Hitachi MK12v 3 1/4hp router - Page 2 - Router Forums
 6Likes
post #11 of 13 (permalink) Old 10-02-2017, 07:33 AM
First Name: Art
Price and performance of the MV12 are the selling points. I have two, one is permanently mounted to my table and the other is permanently mounted to an identical plate used on my table.When ever I am using rail and stile bits I simply pick up the second router and drop it into the table cut out. The router is cheap enough that it makes sense to do it this way.
mgmine is offline
post #12 of 13 (permalink) Old 11-05-2017, 09:51 AM
I in the market to purchase a router , what size should I go with and work with the milescraft pantograph pro and what brand
thank you
doug
djj405 is offline
post #13 of 13 (permalink) Old 11-05-2017, 10:21 AM
Hi Doug and welcome. Your first router purchase should either be a plunge or a combo offer where you get a motor and a plunge and fixed bases. There are operations that can only be done with a plunge while the opposite is not true about fixed base routers. Fixed base routers are nice to use where you are profiling an edge for example because they are shorter and less tippy feeling. The router should be a minimum of about 12 amps/ 2.5 hp (give or take a bit).
I have 3 Hitachi routers, an M12V, M12V2, and a M12VC fixed base. The M12V s are only plunges and are 3+ hp. The VC is about 12 amps and can be had as a combo package. I am very happy with all 3 and they were cheaper than most other brands but still offered a 5 year warranty.
The favorite router on the forum is the Bosch 1617 and in the combo package where you get both bases. I see it up here for $279 to $329 Canadian money. They are well built routers and you would be very happy with that package. The 1617 is around a 12 amp router so it handles everything easily up to panel raising bits. At that size bit you'll need to slow your feed rate and take smaller bites. Hope this helps.
Triton or Hitachi router in a router table bulldog65 Table-mounted Routing 9 08-10-2015 09:38 AM
Router Backup yuva New Member Introductions 6 01-21-2014 08:33 PM
question regarding router settings Hitachi M12V cttdc General Routing 7 01-14-2009 08:10 AM
I see why you guys like that big Hitachi router paulcomi General Routing 3 09-18-2006 10:06 PM
