Cut my finger. - Page 3 - Router Forums
 19Likes
post #21 of 35 (permalink) Old 04-13-2017, 06:30 AM
First Name: Quenten
The last finger laceration I fixed was about a 3/8" slice over a joint. Dropped a chefs knife & went to catch it instinctively, bad decision! Glued it, had to redo it after a couple of days but it healed perfectly. Medical grade (Dermabond) doesn't sting as much.
Tonto1 is offline
post #22 of 35 (permalink) Old 04-14-2017, 04:53 PM
Knothead47's Avatar
A sharp blade will cut through leather. I was fixing a salad several years ago- cut my right thumb. Three stitches with one through the nail for a total of $310. That's $103.33 per stitch- should have gone to medical school. I did go to a restaurant supply and get a mesh glove. However, it isn't puncture proof and SWMBO fixes the salads and other veggies now.
DaninVan likes this.
John T.
Knothead47 is online now
post #23 of 35 (permalink) Old 04-15-2017, 03:09 PM
A mail glove isn't puncture proof? I did not know that.
There seems to be a wide range of quality (?) and price. Basically from $20 up to $150.
DaninVan is online now
post #24 of 35 (permalink) Old 04-15-2017, 05:36 PM
Daikusan's Avatar
Country: Japan
First Name: Steve
A bullet proof vest will stop a bullet but not a knife.
Workmanship is not perfection; it is how well you can cover your mistakes.
Daikusan is offline
post #25 of 35 (permalink) Old 04-15-2017, 07:46 PM
vchiarelli's Avatar
First Name: Vince
Correct Steve - I had a Kevlar vest issued, when I was in law enforcement and we always knew that. Unless things have changed since I retired 20 years ago.
Herb Stoops likes this.
vchiarelli is offline
post #26 of 35 (permalink) Old 04-17-2017, 02:07 PM
First Name: Quenten
Well I cut my hand while doing maintenance on the band saw mill Saturday! Of course it's 30 miles from my house. So I folded up a napkin & wrapped with electric tape. Finished the day, got home & soaked it in Peroxide & bleach water for about an hour. Re-wrapped it (used 1/2" tape as steri-strips) & today I glued it with Dermabond. Looks like it will heal just fine, this will be the longest I've waited to glue a cut, we will see.
Tonto1 is offline
post #27 of 35 (permalink) Old 04-17-2017, 05:49 PM Thread Starter
hawkeye10's Avatar
First Name: Don
You need to change your name to (John Wayne). Y'all are just a like.
Tonto1 likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #28 of 35 (permalink) Old 04-17-2017, 06:16 PM
TwoSkies57's Avatar
the trick with duct tape and electrical tape is to wrap the wound just tight enough. Not so tight as to cut off the circulation, but tight enough to keep the wound closest. If the wound is REALLY dirty/greasy you gotta suck it up and clean it as quickly as possible. The longer you wait, the more it hurts. Always have a good stash of gaze, peroxide and cloth bandages stored somewhere nearby. I keep em in my truck. If its still bleeding 24/48 hours later, get your butt to the stitcher person *G*....
just sayin' YMMV
Tonto1 likes this.
Skipper the Penguin
TwoSkies57 is offline
post #29 of 35 (permalink) Old 04-17-2017, 06:54 PM
Knothead47's Avatar
There is a big difference here. Go to a restaurant supply and look at their mesh gloves. They are cut proof but not puncture proof. This is a disclaimer on the package and the glove, like the one I have.
Cyanoacrylate glue (CA) was originally used for sutureless surgery. I never thought of using that as I have lots of it.
My daughter is an RN and works in the wound center at the local hospital. When I said I used peroxide, she said it will also destroy good tissue. So.........I guess we will have to do like they did in the old western movies- pour some Red Eye on it.
John T.
post #30 of 35 (permalink) Old 04-17-2017, 09:33 PM
First Name: Quenten
She is kinda right. Peroxide works by cutting the protein chains it the cell walls of the bacteria (they soon rupture and die). It also cuts the same way on our cells that are exposed by the injury. So it's still a great idea to use it as it boils out all the dirt & grime in the wound. Just rinse it off with distilled water or tap water that you boil first. You don't want to do it multiple times since it will destroy the newly built cells that form in the healing process. Nothing wrong with a good initial clean out! The decision it whether to use antibiotic ointment. Only use it on smaller cuts. It will hamper closing in a bigger cut by not letting the sides adhere to each other. And you are right about having some form of first aid kit. And I know better! Wont happen again.
Tonto1 is offline
New Zealand novice JRM1300 New Member Introductions 11 12-21-2016 11:53 PM
First go on Bosch router Estoril-5 General Routing 13 11-29-2016 11:06 AM
Edge Banding Router Bit Sets patlaw General Routing 15 02-02-2016 02:10 PM
up cut vs dn cut? tvman44 Router Bits - Types and Usage 6 07-10-2013 07:08 AM
Ate the end of my finger off OOPS! jbander Shop Safety 24 12-31-2012 08:55 PM
