Dust priorities - mask, shopvac, DC system? - Router Forums
 14Likes
post #1 of 14 (permalink) Old 12-18-2017, 01:05 AM Thread Starter
First Name: Ashley
Default Dust priorities - mask, shopvac, DC system?
(Rebuilding shop after move, attempting to bring beginners mind and question all my prior assumptions... also reading tons of old and current threads here that relate.)
The question is, how to prioritize/optimize investment for protecting health against dust (with my kids getting involved more, this is a bigger deal)
The status quo is cheap two rubber band sanding masks and a rigid shopvac with standard filter.
I see four major areas for improvement
A. The Shopvac path...
A1. Upgrade to HEPA filter in Rigid shopvac and religiously attach it to whatever tool I'm using at the moment. Cost $25 here.
A2. Spend another ~$20-$40 for different hoses or hose size adapters to connect to my sander, router DC attachment, etc.
A3. Spend another $50 - $120 for a cyclone or build a Thein baffle to put in front of the shopvac... and then some kind of cart to support the two together.
B. The DC path...
B1. Buy the HF 2hp dust collector on the New years sale at $150.
B2. Then probably buy the Wynn filter to move from HF's 5 micron to 0.5 to 1 micron... for another ~$200.
B3. Then cyclone or Thein baffle...
C. Install an air cleaning system like the Wen here for <$150 installed cost.
D. Better quality masks, vs. the standard cheap two rubber band face irritating ones I've always used when sanding. Cost - up to $400/person for something like the Trend Airshield or $75/person for the Rockler mask that DesertRatTom likes.
Of course the ideal solution involves at least DC + air cleaning + quality masks.
And of course resources are limited.
How would you prioritize these areas?
Critical context:
- Post-move I have no planer, no jointer, no table saw, and no miter saw. Since there's one more move minimum before final stop, I'm trying to be slow acquiring large things and will continue to do most cutting with a DIY tracksaw/circular saw and jigsaw and when planing is essential I'll use a handheld planer from a nearby tool library.
- I was prepared to buy the HF DC and Wynn filter, so I'm mentally willing to invest that $350-400 there or wherever it's better... but I'm actually now leaning away from those purchases.
If you don't persuade me otherwise, I'm thinking that...
(Skip the HF DC system, allocate funds elsewhere due to size when moving, and lack of large tools that need DC most).
1. Definitely upgrade shopvac filter & connect it directly to my current tool in use. Total ~$60.
2. Buy a couple Rockler masks at $75 each.
3. Add to the shopvac a cyclone or Thien baffle to prolong filter life.
4. If I get this far down the spending list, buy a Wen air cleaner also.
(and when weather permits, open the main garage door and back (people) door and run a couple fans I already own)
All input is welcome.
fire65 and Danman1957 like this.
-Ashley
AshleyJ is offline
post #2 of 14 (permalink) Old 12-18-2017, 01:26 AM
Just some thoughts, Ashley.
The best solution is always the one that collects as much of the dust and debris at the source.
An air cleaner isn't a dust collector. It's a really effective way of eliminating extremely fine airborne particles that escape from the dust collector.
A dust collection system is basically portable; it comes apart pretty quickly for moving, so potentially moving in the future isn't a great argument for ruining your lungs in the present.
If the 2HP system is a real 2HP that's a pretty impressive machine.
Mine's only 1HP and it does a fairly decent job.
You can have the ShopVac and an actual dust collector. Not really an either/or thing.
Good luck, and good on ya for taking the lung issue seriously! Too many guys from the trades crippled by COPD.
DaninVan is online now
post #3 of 14 (permalink) Old 12-18-2017, 07:56 AM
DonkeyHody's Avatar
First Name: Andy
No matter what else you do, there will always be times you need a mask. I've found no way to effectively capture all the dust from sanding on a wood lathe for instance. I can't collect all the fine dust from my Random Orbit Sander either. If you think you're getting all the dust from your router, clean your shop up and then notice how much dust is on everything after you've done some routing.
So, I'd get a better mask first.
DonkeyHody is offline
post #4 of 14 (permalink) Old 12-18-2017, 08:39 AM
I suggest the HF DC and Wynn filter with a Thin baffle inside the dust collector if you don't have large pieces that will damage the impeller. My system is fixed with 4" PVC pipe rotted to all my tools.
MT Stringer likes this.
golfeng is offline
post #5 of 14 (permalink) Old 12-18-2017, 10:38 AM
I'd get the Rockler masks for everyone first, then the DC. Get one mask and see how it fits on the kids, then get the rest if they fit the kids OK. The motor puts positive pressure, filtered air in the mask which I like. Get a couple of spare sets of rechargeable AA battery sets and charger, keep them charged.
If the DC will be in your shop, get the Wynn filter. The HF DC breaks down pretty easily. The WEN ceiling mounted filter works very well, but not sure you'll need it until you have more sawdust heavy tools. I have a small hose that goes to the track saw on one end with a 4 inch connector on the other end that goes into the DC.
