Grr-ripper for vertical work on router table - Router Forums
 15Likes
post #1 of 13 (permalink) Old 02-13-2018, 03:16 PM Thread Starter
First Name: stuart
Default Grr-ripper for vertical work on router table
Anybody used a grr-ripper for vertical cuts on the router table? I'm looking at infinity's vertical router table coping sled but I wonder if a grr-ripper would do just as well (and be useful in other applications). Many thanks for any thoughts.
Stuart Wallace is offline
post #2 of 13 (permalink) Old 02-13-2018, 05:03 PM
JOAT's Avatar
First Name: Theo
I've only used mine with my saw, so couldn't say. But, watched the video, if it was me, I'd just make my own version of that coping sled; certainly would cost a lot less. Nothing I would need to do with one on my router, but does give me an idea or two I could use one for on my saw.
Stuart Wallace likes this.
JOAT is offline
post #3 of 13 (permalink) Old 02-13-2018, 05:39 PM
DonkeyHody's Avatar
First Name: Andy
By all means buy a Grripper. I have a pair of them and I use them all the time on both router table and table saw. They simply work better and give me more confidence than anything I've ever tried. However, I think they'd make a poor substitute for a vertical coping sled.
DonkeyHody is offline
post #4 of 13 (permalink) Old 02-13-2018, 08:27 PM
CharleyL's Avatar
First Name: Charley
That requires me to ask you how tall your fence is on your router table and how tall your work is?
For most of what I do on my router table my fence is to low for standing work up on end. About the only time that I did that, I had a taller fence and was using a lock miter bit. Even after getting the bit and fence set correctly for this, I wan't happy with the result, so I have been using splinned miter joints made on my table saw since then.
For work laid flat on the table I use my hands, if it's large enough to do this safely, or if the piece is small I use a Grripper with the narrow side of the Grripper removed, so it will pass over the router bit. I also have one of these for small work http://www.rockler.com/rockler-small...xoCeeQQAvD_BwE I also use this on my table saw. The vertical sled from Infinity is nice, but if I felt that I needed one, I would build something very similar from cabinet plywood. To me, plastic is too slippery for making a jig like this, except for maybe putting strips in the bottom so it slides on the table easily..
Charley
Central North Carolina
CharleyL is offline
post #5 of 13 (permalink) Old 02-13-2018, 08:56 PM
Before you pop for a coping sled, look at how Marc Sommerfeld uses simple push blocks to cut rails, stiles and doors. I have a brand new Woodpecker coping sled sitting in its box. Been used once until I watched how Sommerfeld uses simple blocks with great effectiveness. Here's a video.
His other videos are great at showing great router technique.
post #6 of 13 (permalink) Old 02-13-2018, 09:20 PM
RouterForums.com User
harrysin's Avatar
First Name: Harry
I have always considered the GRR-Ripper to be one of the best accident prevention tools in the woodwork shop. These posed shots show some of the jobs that I use mine for.
Harry
harrysin is offline
post #7 of 13 (permalink) Old 02-13-2018, 10:44 PM
hawkeye10's Avatar
First Name: Don
Originally Posted by DesertRatTom View Post
Before you pop for a coping sled, look at how Marc Sommerfeld uses simple push blocks to cut rails, stiles and doors. I have a brand new Woodpecker coping sled sitting in its box. Been used once until I watched how Sommerfeld uses simple blocks with great effectiveness. Here's a video. https://www.youtube.com/watch?v=hHnLvps8968 His other videos are great at showing great router technique.
The push block he uses is at about 4:49 minute mark in the video. I really like it and it's cheap.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #8 of 13 (permalink) Old 02-14-2018, 08:42 AM
CharleyL's Avatar
First Name: Charley
That's all well and good for routing flat on the table, but the OP wants to rout with the work vertical to the table.
Charley
CharleyL is offline
post #9 of 13 (permalink) Old 02-14-2018, 11:04 AM
MikeMa's Avatar
I actually prefer the Grr-rip Blocks over the Grr-ripper on the router table. They are not quite has expensive, but are actually made to do horizontal and vertical work.
-Mike
Visit my woodworking blog: http://madermadeit.com/
MikeMa is offline
post #10 of 13 (permalink) Old 02-14-2018, 11:08 AM
there are plans for shop made grippers...
Thought I'd share the build of my router table JI808 Table-mounted Routing 29 02-25-2015 06:09 PM
Hello DPugmire New Member Introductions 5 11-08-2010 06:29 AM
Router table or Plunge routing template tom Guide Bushings and Templates 15 04-14-2009 02:45 AM
New poster: Help! Husband wants router for Christmas! Emmie General Routing 21 12-17-2005 08:54 PM
