Making a downdraft sanding box - Router Forums
 25Likes
post #1 of 20 (permalink) Old 02-12-2017, 10:04 PM Thread Starter
difalkner's Avatar
First Name: David
Default Making a downdraft sanding box
I'm guessing dust control goes under the heading of 'Shop Safety'...
Every time we sand anything at all we find that the dust is just too much to deal with and takes hours to clean the shop. So I decided a downdraft sanding box is needed. I've read how some say they don't work very well but I see plenty of how-to videos so someone must like them. Even if it only helped 25% it would be better but after building it and using it I can safely say it is catching at least 75% of the dust, if not more.
So nothing new or secret here, just a video documentation of how I built mine plus the slightly entertaining value of watching us work with a 4x8 sheet in a small shop.
BrianS, JFPNCM, chessnut2 and 7 others like this.
David
Curly Wood Shop on Etsy
David Falkner - Woodworking YouTube channel
Romans 3:23
difalkner is offline
post #2 of 20 (permalink) Old 02-13-2017, 01:58 AM
Good job Dave. Could maybe be in Jigs and Fixtures and would definitely fit in Show and Tell. Shop Safety isn't a misfit.
difalkner likes this.
post #3 of 20 (permalink) Old 02-13-2017, 04:53 AM
hawkeye10's Avatar
First Name: Don
Great post Dave. I am getting ready to build a sanding table also. I want to put mine under a work bench and have it slide out using drawer slides. I also may use "T-tracks" in the top so I can hold things I sand down. That would mean I would have to use 3/4" ply for the top. That would add more weight so I am not sure.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #4 of 20 (permalink) Old 02-13-2017, 05:55 AM Thread Starter
difalkner's Avatar
First Name: David
Thanks, Don!
I can tell you this is heavier than I wanted it to be. My original plan was to have it store on runners or hang directly under the table saw extension but I decided to make it the same size as the extension top so that was out. When I picked it up the first time I knew the only place to store it would be standing up against the garage door. I also thought about getting some pulleys and hanging it directly above the extension by pulling it all the way to the ceiling. But I just made the Walnut/Maple handles and will tote it back and forth.
If I were to make another one I would look at 1/4" or 3/16" hardboard with solid wood internal frame, maybe 3/4" x 3/4" sticks. That might take a little while longer to make but would probably be half the weight.
David
Romans 3:23
post #5 of 20 (permalink) Old 02-13-2017, 10:32 AM
vindaloo's Avatar
First Name: Angie
LOL, you have a huge workshop compared to mine. Mine is 16' x 9' and I can't even get an 8'x4' sheet flat in mine. To break down 8'x4' sheets I had to make a breakdown table for use in my back yard that sits on two collapsible trestles. Then use a circular saw to make the sizes more useable in the workshop.
When everything around you is going to pot, get out in the workshop.
vindaloo is offline
post #6 of 20 (permalink) Old 02-13-2017, 12:29 PM
MEBCWD's Avatar
Dave that is another good video. Looks like a good project but I would have no idea where to store it when not in use. Maybe hinge it on a wall so it could be out of the way but be easy to swing it up when needed.
MEBCWD is offline
post #7 of 20 (permalink) Old 02-13-2017, 12:31 PM
whimsofchaz's Avatar
First Name: Chuck
I really liked the video. Great resource for future reference. Thanks for sharing.
Chuck
whimsofchaz is offline
post #8 of 20 (permalink) Old 02-13-2017, 12:44 PM Thread Starter
difalkner's Avatar
First Name: David
Thanks, Mike! I am actually considering suspending it from the ceiling and lowering it via pulleys and a rope. Then I can raise/lower it as needed.
David
Romans 3:23
post #9 of 20 (permalink) Old 02-13-2017, 02:31 PM
hawkeye10's Avatar
First Name: Don
Dave is yours hooked up to a shop vac. or a big dust collector? I would like to use my shop vac. but I don't know it I will get enough suction. If I use my big dust collector I will have to roll it closer to use it. I really don't want to have to do that because my shop is small "like yours" and it can be a hassle.
post #10 of 20 (permalink) Old 02-13-2017, 06:39 PM
Daikusan's Avatar
Country: Japan
First Name: Steve
Dave, thanks for the great inspiration.
Workmanship is not perfection; it is how well you can cover your mistakes.
Daikusan is offline
Dirty Little Secrets with Sign Making... newmexico Sign Making 45 06-18-2016 02:59 PM
cut off bin to box to planter to--? JFPNCM Show N' Tell 9 01-24-2015 11:32 AM
Downdraft Sanding Table rstermer The Finishing Touch 38 08-10-2009 04:48 AM
First Box Joints w/a Hart Design Jig Wild Rag Jigs and Fixtures 2 03-23-2009 08:54 AM
