Air Quality - Mask vs. Air Filtration - Router Forums
 12Likes
post #1 of 19 (permalink) Old 10-12-2016, 06:04 PM Thread Starter
bdbailey's Avatar
First Name: Benjamin
Default Air Quality - Mask vs. Air Filtration
Lately, while cleaning rusty old tools I bought from a local market, I've inhaled steel wool dust and possibly gotten a tiny bit in my eyes. And while sanding wooden projects, I've only coughed maybe once. But as I do more cleaning, sanding, staining, and possibly moulding plastics, I'll want more safety. A long-time carpenter recommended a $130 full-face mask setup with replaceable filters, if I was to train with him. But I know some people on Router Forums recommend air filtration of some sort. Are both needed? Is one more important than the other?
We're on a budget. I'm fine with $130 for an intense mask I will use for any longer projects. But there needs to be a little more airflow in general - will a fan near the project be sufficient?
Our woodworking workshop (our garage,) has a few windows and of course the large door we can open. But I will not always want to work with that door open, especially in winter. Which brings us to heating - but that's another topic entirely. I can use a coat for now.
I don't want to ruin my health - eyes, fingers, lungs - but I'm not building a bunker and I don't need to cycle enough air for an army. What's the middle ground?
Thanks so much for any advice! Health is so important.
bdbailey is offline
post #2 of 19 (permalink) Old 10-12-2016, 06:48 PM
RainMan 2.0's Avatar
Your a smart man as dust is no joke . I bought a mask that has paper pre filters before it goes to the filtration canisters. It was like 50 bucks I believe .
I wear safety glasses also that have cheaters built in . This most disagree with , but I wear a hard hat with the ear muffs to suppress noise also . I'm used to wearing hard hats , so it doesn't bother me at all.
Used to have a full face shield on it to protect my eyes , but the dust masks canisters got in the way of the shield , so it was back to safety glasses .
At some point I'm going to install a filtration system on the ceiling also , as you can't have to many contingency plans to remove dust IMO .
I also have dust collection on my router , table saw , miter saw etc
My gear . Dust mask is rated for h2s
furboo and Chris Hachet like this.
Currently washed up
RainMan 2.0 is offline
post #3 of 19 (permalink) Old 10-12-2016, 07:27 PM
JOAT's Avatar
First Name: Theo
Dust mask, definitely. Full mask doesn't work for me, wear glasses. Hmmm, wait, I just remembered, had cataract eye surgery last year, and now 20/20. Could wear a full mask now, but don't care for them. I like a full shield over safety glasses. I would imagine you can get a mask for considerably less than $130 that will be completely adequate, I'm thinking they all have replaceable filters now too. I think my half mask ran me around $30, and had two replaceable filters. Have a bit different style now, but still two replaceable filters. My shop is quite small, so have a fan in the window to blow thru and out, but definitely wear the mask when doing anything except some hand sanding. I never coughed before I started using a mask, but did tend to cough up sawdust.
Why am I writing this? And why are you reading it?
Life may not be the party we hoped for, but while we're here we might as well dance.
JOAT is offline
post #4 of 19 (permalink) Old 10-12-2016, 08:20 PM
kp91's Avatar
First Name: Doug
A mask is more important than an ambient air filter
The hard part is finding one you will use and fits well. I use a Triton papr that has the filter on the belt because the flow of air keeps my glasses from fogging when it gets humid.
TWheels likes this.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #5 of 19 (permalink) Old 10-12-2016, 08:52 PM
go w/ non-woven pads instead of steel wool..
in fact don't use steel wool for anything... use the pads...
if you want to use a rust solvent mix 1:1 ratio of ATF and acetone... won't take much...
a fan will make for good ventilation...
goggle/ski type safety glasses...
(examples) https://www.conney.com/category/eye-...safety-goggles
build your own down draft table and hook up a DC to the sander...
10 Downdraft Table Plans and Build Notes for Wood Shops |
possibly molding plastics, I'll want more safety.
positive pressure hood/full face respirator.. but the price of these jst make your brain hurt...
way too many hydrocarbons and noxious gasses to deal w/...
goggles and filtered half face respirator w/ replaceable filters...
