Dust Separator Comparison - Page 3 - Router Forums
 35Likes
post #21 of 29 (permalink) Old 06-19-2018, 09:23 PM
First Name: Reuel
Default Clearvue Cyclone is BEST
Wood Magazine march2014 page 74
After they tested it they stated it returned 20 times more dust than the Oneida tested a year ago.
Clear Vue returned more dust to particles then five single stage collectors tested last year.
ClearVue came out with the mini-cyclone CV06 for ShopVaC based on Bill Penz’s research FIRST.
But Oneida filed a patent for their dust-deputy first and then wanted Clearvue to “cease and desist”.
Lawyers should not decide that a lousier Oneida Dust Deputy had been copied by a superior design.
Buy Clearvue (the Chief) or the Oneida (the Deputy)
Both are Made in USA
reuelt is offline
post #22 of 29 (permalink) Old 06-20-2018, 10:33 AM
The 2 inch Clearview is about $150. FYI
DesertRatTom is online now
post #23 of 29 (permalink) Old 06-20-2018, 07:59 PM
Gaffboat's Avatar
First Name: Oliver
Great reviews and comparisons, Mike. There is nothing better than first-hand information from an actual user. Thank for taking the time to test and report.
Gaffboat is online now
post #24 of 29 (permalink) Old 06-21-2018, 03:34 AM
First Name: Reuel
The Comparisons are too superficial. Sorry.
1. Standard vacuum bags or filters cartridges will only catch dust >5 microns in size only.
So fine dust that are harmful to health if they pass though a bad cyclone or separator would also have pass though the filter bags or cartridge too.
To really compare, all separators must be connected to the same VAC with SAME brand & model of HEPA filter.
High Efficiency Particulate Air (HEPA) Filter. By definition a HEPA filter shall exhibit a
minimum efficiency of 99.97% when tested with an aerosol of 0.3 micrometer diameter. But NOT all claimed to be HEPA are the same.
2. Dust Deputy is not the best. They claim ONLY 99% - same level as what a $4 (Made in China) Cyclone claims.
"The award-winning design of the Dust Deputy cyclone uses centrifugal force to cyclonically separate and remove over 99% of dust and debris from the air-stream before it ever reaches your vacuum's filter, eliminating clogged filters and suction loss! "
A ClearVue Cyclone claims >99.9%
read Bill Pentz SCIENTICIC cyclone and dust collection research
Dust Collection Research - Home
and be educated more SCIENTIFICALLY.
Best Regards
Reuel
"The gift of God is eternal life thru Jesus Christ our Lord"
Reuel - means "God's friend" (Heb)
reuelt is offline
post #25 of 29 (permalink) Old 06-21-2018, 09:24 AM
rrrun's Avatar
First Name: Henry
[QUOTE=reuelt;1950029]Dust Deputy is not the best. They claim ONLY 99% - same level as what a $4 (Made in China) Cyclone claims.
That's not actually their relevant claim on their current website. This was just taken from the ClearVue website:
Separation of airborne dust is six times better than competing models. Independent medical school testing recorded separation rates at 99.9% of dust particles larger than 5-microns and 80% of fine dust particles sized to 0.5-microns. So little dust gets into the shop vacuum resulting in less filter cleaning or need for replacement filters. Continuous full airflow is uncompromised. The Mini CV06 is a great addition to any workshop. Used in conjunction with a shop vacuum, it is ideal for hand tool workstations and general dust clean up.
This is the claim from Oneida about their Dust Deputy:
The Dust Deputy will separate out over 99.7% of nearly any type of dust and debris, with less than 1% making it into the vacuum – significantly extending the life of your vacuum and saving you countless time and money on expensive replacement filters and dust bags!
These claims do not allow head-to-head comparison (funny how competitive companies always manage to do that). ClearVue claims 99.9% of larger than 5-micron dust particles, but only 80% of fine dust down to .5 microns. Oneida, on the other hand, claims 99.7% of all dust. Which is better? No clue.
I agree that both of these marketing claims are just that: marketing claims. They may be based on scientific findings about their units, but a marketing claim should always be read with a healthy skepticism.
Bob Adams likes this.
Henry
Santa Clarita, CA
www.MowryJournal.com
rrrun is offline
post #26 of 29 (permalink) Old 06-21-2018, 10:42 AM
Gaffboat's Avatar
First Name: Oliver
I realize it is the micron-level dust that is injurious to health, but my reason for owning a Dust Deputy is to catch the big chunks and heavier sawdust created by my planer, CNC, and table saw, without clogging up my shop vac filter. Although I may have to empty the Dust Deputy bucket frequently, little or no noticeable dust makes it to the shop vac, so it can keep it running for a more extended period.
Regardless of the <5-micron filtering issues, I think a Dust Deputy or similar device is a helpful addition to any shop. My ceiling-mounted air cleaner filters out airborne dust to the 1-micron level.
