Be careful out there... tragic - Page 2 - Router Forums
 25Likes
post #11 of 20 (permalink) Old 12-19-2018, 07:56 PM
First Name: martin
Electrocuted while wood burning sounds like it Doug. With a standard hot iron almost all the current is converted to heat by resistance so virtually no chance he could be electrocuted that way. I've read that sticking a knife into an active toaster isn't as dangerous as it is reputed because of that reason.
whoever is posting that misinformation is putting people's lives at risk!. you still have 120 volts at a high current on the hot leg of the appliance, that is NOT converted or used!.. make a good enough connection to that, and ground or the neutral, and you can be killed!. https://www.asc.ohio-state.edu/physi...l_current.html what they should have mentioned is that High Voltage at a high current is more dangerous, because I=E/R which is the current equals the voltage divided by the resistance, so the more voltage, the more current can flow with a set resistance!. something like a microwave transformer can supply 1 amp, way more than enough to kill you!..
Dejure likes this.
radios is offline
post #12 of 20 (permalink) Old 12-19-2018, 10:19 PM
jj777746's Avatar
Well there ya go,It's the amps that kill,not the volts.True or false? James jj777746.
You can't drive a bridge spike with a tack hammer(so I'm told)
jj777746 is online now
post #13 of 20 (permalink) Old 12-20-2018, 06:36 AM Thread Starter
kp91's Avatar
First Name: Doug
Mostly true. The electrical signals that regulate the heart are quite small, and can be disrupted bu a relatively weak current. Also important is the path the current takes through the body. Worst case is a path directly across the heart.
Higher voltage can increase the likelihood for that current to flow across a given resistance.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #14 of 20 (permalink) Old 12-22-2018, 03:45 AM
So sad.
kp91 likes this.
Sydney, Australia
jw2170 is offline
post #15 of 20 (permalink) Old 09-18-2019, 12:55 PM
Dejure's Avatar
First Name: Kelly
The main wood turning association banned anything tied to it in their shows, and for good reason.
Some guys brought their beast to a meeting and gave a demo. Having worked both electrical (PSNS, shop 51, electricians) and electronics (Keyport & Bangor, Wash.), it scared the hell out of me. These boys took a lot for granted. My shop has 1" thick rubber mats and I'd have second thoughts with most the systems I've seen. "Maybe" with a 5 foot glass pole. They were doing it on concrete floors and no mats.
kp91 and Gene Howe like this.
The reason I have what you want is, I never lent it out before.
Scraps are a myth.
Dejure is offline
post #16 of 20 (permalink) Old 09-18-2019, 01:12 PM
David Bradford's Avatar
First Name: David
I do all the electrical work around our shop but I would want no part in that process.
kp91, Gene Howe and RainMan 2.0 like this.
David Bradford is offline
post #17 of 20 (permalink) Old 12-16-2019, 12:49 AM
Dejure's Avatar
First Name: Kelly
Holy cow, I find it difficult to believe people are that ignorant, but....
That's like saying the knife I stick in an outlet will act like the nichrome wire so all the electric turning it red hot [as the current through it into me] dissipates the dangerous electrons leaving only the good ones so.....
Scraps are a myth.
Dejure is offline
post #18 of 20 (permalink) Old 12-16-2019, 08:16 AM
Nickp's Avatar
First Name: Nick
Very sad to hear...just can't imagine what the kids felt when they found their father...
Nick
Nickp is online now
post #19 of 20 (permalink) Old 12-16-2019, 08:32 AM
Knothead47's Avatar
Sad story. I was in a gift shop last Friday and there were several pieces by a local person who made several items, advertised as the Lichtenberg process. I cringed and almost said something to the store owner.
John T.
Knothead47 is offline
post #20 of 20 (permalink) Old 12-16-2019, 08:43 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Perhaps a double wound isolation transformer would have prevented this tragedy.
Harry
harrysin is offline
Wood for stringers... Nickp Wood Species 14 01-24-2013 08:26 AM
A tragic lesson Gene Howe Shop Safety 8 04-21-2011 05:26 PM
It's just tragic. The oil AxlMyk Lobby 48 08-01-2010 08:39 AM
Be careful out there... Gene Howe Tools and Woodworking 10 11-16-2009 09:31 PM
