Router bits with chip breaker. - Router Forums
 2Likes
  • 1 Post By hawkeye10
  • 1 Post By Jack Wilson
post #1 of 4 (permalink) Old 07-28-2016, 04:58 PM Thread Starter
hawkeye10's Avatar
First Name: Don
Default Router bits with chip breaker.
I know I have led a sheltered but tell me about a router bit with a chip breaker.
Spiral Router Bits - WHITESIDE #RU5125CB SPIRAL UP CUT BIT W/CHIP BREAKER- 1/2 SH X 1/2 CD X 1-1/4 CL
Jskingry likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #2 of 4 (permalink) Old 07-28-2016, 05:08 PM
the cutting/shearing edges of the bit have notches in them so that the cut chips are reduced in size for easier removal on deep cuts as in mortises..
makes little sawdust out of big sawdust..
less work for the DC to carry away the waste too...
post #3 of 4 (permalink) Old 07-30-2016, 08:46 AM
Honored Member
First Name: pat
Chip breakers are carry-overs from end mills.
In this case, they add efficiency to the cutting action, (take less energy to do the same as non-chip breaking tool). They are for aggressive waste apps; they are not finish cutters.
Moreover, they will not leave a surface like this.
Quillman is offline
post #4 of 4 (permalink) Old 07-30-2016, 09:08 AM
Jack Wilson's Avatar
First Name: Jack
Someone discovered that after dropping these bits on a concrete floor they pull chips out better, now they call it a "design feature"!
hawkeye10 likes this.
Jack
He is no fool who gives what he cannot keep to gain what he cannot lose
If you cannot stand behind our troops, (and I understand, no judgement here), then please stand in front of them, remember, they're willing to stand in front of you!
Jack Wilson is offline
up and down cut spiral bits in hand held router vs table mounted router almost there Router Bits - Types and Usage 17 04-22-2014 11:00 AM
Router bits needed for Leigh Dovetail Jig D4R Llewellyn New Member Introductions 11 08-13-2012 03:04 AM
How to buy router bits xplorx4 Router Bits - Types and Usage 31 02-09-2009 01:04 AM
