T-Slot Router Bit - Router Forums
 18Likes
post #1 of 13 (permalink) Old 04-20-2016, 04:06 PM Thread Starter
Contributor of the Month
Default T-Slot Router Bit
I just bought Infinity's T-Slot Router bit. It is advertised as perfect for 1/4 X 20 Hex Bolts.....which is what I will be using to make a jig. I'm wondering if it would be better to cut a channel in the wood with a saw blade prior to using the bit in order to remove some of the wood and make it easier on the T-Slot bit or just use the T-Slot bit to do the whole job. I will be using the bit on Poplar.
I will be cutting the slot on a router table.
Thank You for any advice.
JIMMIEM is offline
post #2 of 13 (permalink) Old 04-20-2016, 04:25 PM
TWheels's Avatar
Yes, cut a channel first. It will make the T-slot bit cutting easier and reduce wear on the T-slot bit.
One other comment: it might be easier to use a hand held router with a template and template guide to cut the T-slot. I used that method for my featherboard holders and for dados in shelves.
jw2170, JFPNCM, Shop guy and 3 others like this.
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #3 of 13 (permalink) Old 04-20-2016, 10:03 PM
Gaffboat's Avatar
First Name: Oliver
Yes, like Tom says, cut a channel first. I use my box joint blade on my table saw. Then I cut the slots with the T-track bit on the router table. I have a set of Jessem Router stock guides that helps keep the board flat to the table and against the fence. Featherboards would do the same thing.
billyjim and Herb Stoops like this.
Gaffboat is offline
post #4 of 13 (permalink) Old 04-21-2016, 09:43 AM
One more for the saw slot first. One of the issues with type bit is that it has a hard time getting rid of the chips so lots of them get recycled in the cut and generate a lot of heat. The saw slot will also give it air to cool itself with. I worked at a place once that used a proprietary bit to fit a plastic clip into for attaching kick boards. The saw slot extended the life of the bit times 3.
post #5 of 13 (permalink) Old 04-21-2016, 10:35 AM
I pre-cut the 1/4" slot with a 1/4" router bit, then without changing the fence location replaced it with the slot-cutter.
And, yes chip removal is an issue if you don't precut the slot.
Arcola60 and PhilBa like this.
<Chas>
I'll burn that bridge when I come to it
CharlesWebster is offline
post #6 of 13 (permalink) Old 04-21-2016, 12:01 PM
JFPNCM's Avatar
First Name: Jon
Most definitely cut the slot first.
I over heard a discussion at the register in the local Rockler store where a chap buying a T-slot bit was asked how we was going to cut the slot. He was a bit surprised by the question as he just assumed the bit would handle the entire job. The clerk was kind and pointed out that the only cutters on that bit were at the tip for the T per se. He added an upcut spiral to his collection. I asked the cashier later if that was a common oversight and he advised that they routinely ask that question now as several customers had returned with badly burned T bits and/or complaints of failure to cut.
Jon
JFPNCM is offline
post #7 of 13 (permalink) Old 04-21-2016, 12:17 PM
VOE, in my early days of using a router table I went thru 3 bits in a hurry and never used that kind of bit again. Same thing chuck them up go 3"-4", Bing the bit was gone. and an ugly slot burned around the edges.
That is a problem for a beginner is that the bits come with no instructions on how to use them. I have seen recently notices "to use in router table only" on the packaging of the larger bits.
I have never seen a notice on the package of a "T" slot bit, or a ball slot bit to cut the slot first.
Herb Stoops is offline
post #8 of 13 (permalink) Old 04-21-2016, 02:09 PM
First Name: Kurt
Hmmm.... Never thought of cutting a slot first.... I always run the bit a few inches and back it out to clear the chips...
This has always worked ok, and never harmed the bit.... The slot is clean with no burning....
But I will change my method in the future.... Just makes sense....
Oakwerks is offline
post #9 of 13 (permalink) Old 04-21-2016, 06:05 PM Thread Starter
I'll cut the channel on the table saw, then use a straight 1/4" bit on the router table to widen the channel, then finish up with the T-slot bit. This should be the least stressful for the T-sot bit.
Oakwerks and Herb Stoops like this.
JIMMIEM is offline
post #10 of 13 (permalink) Old 04-21-2016, 06:41 PM
JFPNCM's Avatar
First Name: Jon
@Herb Stoops
I've never seen a notice on 1 either. Nice to know that the Rockler shop is thinking.
Herb Stoops likes this.
Jon
JFPNCM is offline
Router and bit for slot cutting robjenko General Routing 10 05-16-2011 03:14 AM
