Feeding a miter cut on a table saw - Router Forums
 26Likes
post #1 of 29 (permalink) Old 04-28-2018, 01:13 PM Thread Starter
JFPNCM's Avatar
First Name: Jon
Default Feeding a miter cut on a table saw
Curious to know the Forum's opinion on how one should feed a miter cut on a table saw. For lack of better words, I'll refer to the two choices as "pull" and "push" as shown in the top and bottom photos below. I was taught to use the push (bottom) approach as it keeps the board tight to the fence and the stop block if one is used. I had never considered the "pull" approach until I saw a friend use it which he described as what he was taught.
My concern with the pull approach is that if the cut were to bind, it could pull the board and one's hand into the blade.
Is there a "best" approach or does this fall into the "each to his/her own preference" category?
Sorry about the sideways photos again.
Jon
JFPNCM is offline
post #2 of 29 (permalink) Old 04-28-2018, 01:26 PM
I'm always in favor of the first pictured method.
post #3 of 29 (permalink) Old 04-28-2018, 01:32 PM
You could use a clamp to secure the work and then it doesn’t matter. The clamp can improve the push cut too as either one tends to pull or push the board sideways.
DesertRatTom and jj777746 like this.
post #4 of 29 (permalink) Old 04-28-2018, 02:14 PM
My preference is for the pointy bit to enter first as the back end is more likely to have any tearout, and in most cases that'd be on the inside of a joint. That and I like what Jon says about (not!) pulling the hand into the blade.
DaninVan is offline
post #5 of 29 (permalink) Old 04-28-2018, 02:51 PM
I don't understand the question,both are push aren't they? It is just that point goes thru first, or heel goes thru first?
Roy Drake and RainMan 2.0 like this.
Herb Stoops is offline
post #6 of 29 (permalink) Old 04-28-2018, 03:11 PM
1st picture method for a rough cut and miter knife to finish...
post #7 of 29 (permalink) Old 04-28-2018, 03:31 PM
vchiarelli's Avatar
First Name: Vince
I'm confused about the "push/pull" terminology as well as in my mind, they are both push cuts. Having said that, using a clamp to hold the work piece and keeping your hands away should negate the possibility of having your hands pulled into the blade. I've always used the orientation in the second picture.
vchiarelli is offline
post #8 of 29 (permalink) Old 04-28-2018, 03:55 PM
First Name: Richard
I use the first picture method.
Shop guy is offline
post #9 of 29 (permalink) Old 04-28-2018, 04:26 PM
RainMan 2.0's Avatar
Mentally, I have to have the material on the right hand side of the miter . Don’t know why , maybe cause I’m right handed?
If tear outs a concern, I’d clamp it and have a piece of mdf as a sacrificial piece
Danman1957 and Herb Stoops like this.
Ok ,I never insulate
RainMan 2.0 is offline
post #10 of 29 (permalink) Old 04-28-2018, 08:56 PM Thread Starter
JFPNCM's Avatar
First Name: Jon
All points are good and I apologize for the confusion generated by the push/pull terminology. To Chuck's point, I use a clamp and add the backer board as suggested by Rick. Stick's suggestion of using the miter knife has a lot of merit.
Thank you one and all.
gjackson52 likes this.
Jon
JFPNCM is offline
Another Newby Tweety New Member Introductions 13 12-18-2017 06:38 AM
GIVEAWAY: Triton Dual Mode Precision Plunge Router TRA001 Cricket Featured Topics 224 04-10-2017 08:32 PM
Hello everyone Martin Reed New Member Introductions 11 03-11-2017 08:47 PM
I wished that there were more woodshop hours on Sunday. inajeep New Member Introductions 12 02-14-2017 11:12 PM
Hello ACE0220 New Member Introductions 11 02-11-2017 10:00 PM
