Table saw kickback - Page 2 - Router Forums
 37Likes
post #11 of 31 (permalink) Old 11-07-2018, 08:16 PM
Semipro's Avatar
First Name: John_*
Steven
I see you joined 4 years ago, 9 more posts and you can post URLs
it is there to keep spam down!
Semipro is offline
post #12 of 31 (permalink) Old 11-07-2018, 09:12 PM
gomolajoe's Avatar
First Name: Joe
Sorry for the upside down pics. I went for the total package. I really like the flat plate for an additional push towards the fence if needed. The videos on their site are helpful.
thomas1389 and Nickp like this.
gomolajoe is offline
post #13 of 31 (permalink) Old 11-07-2018, 09:25 PM
First Name: Steve
Watch you fingers ( I had to pay stupid tax at ER). I use masking tape and gorilla Gel super glue. Run a piece of 3/4 scrap plywood. Make it wide enough to keep you hands clear. I made a handle for mine and mounted it a slight angle in this will keep piece tight to fence for the length of cut. Now the secret is to stand plywood on edge run a piece of 3/4 making tape, Then on the piece wish to orient it and place masking tape to the edge opposite of your desired cut end. Place SG along one side of sled or work , whichever is shorter. place sled against fence and the press the two pieces of masking tape together and set desired size of wood on the left side of blade, push thru There will not be any stupid tax to pay. Separate sled and wood by breaking the tape will let go from wood so nothing is glued together is the masking tape. I was ripping 1/16 and 1/8 strips and used this tool. ordered it at amazon works fantastic. The piece will be uniform You cannot make it for less POWERTEC 71059 Thin Rip Table Saw Jig. I have grr-rip but the toll is much better
Steve Pack is online now
post #14 of 31 (permalink) Old 11-07-2018, 09:26 PM
First Name: Steve
thanks
post #15 of 31 (permalink) Old 11-07-2018, 11:54 PM
JOAT's Avatar
First Name: Theo
I've got a Grrrrrripper (however you spell it), and like it. Won it, didn't buy it. I'm 77, started out helping my grandfather when I was probably 7 or 8. Started using power tools in 9th grade, table saw in 10th grade. No riving knife or kick back thingies on my saw. Never had a kickback yet, and don't plan on having one. BUT, just in case, I always stand out of line with the blade. Learned that one in the 10th grade, when our shop teacher demonstrated kickback, and described what caused it. And I still remember that piece of wood hitting the wall. Unless I am holding a piece of wood well away from the blade, I use push blocks, not so often push sticks. I set my blade so it just cuts the top of the wood, then use a push block, with a handle, thick enough that I can pass right over the blade and it will just make a very small cut on the bottom of the push block, and impossible to cut me. It helps to be a bit scared of the saw, or anytool with whirly parts that can bite you; it make you careful.
You see pictures and videos of people standing in line with the blade of a saw, a lot of time supposedly skilled woodworkers. Which just about guarantees that if there is kickback, they are going to get hit. Standing out of line with the blade is one of the best safety measures you can take with a table saw.
Marco, JFPNCM, DaninVan and 2 others like this.
JOAT is offline
post #16 of 31 (permalink) Old 11-08-2018, 02:41 PM
JFPNCM's Avatar
First Name: Jon
Another approach i’ve Found when ripping thin pieces is to use a magnetic clamp to hold the shop vac hose just to the left of the piece being cut off The vacuum will pull the thin piece over and hold it in place. I’ve never tried for pieces wider than 1/2” however. Believe the approach was originally posted on this forum but not sure by who.
obviously not a cure for kickback but helpful with the upside of pulling off some sawdust as well.
Jon
JFPNCM is online now
post #17 of 31 (permalink) Old 02-01-2020, 09:43 PM
First Name: Mark
I learned how to rip thin pieces of stock the hard way and got my finger. I was very lucky to come away with just a nasty cut to the index finger that left a nice scar. Since then, if I need a piece of stock less than a push stick, I cut it from a much larger piece. For example, if my piece needs to be 2" x 1/4", I will cut a piece 5" (by 8' or whatever I need to get the lineal feet needed) and then start my 1/4" rip. Taking it nice and slow, the blade is never exposed except at the end. I can even flip the board to the opposite side when done and run another 1/4" run. Then, after the 1/4 rips are in the 5" board, I will lay the board down and rip the 2" needed and no finger(s) are subjected to blade danger. Yet, with this method, it is very obvious that I do not have my blade (top) guard on.
rmark is offline
post #18 of 31 (permalink) Old 02-02-2020, 12:34 PM
CharleyL's Avatar
First Name: Charley
The Grrippers are nice, and I now own three, one of them has the narrow side removed and it is dedicated for use on the router table. The other two are mostly for use on the table saw, the two provide the ability to hand over hand feed long boards when ripping. The orange push stick in Harry's photo #5, or any of it's similar designs are very dangerous to use as the primary pushing device on a table saw, because they fail to hold the work down as it's being pushed through the cut, and the rear of the blade can lift the piece easily and throw it at you. They are OK for other purposes, and can be used as a second tool to hold the work against the fence, but your primary "push stick" needs to be of a design that both holds the work piece down and against the fence, as well as push it forward through the cut and beyond the blade. During any of these cuts your hands and fingers should never get less than 6" from the blade or cutter, unless it's fully protected by the pusher device, like when holding the handle of a Grripper.
I use my Grrippers a lot, but still use my shop made pushers for certain operations on my table saw, but every one of them holds the work down as well as pushes it forward, and my hand is always on the handle of it to keep it 6" or more away from the spinney sharp thing. Whenever I'm about to use one of my woodworking tools I mentally go through the process that I'm planning. If any part of the process will put my fingers or any other part of my body closer than 6" to that sharp spinney thing, I'll find another way to do it.
I've been woodworking or helping my dad and uncles do woodworking since I was about 8. I'm almost 78 now, and still have all ten with no scars from those sharp spinney things. Scars from other things yes, but not from woodworking tools.
Charley
JFPNCM and DesertRatTom like this.
Central North Carolina
CharleyL is offline
post #19 of 31 (permalink) Old 02-02-2020, 02:04 PM
Like Charley, I preplan almost every cut, working out how to do it best/safely. For thin strips, which I cut often, I have a Rockler thin strip jig, that lets me cut same size strips on the outside edge of the blade and so the fence is moved and the outside piece isn't trapped against the blade. A piece trapped against the fence is more likely to kick back because it's easy to catch it on the blade as you push the last bit through. That's where the Grripper's 1/8th foot comes into play. The alternative as the piece gets thinner and thinner is a long, skinny push block. The pictures are of a variety of push sticks and simple shop made push blocks, any of which will increase safety.
Name:	push stick 1.jpg
Name:	push stick block.jpg
Name:	push sticks.jpg
DesertRatTom is online now
post #20 of 31 (permalink) Old 02-02-2020, 02:16 PM
Pro4824's Avatar
First Name: Joe
I use the bandsaw for thin strips. Much safer.
Stick486 likes this.
Pro4824 is offline
Design for folding cutting table DesertRatTom Tools and Woodworking 18 06-01-2018 08:47 PM
New fence (Part 2) Out Feed Table Coleve Show N' Tell 23 11-16-2017 01:09 PM
Resurrected bird table Coleve Show N' Tell 16 12-07-2013 07:05 AM
Dust Collection on Table Saw Router Table Extension Guitarman1 Table-mounted Routing 0 10-02-2011 03:32 PM
kickback on router table delia1tj Table-mounted Routing 12 08-03-2010 02:17 AM