As to tools, I can't imagine doing without a table saw as the first priority. If I were to move, my Laguna 10 inch is easily moved, particularly if you take the wings off. Planer is also easy to move (DeWalt 735 with stand is on sale occasionally). A decent jointer will be incredibly heavy, but my 6 inch Powermatic has a mobile base as well. But I think those two thicknessing tools can wait if you're not making precision projects.
When I get a second drum filter for my second HF DC unit, I'll probably buy one with a paddle/handle setup to knock the sawdust off the filter. The Wynn has you blow air through the filter to clean it out.
One small thing: It's tempting when you only have a couple of cuts to make, not to put on the mask, so I keep a box of paper medical masks handy. Better than nothing.
Most table saws have some sort of dust intake below the table but shoot out a lot of sawdust above the table. A friend of mine simply dropped a 2x from the rafter down to just above the saw to hold an inexpensive dc hood over the blade. He uses a 2.5"/4" splitter for collecting dust from the low port and runs a 2.5" pipe up over to the blade collector. You might also check out the Shark Guard, which rides on the splitter and sucks up the sawdust. Don't have one, but it's a great option and folks here seem to like them. Easily removed if necessary.
I worried about moving heavy gear at one time but my brother said just hire a truck and a couple of beefy helpers. Makes sense. Taxifornia is getting me down so I've given it some consideration.
Finally, the WEN filter with a timer. I have fairly good DC in the shop, but the WEN really scrubs the air in there. You can tell the difference, particularly if you have any breathing problems.
Hope this is helpful. I think you're wise to handle DC issues first. I think a lot of people have permanent damage because they didn't handle the dust issue from the start. Your kids will be forming good health and safety habits from the start.
JFPNCM and DaninVan like this.
DesertRatTom is online now
post #6 of 14 (permalink) Old 12-18-2017, 11:58 AM
@AshleyJ
Seems that HF has the DC unit on sale again, with the coupon, it's about $150. I see them on sale about 2-3 times a year, often the 4th of July weekend. Maybe Santa will bring you one?
post #7 of 14 (permalink) Old 12-18-2017, 12:15 PM
Terry Q's Avatar
I’d get the better filter for your shop vac, and a air filtration system. If you use a lathe then that is something all together different and a full face shield with filtered air would be the way to go.
The reason I say air filtration is because some people like me hate wearing masks and only do it when they have too. If you have an air filtration system it will protect the lungs of everyone in the room for the entire time they are in the workroom. If you use masks, the dust is only obvious when you are creating it, but if you take your mask off after routing or sanding or whatever, the dust is still in the air. I can’t imagine wearing a mask for the entire time I’m in my workshop, and your kids won’t want to do it either.
If you’ve never used air filtration you don’t know what you are missing. If I turn on a piece of power equipment to cut something, I’m almost immediately reminded that I don’t have filtration on because I can smell the dust in the air.
kp91 and DesertRatTom like this.
Terry Q is offline
post #8 of 14 (permalink) Old 12-18-2017, 02:47 PM
Country: France
First Name: Gérard
Dust is truly a great problem, and a big health risk.
Wear quality masks!
I use p3 grade made for working with asbestos.
use aspiration, Baffle and ,if possible,push the exhaust out of your workshop...
I don't believe in perfect filtering ,but in my place, the is enought moisture for bacterias and micro-mushrooms to eat wood dust,
they with happiness eat wood beams , so...wood dust...They soon will do.
In fact wood dust is a very dangerous thing.
Regards
ggom
ggom is offline
post #9 of 14 (permalink) Old 12-18-2017, 03:29 PM
BrianS's Avatar
First Name: Brian
I always try to wear a mask when ever I am cutting/sanding/routing/etc.. in short, ANYTHING that will generate dust. I use a 3m mask like this one: 3M dust mask. Replaceable cartridges are available for different uses... ie paint, organics, asbestos, etc. I've used several different disposable masks and most fog up my glasses. The ones that I have had good luck with, and don't fog up my glasses, are the ones with an exhaust vent opposite my nose and mouth. I also use a dust collector, or a shop vac depending on what machine I'm using. Eventually the DC will be accessible for all my machines, but I'm not there yet. I also use a 20" box fan with a furnace filter fastened to the infeed side. Certainly not as good as a dedicated air cleaner, but it does make a huge difference in the particulate floating in the air.
Brian
(Origin uncertain)
BrianS is offline
post #10 of 14 (permalink) Old 12-18-2017, 04:12 PM
About 1/2 of what an equivalent DC costs N. of 49.
Wireless dust collection system RÖENTGEEP Tools and Woodworking 15 11-23-2015 08:08 PM
Big time dust problem lnagel Table-mounted Routing 5 05-18-2009 06:58 AM
Shop Vac dust system kheppner Tools and Woodworking 2 09-14-2006 03:31 PM
Dust mask Learning Herb Tools and Woodworking 4 05-25-2005 08:53 PM
Dust collection system for Router Table yhadar Lobby 2 12-31-2004 01:37 PM
