sound baffled air vent for workshop - Router Forums
post #1 of 3 (permalink) Old 09-02-2016, 10:51 PM Thread Starter
First Name: Peter
Default sound baffled air vent for workshop
Hi
may I ask if anyone knows how to make a sound baffled air vent for a workshop please?
regards
Peteroo
Peteroo is offline
post #2 of 3 (permalink) Old 09-03-2016, 01:21 AM
Only thing I can think of would be putting baffles in the opening so the air has to change direction several times. Each change in direction, there'll be a reduction in sound level. I had something like this in a darkroom that only had 3 ply baffles painted flat black that worked well. For sound, I'd consider finding some sound deadening material, like gooey rubber coating or material such as cork, which should further dampen sound. I doubt you'll get rid of every sound, but likely bring it down to a livable level. If you want air flow, a squirrel cage blower should do the trick.
post #3 of 3 (permalink) Old 09-03-2016, 03:36 AM
Originally Posted by Peteroo View Post
Hi
regards
Peteroo
increasing the size of the vent will reduce the Db's.....
Hello and a question about air compressors Joe T CNC CNC Routing 1 11-07-2013 03:48 AM
What makes a good sauna Tiny Lobby 9 09-21-2012 12:38 AM
Dylos Air Quality Monitor Group Buy BigJimAK The Bargain Bin 0 07-28-2011 11:46 AM
