A.G.E. Series by Amana Tool MD502 Raised Panel Door set - Router Forums
 2Likes
  • 2 Post By Cherryville Chuck
post #1 of 6 (permalink) Old 05-23-2016, 11:51 PM Thread Starter
First Name: Eugene
Default A.G.E. Series by Amana Tool MD502 Raised Panel Door set
Does anybody know how far the rail protrudes into the stiles on this set, it makes a 3/8 Grove, i measured from the tip of the cutter to the bearing and it appears to be 3/8 as well, I can't find the information in the kit or on there site? I just wanted to make double sure before I begin to cut things up, and come up too short when I do the coaping cuts, thanks for the anticipated help.
Eugd is offline
post #2 of 6 (permalink) Old 05-24-2016, 12:11 AM
Eugd it should be the distance from the tip of the largest diameter to the bearing. I tried finding that set on their site but it didn't come up in a search.
post #3 of 6 (permalink) Old 05-24-2016, 12:48 AM
It wouldn't hurt to try them on some scrap first and then you can use those for dummy sticks to set the production run with. Then you'll be able to make sure before you make a mistake on some expensive wood.
David Dickson and cocobolo1 like this.
post #4 of 6 (permalink) Old 05-24-2016, 12:56 AM
You should follow Chuck's very good advice and build a couple samples from cheap material. I make prototypes for most of my projects.
post #5 of 6 (permalink) Old 05-24-2016, 04:55 AM
your best bet would be to run a few test cuts and assemblies w/ scrap material...
Stick486 is offline
post #6 of 6 (permalink) Old 05-24-2016, 06:15 AM Thread Starter
First Name: Eugene
Will do, thanks gentlemen
Eugd is offline
peak hp vs. real hp danapointed New Member Introductions 15 05-10-2017 04:33 PM
Craftsman v. Delta Tablesaws Thowie70 Tools and Woodworking 22 02-24-2014 11:12 PM
Peak HP dgcutter General Routing 22 01-10-2013 09:23 PM
Selecting the Correct Router Bit LMT Onsrud (Onsrud) Router Bits - Types and Usage 1 02-08-2012 12:17 AM
square corner cnc raised panel Bob flan CNC Routing 28 06-11-2011 05:04 PM
