Bandsaw Blade Tension Safety Switch - Router Forums
 18Likes
post #1 of 11 (permalink) Old 01-17-2018, 03:56 PM Thread Starter
DonkeyHody's Avatar
First Name: Andy
Default Bandsaw Blade Tension Safety Switch
Just once, I forgot to tension the blade before turning the bandsaw on. Don't want to do that again.
For less than $10, I bought a push-button limit switch similar to the one on the blade brake. A block of wood acts as a spacer to hold the switch in the proper position. I Drilled and tapped the back of the saw case to hold the block in place. I wired the tension switch in series with the blade brake switch. Now the motor won't start unless the blade is tensioned.
DonkeyHody is offline
post #2 of 11 (permalink) Old 01-17-2018, 04:38 PM
difalkner's Avatar
First Name: David
Nice work, Andy! How's it work? Looks foolproof to me. Laguna should use that and pay you in saw blades!
David
DesertRatTom and ggom like this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #3 of 11 (permalink) Old 01-17-2018, 05:24 PM Thread Starter
DonkeyHody's Avatar
First Name: Andy
David
How's it work?? If you mean does it work well, yes it does. The blade tension lever must be at the limit of its travel or the saw won't start.
If you mean "how" does it work, it interrupts the current to the magnetic coil that keeps the motor switch engaged. This push-button switch has 3 terminals. One is "Common", one is on when the button is pushed, the other is on when the button is released.
difalkner likes this.
post #4 of 11 (permalink) Old 01-17-2018, 07:35 PM
difalkner's Avatar
First Name: David
Yes, I meant how well does it work but I didn't phrase that correctly, did I? I understand the electrical part.
But the electrical explanation may help someone who doesn't understand that part so good response on both counts - thanks!
David
David
Romans 3:23
post #5 of 11 (permalink) Old 01-25-2018, 02:11 PM
Dejure's Avatar
First Name: Kelly
Good solution.
The reason I have what you want is, I never lent it out before.
Scraps are a myth.
Dejure is offline
post #6 of 11 (permalink) Old 01-25-2018, 02:44 PM
Nickp's Avatar
First Name: Nick
Nicely done...
Nick
Nickp is online now
post #7 of 11 (permalink) Old 01-25-2018, 03:19 PM
I like it. Nice and simple but still very effective.
post #8 of 11 (permalink) Old 05-21-2018, 12:04 PM
First Name: Charlie
Very slick! I may adopt that. I started my Laguna untensioned one time. The blade came of as soon as I started cutting. I thought I had broke the 150.00 Resaw King blade but it was OK, Whew! Now I keep a stick on the table with "blade tension off" wrote on it. I lay it aside when the blade is tensioned.
vchiarelli and DesertRatTom like this.
charlsara is offline
post #9 of 11 (permalink) Old 05-21-2018, 02:15 PM
Nice idea on the switch. But for my little bandsaw kept in the shop, a simple sign would help. Maybe attach it to a short wire so I can flip it away without losing track of it. I think you should suggest this to Laguna.
post #10 of 11 (permalink) Old 05-21-2018, 07:14 PM Thread Starter
DonkeyHody's Avatar
First Name: Andy
I went to Laguna's web site and submitted a message to customer service suggesting they add a stop switch on the blade tension lever. No reply.
Seeking Bandsaw Blade Recommendations and Insight BattleRidge Tools and Woodworking 16 01-20-2018 09:53 PM
Lenox Tri Master Blade For Sale: Jerry Bowen Lobby 0 02-17-2015 01:41 PM
Bandsaw blade substitution chessnut2 Tools and Woodworking 11 12-18-2012 04:39 PM
Grizzly GO636X 17" Ultimate Bandsaw GoonMan Tool Reviews 1 07-27-2008 02:22 AM
Rockler Safety Power Tool Switch 1/3 off Ladd The Bargain Bin 3 12-16-2007 03:45 PM
