My Router Screwed Itself! - Router Forums
 18Likes
post #1 of 19 (permalink) Old 03-10-2018, 02:18 PM Thread Starter
DonkeyHody's Avatar
First Name: Andy
Default My Router Screwed Itself!
I was setting up to route a shallow dado using my old Porter Cable 7518 in the table. Got the bit height set perfectly to my satisfaction and I hit the switch to turn the router on. I had forgotten to tighten the base clamp. The starting torque of the router instantly unscrewed the motor from the base. Down on the floor she went, where she writhed around a bit until I killed the power. Lucky for me, I was using a remote starter switch instead of the switch on the router itself. That would have put my hands too close to the falling motor and increased the temptation to try to catch it. As it was, the only harm done was that the bit shaved the insulation off about 6 inches of the power cord. Not quite enough to let the sparks out, but enough that I'll need to replace the cord. Now I gotta figure out a fail-safe to be sure that doesn't happen again.
DonkeyHody is offline
post #2 of 19 (permalink) Old 03-10-2018, 02:32 PM
difalkner's Avatar
First Name: David
Glad it didn't get your hands, Andy!
David
Herb Stoops likes this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is offline
post #3 of 19 (permalink) Old 03-10-2018, 02:49 PM
if you can cut the cord and put a cord cap on it..
build a step under the motor that limits it's travel..
remove the step to remove the motor..
post #4 of 19 (permalink) Old 03-10-2018, 04:02 PM
Good safeth tip there Stick.
post #5 of 19 (permalink) Old 03-10-2018, 05:19 PM
jj777746's Avatar
So glad you didn't try to catch it Andy,could have been a real bad scene
You can't drive a bridge spike with a tack hammer(so I'm told)
jj777746 is offline
post #6 of 19 (permalink) Old 03-10-2018, 06:00 PM
It could have been worse. Without thinking it through I tried mounting my rack and pinion adjusting DW610 in my LV bench top table. First time I loosened the clamp it fell onto the bench.
post #7 of 19 (permalink) Old 03-10-2018, 09:55 PM
Terry Q's Avatar
All good reasons to use router lifts
Terry Q is offline
post #8 of 19 (permalink) Old 03-10-2018, 10:06 PM
old55's Avatar
First Name: Ross
Lucky no damage to yourself.
Ross,
old55 is offline
post #9 of 19 (permalink) Old 03-10-2018, 11:38 PM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Ditch the remote.
You only got lazy because you no longer have to put your hands near it to switch on.
sunnybob is offline
post #10 of 19 (permalink) Old 03-11-2018, 06:49 AM
hawkeye10's Avatar
First Name: Don
Andy, I guess things got lively for a few seconds? Kinda like this . I am glad nothing really bad happened because it could have. Stick has a great idea, so maybe lay a brick or two under it.
Don in Murfreesboro,Tn.
hawkeye10 is offline
Router Backup yuva New Member Introductions 6 01-21-2014 08:33 PM
Help on mounting triton guides (TGA001) on a router table dex2008 Table-mounted Routing 9 08-23-2012 06:38 PM
Thanks for a great forum tmutchf New Member Introductions 9 03-11-2010 04:43 AM