Dejure, JFPNCM, MEBCWD and 1 others like this.
post #27 of 29 (permalink) Old 06-21-2018, 03:10 PM
First Name: Reuel
Originally Posted by rrrun View Post
No clue.
Just look at the shape of the cyclone.
Dust Deputy's design is very simple and made in China is $4 because it is original (=GENERATION 1) design.
In China they already have Generation 3 and Generation 5 design ($25) already.
DD's claim that does not specify 99% of what size of the dust so it is a misleading claim.
Bill Penz who did research said:
"My professor and engineer friends tested most brands and sizes of small shop vacuums, dust collectors, cyclone separators and air cleaners and I shared the results of those tests here on this page but within a week all had to be taken down. Two of the biggest small shop cyclone vendors and one dust collector vendor tied me up with litigation demanding that I remove these test results and also remove every instance of those vendor names from all of my web pages. I spent thousands on attorneys who all assured me we would win eventually, but at too high of a cost. All said that the courts almost never award damages or attorney fees in these kinds of business suits, so this all had to be out of my pocket. Worse, if I did not remove these test results and vendor names immediately, these vendors would be granted a court order to force me to pull down not just the results shared on this page, but all of my web pages for the years they could drag out these nuisance suits. Regardless, each of these suits would cost me at least $25,000 to defend and I do not have a spare $75,000 or more to throw away. Three different woodworking magazine editors shared they had the same problem where the big name vendors forced them to omit negative test results and to change their testing to make certain equipment appear to perform far better than it does in real use. I apologize in advance for not being able to share all our detailed test results."
ClearVue did not design their products. They just implemented Bill Pentz's design which was designed because no other vendors's design was effective.
Roger Edwards likes this.
Best Regards
Reuel
reuelt is offline
post #28 of 29 (permalink) Old Today, 12:41 PM
Dejure's Avatar
First Name: Kelly
Years back, I was doing work on the oldest Queen Ann in Olympia, Washington. One of the projects was cleaning up the cedar siding and shingles in front. To remove the paint, I was using a Paint Shaver Pro, which is like an angle grinder, with which a head that has three triangular carbide teeth that remove up to one square foot of paint in about one minute. Needless to say, the beast throws off a lot of dust and debris.
Initially, I ran a 16 gallon shop vac with a HEPA filter. Run time between filter cleanings was about 5 minutes. Obviously, a pain. More so because you had to be careful with everything, since the place was 80 years old, so most the paint was lead.
On a whim, I build a poor mans Rainbow vacuum using a 30 gallon, plastic drum. The pipe from the Shaver went to the bottom of the drum and the one to the vac stopped just inside the lid. To knock down splash and such, I fit a 3-M floor scrubbing pad in the drum, with a single hole for the pipe running to just off the bottom. I added about five to seven gallons of water and tried the process again. Run time went up to 20 minutes, but what a mucky mess.
I was looking for a better solution and came across a contraption called a Dust Deputy. It sounded good, so I took the two hundred dollar plunge (metal version, for the abuse factor) and have never looked back.
The Dust Deputy also gave me about twenty minutes of run time, but without the muddy mess. Add to that, it kept the efficiency of the vac high enough I was able to drop back to a smaller vac.
The Dust Deputy inspired the purchase of a 3 horse Gorilla for the shop, and Super Dust Deputy for one of the four bag units and another Deputy for the sandblast station.
I had a separator with the 90 degree bends, like the ones in the photos, but was unhappy with the results. That is not to say it didn't help, but the cyclone efficiency spoiled me. That aside, a couple of the other units show do seem to offer promise.
Meanwhile, I love that, whether using the DD, the SDD or other cyclone, I only have to empty out the dust collector collection bags about every five or ten years, though I may have emptied the drum fifty or a hundred times.
The reason I have what you want is, I never lent it out before.
Scraps are a myth.
Dejure is online now
post #29 of 29 (permalink) Old Today, 01:22 PM
First Name: DC
I don't saw, sand, route in the garage shop since the boss (wife) doesn't want all that debris to track into the house so I drag my workbenches into the yard and do all woodworking activities that create dust/chips. I still wear a dust mask and use the Oneida Dust Deputy Jr. outside. I wanted to try the HD Dustopper but all Hawaii stores were having issues with their inventories which have since been resolved but too late. So far the filter Ridgid shop vac (we call it the big oaf) is still clean after 4 months of use.
anndel is online now
Currently Active Users Viewing This Thread: 8 (4 members and 4 guests)
anndel , beltramidave , DesertRatTom , JFPNCM
Dust boxes effectiveness revisited barri Table-mounted Routing 56 11-18-2017 02:10 AM
Small shop dust collection Barry747 Shop Safety 4 10-12-2015 11:04 AM
A Dust Problem rrrun The Finishing Touch 15 01-19-2015 10:44 PM
Index of Dust Collection Solutions and Comments allthunbs Shop Safety 28 03-14-2014 01:40 AM
My Dust Collection System MAFoElffen Tools and Woodworking 19 05-23-2013 03:39 PM
