Making a downdraft sanding box - Page 2 - Router Forums
 25Likes
post #11 of 20 (permalink) Old 02-13-2017, 06:50 PM
old55's Avatar
First Name: Ross
Thanks Dave great job.
difalkner likes this.
Ross,
old55 is offline
post #12 of 20 (permalink) Old 02-13-2017, 07:12 PM Thread Starter
Forum Moderator
difalkner's Avatar
First Name: David
Originally Posted by hawkeye10 View Post
Dave is yours hooked up to a shop vac. or a big dust collector? I would like to use my shop vac. but I don't know it I will get enough suction. If I use my big dust collector I will have to roll it closer to use it. I really don't want to have to do that because my shop is small "like yours" and it can be a hassle.
It's hooked up to the HF dust collector, Don. I think it would have to be much smaller if you were going to use a shop vac. One thing I did was to buy a 20' clear hose from Amazon and it reaches all of the tools in our shop. Powertec 4" clear 20' hose
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #13 of 20 (permalink) Old 02-13-2017, 08:01 PM
Forum Moderator
MT Stringer's Avatar
Good job, David. I need one of those in the worst way. Like you, I keep the door shut. I like it cool in the shop and the mini split does a great job of that.
I have thought about it in the past but never put out the effort to build one. The biggest problem is storage. I just don't have the room to store it. I guess I need to look around and see what I can do to make room for one.
MT Stringer is offline
post #14 of 20 (permalink) Old 02-13-2017, 08:23 PM Thread Starter
Forum Moderator
difalkner's Avatar
First Name: David
Thanks, Mike! After the last round of tails and cutting boards I was still cleaning dust 3 days later and figured this has to stop. And I seriously should have used hardboard and made it much lighter. Of course, it is stout enough to actually work on without concern that it's going to give way. And for storage all I did is prop it against the handful of other 'too large for anywhere else' items against the garage door that only gets opened about twice a year. I left enough room that I can get to the bandsaw without moving anything.
MEBCWD likes this.
David
Romans 3:23
post #15 of 20 (permalink) Old 02-15-2017, 04:41 AM
hawkeye10's Avatar
First Name: Don
Mike this is how I am going to build mine so storage will not be a problem. I also think I will put T-tracks in the top so I can hold thing in place when sanding or doing something else.
This video shows the top I want to put on it. Comments good or bad needed.
MEBCWD likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #16 of 20 (permalink) Old 02-15-2017, 06:46 AM
Both are interesting ways to address the storage problem, but I really like the second one, building the dust collection into the top of the work table. I found another option, a portable hood that clamps onto the workbench while you're sanding - still needs to be stored, but much smaller.
As an aside, I found that hooking a shop vac up to my ROS gave much better dust collection than the little canister that came with it, there seems to be little or no dust thrown out by the sander now.
tomp913 is offline
post #17 of 20 (permalink) Old 02-15-2017, 12:54 PM
MEBCWD's Avatar
Don the problem I see with mounting it on drawer slides is the working height of the top. I have enough problem with working on the top of a normal workbench but it could be on a drawer mounded shelf where it could be pulled out and raised up onto the top of the workbench. Problem there would be the top of the workbench would need to be cleaned off before you could use the table.
Oh one more possibility it could be hinged to your workbench on the end or back if your bench is not against a wall and mounted right would be higher than the top of the bench when in use or could be mounted where it is flush with the top. with the addition of the T-track it could be used to assist with glue ups. I kind of like this idea because both of my workbenches are on rollers and are usually never against a wall.
MEBCWD is online now
post #18 of 20 (permalink) Old 02-15-2017, 01:36 PM
First Name: Earl
Mike's comments made me visualize one of those blender/mixer mounts--would be pricy unless you ran across someone tossing a set a cabinets!!
earl
MEBCWD likes this.
greenacres2 is offline
post #19 of 20 (permalink) Old 02-15-2017, 03:13 PM
hawkeye10's Avatar
First Name: Don
Mike I thought I would just sit and sand. The bench I sand on now I sit and sand sometimes. I am lazy like that.
MEBCWD likes this.
post #20 of 20 (permalink) Old 02-15-2017, 03:33 PM
MEBCWD's Avatar
So maybe I need to rethink things because my way may be too high for my shop stool.
cut off bin to box to planter to--? JFPNCM Show N' Tell 12 08-27-2019 12:30 AM
Dirty Little Secrets with Sign Making... newmexico Sign Making 45 06-18-2016 02:59 PM
Downdraft Sanding Table rstermer The Finishing Touch 38 08-10-2009 04:48 AM
First Box Joints w/a Hart Design Jig Wild Rag Jigs and Fixtures 2 03-23-2009 08:54 AM
