Fire safety, small shop must have, cheap and safe - Page 3 - Router Forums
 52Likes
post #21 of 38 (permalink) Old 08-30-2019, 07:45 PM Thread Starter
BCR
Originally Posted by Danman1957 View Post
I have 3 in my shop, 2 as shown and another for chemical fires. A must in all shops for sure.
Yeah, my sentiments exactly. These are a must in all small shops.
I do not say big shops, as most of them will be business class, and will have MANDATORY fire safety cabinets as well extinguishers.
Anyway, may not be back for awhile to answer any PM's or the like, due to Dorian (grey)….
Looks as though it is headed - centered at me here in SoFlo. I live pretty far out west, but winds get bad here, so the house I have been shuttering up all day (as much as I can, work).
BCR is offline
post #22 of 38 (permalink) Old 08-30-2019, 11:18 PM
I have one installed in the back of the Ute...
Bought it mainly for fire protection in the camper trailer....(Propane (Gas) stoves etc..)
Only a small one like in the picture. I did read that it should be at least double that size to be really effective....
Herb Stoops and jj777746 like this.
Sydney, Australia
jw2170 is offline
post #23 of 38 (permalink) Old 08-31-2019, 01:44 AM
Good luck Brian. According to the forecast I heard tonight you have until Monday.
BCR and Herb Stoops like this.
post #24 of 38 (permalink) Old 08-31-2019, 02:28 AM
good luck Brian w/ your meteorological calamity...
BCR likes this.
Stick486 is offline
post #25 of 38 (permalink) Old 08-31-2019, 11:44 AM
Nickp's Avatar
First Name: Nick
Be safe with the storm...take no chances...hope all goes well for you...
Nick
Nickp is offline
post #26 of 38 (permalink) Old 08-31-2019, 02:35 PM
Danman1957's Avatar
Good luck with the storm Brian
BCR likes this.
Don't fear your tools, pay attention and respect the tools and avoid injury.
Danman1957 is offline
post #27 of 38 (permalink) Old 09-01-2019, 09:35 PM
You guys seem to be copping it all ways this season.
Hope no members badly affected..
BCR likes this.
Sydney, Australia
jw2170 is offline
post #28 of 38 (permalink) Old 09-02-2019, 10:51 AM
CharleyL's Avatar
First Name: Charley
The only safe way to put out a propane or city gas fire is to turn off the gas. If you put the fire out and don't stop the gas flow quickly, it will find another ignition source and re-light, possibly causing a bigger fire and/or explosion in the process. You don't want to be there when this happens. Control the fire so nothing else burns, but don't put it out.
Purple K fire extinguishers are intended for burning metal fires. They are expensive, and not very good at fighting any other kind of fire. We carried 1 Purple K extinguisher on each engine, and used them mostly when we had a VW hatchback engine fire, because the fan part of the engine was made from magnesium and was very difficult to put out any other way. Many times it was necessary to chop out the burning metal and bury it to put it out because even the Purple K didn't work well enough, and at least two engines responded to every auto accident or vehicle fire, one of them being a tanker/pumper, so we brought over 2,500 gallons of water with us, and at least two Purple K extinguishers.
Fire Classifications -
A = burning wood and paper
B = burning liquids
C = burning electrical fires (best to turn off electrical source first, in which case it
becomes more of a class B fire)
D = Burning metal
Carbon Dioxide fire extinguishers are great for class B and C fires, but they are heavy. Their one big advantage is that they don't make a mess like dry chemical extinguishers do.
Water is a great class A fire extinguisher.
When using a fire extinguisher, get as close as you can to the fire and use the extinguisher to sweep the fire off of the burning material much like you would use a push broom. Be careful not to allow it to sneak back around either side as you advance, and continue until the fire is completely out. Then back away carefully until you are safely out of the involved area. Fires can re-light, so be prepared not to allow it to get behind you as you back away.
Don't keep your fire extinguisher right next to the most probable sources of fire. Locate it near your exit point.
That way, as you are running away from the fire, you can decide to turn and fight the fire with the fire extinguisher, or decide that it's too big to fight and continue running away, hopefully toward a phone or alarm call box to get help. A fire extinguisher that is located close to the likely fire source could be in the fire, and it will do you no good, since it won't fight the fire without you operating it.
An untrained person will not operate a fire extinguisher correctly, so their chances of successfully putting a fire out by using a small fire extinguisher, like the 2 1/2 lb in the photo above, because they will waste most of the few seconds that the extinguisher will deliver the extinguishing agent. They will spray it at the fire and smoke rather than at the base of the fire, or they will begin shooting the extinguisher from too far away for it to be effective. If used properly and under all of the right conditions, that 2 1/2 lb dry chemical extinguisher can put out a fire in a trash can and not much larger. If it's a bigger fire than that, your chances will be significantly reduced, especially if you have had no experience using a fire extinguisher.
I have two 10 lb dry chemical ABC extinguishers and one 20 lb CO2 extinguisher in my shop, all located next to the exit doors. I also have a water faucet and a 50' garden hose and nozzle on the outside of the shop between the exits. The nearest manned fire station to my home and shop is also only 2 1/2 miles away. My kitchen has a 10 lb ABC dry chemical located in it near the door, and my garage has a 10 lb dry chemical ABC plus a 20 lb CO2 extinguisher located just inside and between the two garage doors. There is also a pressurized water extinguisher in both the first and second floor hallways.
I was a volunteer fireman from the age of 18, working my way up to Captain of a 6 vehicle fire company. For my last 7 years, before my first retirement at the age of 58, I was the fire marshal for a 3.8 million sq ft manufacturing facility located on 1,364 acres. I managed 5 fire technicians who maintained and tested all of the fire equipment in the facility.
I have a deep respect for fire, and the damage that it can do. I've probably a bit over protected my family, home, and shop, but I feel comfortable in the fact that I have fire extinguishers placed near my family and me, so we can minimize any fire damage to our property until help arrives. The farther you are away from your nearest fire company, the more protection that you should have because you won't likely have any help for at least 5 minutes and in rural areas this could be 35 minutes or more. I've arrived at structure fires before the trucks have arrived and made significant progress using only a garden hose, or even snow to fight the fire, until the trucks got there.
Charley
BCR, Nickp and tulowd like this.
Central North Carolina
CharleyL is offline
post #29 of 38 (permalink) Old 09-02-2019, 05:01 PM
First Name: Larry
The Navy had purple K extinguishers that were flat amazing on how they put out fires. Never have seen them in civilian places??
Larry42 is offline
post #30 of 38 (permalink) Old 09-05-2019, 09:05 PM Thread Starter
BCR
Thanks fellows for your concerns. I am fine, the most we had here was a few trees knocked over, and a little mess (thankfully) I dodged a bullet, but perhaps others may have not, this has (and still is) been a very bad storm. Bahamas, oh wow, I feel bad for them.
Again thanks for your concern, back on topic.
Yes, finally got around to hanging the FE, changed places, it is far away from all machinery, and is right next to door opening (it's farthest away from all tools, but in a spot I will see it every time I use shop, so will know where it is in a hurry (emergency, that hopefully I will never need).
On another note: I decided to pick up a 4th can, so I can spread these all out evenly throughout house. Still at a price, in comparison to other brands that only do a B +C fire for 50.00 dollars that have a 2.5 pound use.
Oh yeah, for these, they are 5 pounders for 16.99 since I have so many, I felt that I did not need a single 10 or 20 pounder. (with luck, I wood get to the fire quick enough).
Yes that was a bad pun.
BCR is offline