(example) 3M® 6000 Series Half Facepiece Reusable Respirators | Seton
Shop air filtration???
no, but add a box fan w/ an AC filter mounted to it to the arsenal... a positive plus that will not hurt...
Box Fan Filter
please....
dust collection (DC) system and eye/hearing protection...
use the search function here on DC as there are a lot of threads on the subject...
VOE says.. get more unit than you think you'll ever need.. ''no get bys'' is to your advantage...
Stick486 is offline
post #6 of 19 (permalink) Old 10-12-2016, 08:54 PM
First Name: lee
I use both a face mask and air filtration. I have older tools so the DC is not prefect with these tools so adding a mask and air filtration hopefully makes up for less than prefect DC. I think it is all a balance trying reduce your dust intake.
coxhaus is offline
post #7 of 19 (permalink) Old 10-12-2016, 09:37 PM
I like this one, Rockler Power air respirator, Power Air Respirator - Rockler Woodworking Tools. Glasses go over that, either goggles or a pair of safety glasses over that. Runs on 4 AA batteries, so I keep a couple of sets of rechargables on hand. Fan in mask puts in positive air pressure, and mine leaks air over my cheeks and keeps my glasses from fogging. Plenty of air flow, no dust gets through. Picture below.
Name:	power dust mask.jpg
DesertRatTom is online now
post #8 of 19 (permalink) Old 10-12-2016, 10:48 PM
BrianS's Avatar
First Name: Brian
This is very similar to the one that I have: 3M Dustmask. It works very well for me, and there are several different filter canisters that you can get for it, all depends on what you are doing.
I used to use the paper throw away masks and thought they did an adequate job. I had to make sure I got the ones with the center exhaust valve, else my glasses would fog up. Use dust collection at the source... whatever machine you are using, make sure you are using a dust collector. You will never get all of it IMHO, but if you get most of it, it's OK. Air filtration in the shop can be as complicated as the most expensive, efficient filtration you can find... or it can be really simple. Tape a standard furnace filter to a 20" box fan and turn it on. It won't get all the real fine particles, but it will still get a lot of the particulate matter floating thru the air.
Bottom line, use a filtered mask, and a collection system. You only get one pair of lungs, protect them.
Brian
(Origin uncertain)
BrianS is offline
post #9 of 19 (permalink) Old 10-13-2016, 12:07 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
BDBAILEY....
Unless you are a very lucky man, you will only ever have one set of eyes and one set of lungs.
Forget any kind of budget for safety items. Whats the use of having a workshop full of tools if your lungs are so bad you cant walk to it (try googling COPD), or you cant see to work it all.
Mask AND dust collection are vital and anyone who decides not to use both is just fooling themselves.
I have a dust collection system to my machines, and still wear a face mask to FFP3 specification, because its the very fine dust that you cant see that will eat your lungs out.
and I use safety glasses and ear defenders on anything that throws dust and chips at me.
In terms of a car, think of it as fitting a giant race engine but not upgrading the brakes. Starts off well, but disaster is just a little way down the road
BrianS, RÖENTGEEP and RainMan 2.0 like this.
sunnybob is offline
post #10 of 19 (permalink) Old 10-13-2016, 10:22 AM
mlerchenmuller's Avatar
+1 on the 3M 6000 mask. Works for sawdust as well as fumes from finishing products. It is a half mask so it does not interfere with glasses or safety goggles. A very high level of particulate filtering. It's the very fine sawdust that will harm you. Most of the dust collectors are not very efficient removing the very fine particulates.
mlerchenmuller is offline
Jet AFS-1000B Air Filtration System curiousgeorge Tool Reviews 14 10-08-2014 12:54 AM
air filtration gman58 Shop Safety 4 01-26-2013 11:00 PM
FREE: air filtration system dave123ellen Woodworking Classifieds 5 05-18-2012 01:39 PM
Dylos Air Quality Monitor Group Buy BigJimAK The Bargain Bin 0 07-28-2011 11:46 AM
For Sale: Air Filtration System dave123ellen Woodworking Classifieds 3 04-10-2011 09:56 AM
