Help finding router bits - Router Forums
 2Likes
post #1 of 22 (permalink) Old 04-28-2016, 05:05 PM Thread Starter
jcoxbtl's Avatar
First Name: Jason
Default Help finding router bits
I'm replicating a 2" interior door. 6 panel. Custom built in a 10 million dollar home.
I can't find the router bits I need.
I would like a door making set, but anything would help!
The drawing is to scale.
Thank you
jcoxbtl is offline
post #2 of 22 (permalink) Old 04-28-2016, 06:52 PM
a few to pick from...
Door Router Bits: Lonnie Bird Tambour Door, Cabinet, Screen & Shaker Door
and BTW...
welcome to forums oh nameless one...
post #3 of 22 (permalink) Old 04-28-2016, 09:24 PM
There's an upside down ogee in this set that might be the right size. Router bit sets-Crown molding set-CMT tools
post #4 of 22 (permalink) Old 04-29-2016, 05:42 AM
First Name: Larry
Welcome to the forum N/a
Knot working is offline
post #5 of 22 (permalink) Old 04-29-2016, 08:44 AM
Country: Mexico
First Name: Joseph Anthony
Talking
Thank you
What are you doing in my home? LOL
Welcome aboard and good luck with your work.
Roy Drake likes this.
Cheers.
Joe
RÖENTGEEP is offline
post #6 of 22 (permalink) Old 04-29-2016, 10:21 AM
it's obvious...
replacing your door because you hadn't got around to it yet...
RÖENTGEEP likes this.
post #7 of 22 (permalink) Old 04-29-2016, 11:09 AM
Nickp's Avatar
First Name: Nick
Freud adjustable rail & stile (ogee?) 99-761...one side of the door then the other...?
http://www.justfreud.com/raiStile_Sets.htm
Nick
Nickp is offline
post #8 of 22 (permalink) Old 04-29-2016, 11:46 AM
CharleyL's Avatar
First Name: Charley
You can get router bits to cut almost anything you want, even custom router bits, if you can afford them, but I think this can best be done with a shaper and the right stack of cutters. That's a lot of wood to be trying to cut with a router, even a 3 hp router. It's possible, but will require extra passes and setups.
Charley
Central North Carolina
CharleyL is offline
post #9 of 22 (permalink) Old 04-29-2016, 06:52 PM Thread Starter
jcoxbtl's Avatar
First Name: Jason
Thank you for your help so far. These bits aren't quite the right profile. I need a 3/4 cutting height, and 1/2" depth. I think its 1/4" for both radius. The closest I've come so far is Freud 38-106. But it looks like the bottom radius is about 1/8" on this bit.
When your work speaks for itself, don't interrupt.
jcoxbtl is offline
post #10 of 22 (permalink) Old 04-29-2016, 08:38 PM
Nickp's Avatar
First Name: Nick
On the 99-761 set...the bottom cutter screws off which is normally used to make extended tenons. I think the cutting height is 3/4. If the profile is right you could cut one side then the other, leaving 1/2" tenon in the middle. Is the profile Ogee or something else...?
I'll measure mine in the morning to verify...will check the 38-106...
Edit...looks like 38-106 has 1/4 radius...google image...
Nick
Nickp is offline
Router bits needed for Leigh Dovetail Jig D4R Llewellyn New Member Introductions 11 08-13-2012 03:04 AM
How to buy router bits xplorx4 Router Bits - Types and Usage 31 02-09-2009 01:04 AM
