_*
befine as long as you got enough travel distance under the table to get it low enough to ride your bearing on the pattern
Semipro is offline
post #3 of 8 (permalink) Old 03-11-2016, 08:43 AM
Honored Member
First Name: pat
In RouterDom, deflection is your enemy.
Keep cutters as short as possible.
If cutters and drills were supported on both ends, like jointer spindles,
length would be less of a problem.
cocobolo1 likes this.
Quillman is offline
post #4 of 8 (permalink) Old 03-11-2016, 09:16 AM
DonkeyHody's Avatar
First Name: Andy
Unless you have some tight spots to get into, go for a larger diameter bit and 1/2 inch shank. The larger diameter is good for avoiding chip-out as well as curing deflection problems. Get the 2" length because one day you'll need it.
DonkeyHody is offline
post #5 of 8 (permalink) Old 03-11-2016, 09:31 AM
The longer the bit the less wood you want to try and take off per pass because of what Quillman says.
post #6 of 8 (permalink) Old 03-11-2016, 10:37 AM Thread Starter
First Name: Joe
I heard back from Whiteside and they recommended adding 1/4 inch to thickness or depth and going with next size up. So I went with their 2 inch # 2408 bit. Thanks for all the responses.
Joesf is offline
post #7 of 8 (permalink) Old 03-11-2016, 12:21 PM
Ghidrah's Avatar
First Name: Ronald
Agree with DonkyHody. The longer bit with the 1/2" shank has more versatility. Also the larger the cutting diameter the better the resistance to lateral stress. As for the amount of material, the bulk should be removed prior to the routing process.
Ghidrah is offline
post #8 of 8 (permalink) Old 05-31-2016, 12:22 AM
On vacation
Well, definitely a good read. I appreciate for sharing.
cynthiamyra is offline
OMG, top bearing trim bit frustration vindaloo Router Bits - Types and Usage 4 08-15-2013 07:25 PM
is it safe to use a straight bit like a flush trim bit? achoox4 Router Bits - Types and Usage 12 04-11-2013 11:25 AM
sprial flush trim bit dogrunner Router Bits - Types and Usage 9 01-06-2013 02:38 PM
Flush Trim Bit - How to determine which one? tcoldewey Router Bits - Types and Usage 2 03-01-2009 05:57 PM
Flush Trim Bit odamsr Router Bits - Types and Usage 3 09-14-2005 06:32 AM
