My Router Screwed Itself! - Page 2 - Router Forums
 18Likes
post #11 of 19 (permalink) Old 03-11-2018, 08:43 AM Thread Starter
DonkeyHody's Avatar
First Name: Andy
Originally Posted by sunnybob View Post
Ditch the remote.
You only got lazy because you no longer have to put your hands near it to switch on.
Sorry, I'm keeping the remote switch. I don't like the idea of fumbling around under the table searching for a switch that changes locations with bit height. The remote switch is in the same place every time, and it's quick and easy to find.
Herb Stoops likes this.
DonkeyHody is offline
post #12 of 19 (permalink) Old 03-11-2018, 09:16 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Yet another perfect reason to use PLUNGE routers in and out of tables. I Know that router has a sort of speed control but it sounds like it doesn't have soft start!
Harry
harrysin is offline
post #13 of 19 (permalink) Old 03-11-2018, 09:41 AM
TenGees's Avatar
First Name: Paul
No utube video of you dancing around, Andy?
Glad you weren't hurt or damage your tool seriously.
Danman1957 and Herb Stoops like this.
TenGees is offline
post #14 of 19 (permalink) Old 03-11-2018, 01:04 PM Thread Starter
DonkeyHody's Avatar
First Name: Andy
My router does have a soft start. But the starting torque was still enough to unscrew the motor from the wax-lubricated base. I have a Triton plunge router, which I prefer to this one, but the Triton has a panel-raising bit in it that I didn't want to re-set.
post #15 of 19 (permalink) Old 03-11-2018, 01:18 PM
I have my variable speed control/On/Off switch mounted to the front under the table edge on both my router tables and the router is in the ON position all the time on HI speed.
Shop guy likes this.
Herb Stoops is online now
post #16 of 19 (permalink) Old 03-11-2018, 11:46 PM
harrysin's Avatar
First Name: Harry
Andy, I have always considered that the Triton was designed for table use, that being so, perhaps it's time to re-arrange things so that the Triton is under the table where I have mine.
reuelt and Danman1957 like this.
Harry
harrysin is offline
post #17 of 19 (permalink) Old 05-31-2018, 05:45 PM
First Name: Reuel
Default Please get a Proper NVR switch
Please get a Proper 110V NVR switch.
If there is a utility Power Failure, for SAFETY you want the tool to stay off when power suddenly returns.
US $21.95 on ebay + freight.
https://www.ebay.com/itm/Electrical-...8AAOxyOMdS8Uiy
Best Regards
Reuel
"The gift of God is eternal life thru Jesus Christ our Lord"
Reuel - means "God's friend" (Heb)
reuelt is offline
post #18 of 19 (permalink) Old 05-31-2018, 08:13 PM
I'm also a fan of those paddle switches. I place them when possible where I can hit them with my leg or hip so I don't have to relese my grip on the workpiece or tool.
jj777746 likes this.
post #19 of 19 (permalink) Old 05-31-2018, 10:35 PM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Buy an NVR switch.
The safety factor of knowing that machine will not start up by itself after a power outage is the main factor, although the ease of just whacking the switch rather trying to push or pull a little lever is also a very good plus.
Another point in the NVR favour is that most ordinary switches like Andy's appears to be is that it only switches the live wire. The neutral is still connected. Its quite possible for a fault on another machine or part of the wiring to push live voltage back down the neutral wire, and suddenly your machine is live, just as youre changing a bit.
sunnybob is online now
Router Backup yuva New Member Introductions 6 01-21-2014 08:33 PM
Help on mounting triton guides (TGA001) on a router table dex2008 Table-mounted Routing 9 08-23-2012 06:38 PM
Thanks for a great forum tmutchf New Member Introductions 9 03-11-2010 04:43 AM
