Full face mask for eye and lung protection - Router Forums
 44Likes
post #1 of 34 (permalink) Old 05-11-2019, 03:06 PM Thread Starter
RainMan 2.0's Avatar
Default Full face mask for eye and lung protection
Hey guys, I had a major mowing the lawn last week . I didn’t bag my clippings, so my corneal transplant went off the deep end , breaking a bunch of blood vessels in the eye .
I wear a mask over my mouth and nose ,as I sneeze for days after cutting if I don’t , but safety glasses do not offer me enough protection from the air born particles coming from the grass .
Although I didn’t want to spend an exorbitant amount of money on a respirator system, I’m thinking this one from 3M may be the best solution. The replacement filters alone are over $300?
It does not work for paint vapours, but apparently it’s great for dust .
One other problem I have been having is coughing for days after I’ve cut Mdf.
I have dust collection on my TS, and wear a 3M mask , but ten minutes later when I remove the mask , there seems to still be airborne particulates from the mdf .
So I’m thinking , although this is expensive, it may pay off in spades. Not sure if there’s a cheaper price in Canada, or a better solution.
Anyone familiar with this product ?
https://www.amazon.ca/dp/B007PB4C38/...v_ov_lig_dp_it
Ok ,I never insulate
RainMan 2.0 is online now
post #2 of 34 (permalink) Old 05-11-2019, 04:23 PM
If dust is hanging around in the air, consider an air filtration unit that has a timer. I have a WEN unit in my shop and another in the garage that I can set to run for 1, 2, 4 or 8 hours. After 2 hours there isn't any dust left in the air, but once in awhile, I let it go for 4 hours. Really helps.
Didn't know you had a corneal transplant. Which may help explain why you're sensitive to blue spectrum LEDs. I have a Rockler battery powered ventilation mask that is very good for dust, add to that an appropriate eye protection of shield, and it might do the trick.
Pix of both attached: Got the WEN for about $100 U.S., the mask is about $80 from Rockler. Good face mask wouldn't be that much either. Maybe those will do the trick.
DesertRatTom is online now
post #3 of 34 (permalink) Old 05-11-2019, 04:26 PM
JOAT's Avatar
First Name: Theo
Although I didnít want to spend an exorbitant amount of money on a respirator system, Iím thinking this one from 3M may be the best solution. The replacement filters alone are over $300?
It does not work for paint vapours, but apparently itís great for dust .
One other problem I have been having is coughing for days after Iíve cut Mdf.
I have the lawn mowing part solved. I have a lot of trees, and it takes a lot of work to have a lawn. Stopped mowing in '84, when the first ex walked out.
I would think goggles would likely work.
Maybe a respirator like Tom recommended to me. Battery powered, runs around $50 USD. Somewhere on Amazon. 3M?
I deal with MDF dust, by not using MDF. Tried it once, won't use it again I have a window in the back of my shop. I keep it open a bit, and a box fan runs constantly. Any floating dust particles always disappear out the front door quite nicely. Best I can come up with.
RainMan 2.0 and jj777746 like this.
JOAT is offline
post #4 of 34 (permalink) Old 05-11-2019, 04:41 PM Thread Starter
Tom, my eye went off the deep end mowing the grass . I did not get impacted by anything .
It’s happened before,but never this serious .
So I pretty need total protection,so whether I like it or not , I think I have to go further in debt and go with the 3M system .
I was also debating to get one of those air filter systems that you hang also .
Joat, I can’t wear googles , as they fog up almost immediately
post #5 of 34 (permalink) Old 05-11-2019, 04:41 PM
kp91's Avatar
First Name: Doug
Rick,
I have 2 PAPR units, both older models. I have the Triton model, which works very well for what I need, and I have the OLD 3M version that my youngest uses for wood turning. (She has asthma and it can be triggered by the dust). The newer helmet looks a lot smaller than hers, and the battery technology is a lot better if it lives up to the advertisement.
Both were acquired used. The triton I got off of EBAY, the 3M unit at a government surplus auction. My primary goal of using a PAPR was dealing with the summer time humidity, glasses, and a dust mask. I would fog my glasses up so bad I couldn't see, so I wouldn't wear the mask. The PAPR works great for this, I actually will wear it. I really like the blower on the belt, keeps the helmet weight down.
If you don't wear glasses, you might try a full face respirator, they can be had for quite cheap, and are surprisingly comfortable. Just check to see if they have an impact rating if you are going to count on it for primary eye protection.
RainMan 2.0 likes this.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #6 of 34 (permalink) Old 05-11-2019, 04:48 PM
kp91's Avatar
First Name: Doug
Halfway option, but a little more cumbersome in my opinion....
What the paint guys use https://www.zoro.com/3m-papr-system-...wHwg&gclsrc=ds
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #7 of 34 (permalink) Old 05-11-2019, 04:49 PM Thread Starter
Originally Posted by kp91 View Post
Rick,
I have to wear cheaters , so thereís that . I remember seeing a pic a while back with your daughter using a similar looking system , and was hoping youíd chime in .
Seems weird having to walk around my shop like Iím working with the Ebola virus, but I guess it doesnít always have to be on .
I get strange enough looks when Iím wearing my 3M mask mowing the lawn . But I sure like not having the allergies later
MEBCWD likes this.
post #8 of 34 (permalink) Old 05-11-2019, 07:07 PM
kp91's Avatar
First Name: Doug
Weird looks, or bad lungs........ easy enough choice in my book. I look weird enough without trying anyway.
I have had the luxury of trying a lot of PPE over the years at work, and seen seen some cool, expensive stuff that was supposed to be the end all and beat all. Unfortunately, if the guys won't wear it, it's useless. If you find something that works and that you will use, then you've got something.
MEBCWD, TenGees and jj777746 like this.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #9 of 34 (permalink) Old 05-11-2019, 07:24 PM
The rockler mask blows a little air under my glasses so they don't fog up. It's pretty comfortable on my ample schnoz.
jj777746 likes this.
post #10 of 34 (permalink) Old 05-11-2019, 07:36 PM Thread Starter
I’m with you . My neighbour says I look like a bug when I cut the lawn . I just like the fact that I never breathed in any grass ,dust or contaminates . I have a few dry spots on my lawn where I need some more seed, and I get quite a dirt storm when I mow over it .
I’d much rather not breath it in,as I think dirt goes in your lungs but so much out .
I may take the plunge and get the one from 3M ,the 300. It doesn’t do paint,(the 600 does) but I’ll use my mask that’s rated for paint for the few times I use spray bombs . I am going to change my gyms yellow equipment to orange, so I will be spraying for a while when the day comes .
But right now my main concern is my lawn and my shop . Seeing as it has face protection,that’s an added bonus there . Hopefully it’d replaceable.
I’m not seeing a better price than on amazon.ca, which is unusual .
