Thickness Planer mishap - Router Forums
post #1 of 18 (permalink) Old 12-13-2009, 02:51 AM Thread Starter
TRN_Diesel's Avatar
Default Thickness Planer mishap
While making the cutting boards I tried to pass the boards through the thickness planer and well my little 12 1/2" Delta said no way and spit it back out at me.
I was standing in front of the machine and it hit me in the legs. Another 3 inches and I would be singing Silent Night in a few higher notes.
So a word to the wise do not be an idiot like me and try to plane a cross grain cutting board it does not work so well.
TRN_Diesel is offline
post #2 of 18 (permalink) Old 12-13-2009, 08:42 AM
AxlMyk's Avatar
Crossgrain ANYTHING dpesn't work well in a planer. I found that out with a slab of rosewood I tried. It exploded in the machine.
Glad you're OK.
AxlMyk is offline
post #3 of 18 (permalink) Old 12-13-2009, 09:32 AM
Hamlin's Avatar
First Name: Ken
Glad to hear you're ok Dan.
Ken
"A VETERAN"
Hamlin is offline
post #4 of 18 (permalink) Old 12-13-2009, 10:25 AM
First Name: Jiggs
On another forum I read about making a "frame" from 2x4's on your breadboard.
Mill 2x4's to the thickness of your board. glue the 2x4's to the edges (just the long side) leaving them a few inches longer than the cutting board.. When running through the planner take a minimum amount of stock with each pass, When your desired thickness is reached - take the board to the table saw and remove the frame. It works - I have done many this way with no problems.
There were also many positive comments on the way this works from several of the other members.
Angus
angus is offline
post #5 of 18 (permalink) Old 12-13-2009, 10:31 AM Thread Starter
TRN_Diesel's Avatar
Angus
Thanks will keep that in mind next time.
post #6 of 18 (permalink) Old 12-13-2009, 10:50 AM
First Name: Duane
I just wouldn't do it LOL !!
Glad you are ok buddy !
Duane867 is offline
post #7 of 18 (permalink) Old 12-13-2009, 11:55 AM
TwoSkies57's Avatar
Man.. when ya least expect it!! I've got a nice scar on my left wrist to prove it. Having milled what seems like miles of timber through my planer without incident I would have never given cross grain a thought. A great heads up thread!! thanks...
TwoSkies57 is offline
post #8 of 18 (permalink) Old 12-13-2009, 12:49 PM
Bob N's Avatar
First Name: Bob
Hi Dan,
I was almost afraid to open this thread after reading the topic
Glad you are "tall" and okay
Bob N is offline
post #9 of 18 (permalink) Old 12-13-2009, 01:09 PM
Ghidrah's Avatar
First Name: Ronald
I've never tried cross grain planing.
It was spit out because the board wasn't wide enough to span both rollers?
Ghidrah is offline
post #10 of 18 (permalink) Old 12-13-2009, 01:57 PM
RealCom's Avatar
First Name: Ralph
Dan,
I am making some cutting boards for Chriustmas also. and a couple are end grain boards. I use my Delta 13" planer and just make sure that I have it set to take the least cut possible. It will always tearout your edges, but I just clean them up with my TS and then route the edges.
RealCom is offline
Wonderful Wife (new jointer and planer) xplorx4 Tools and Woodworking 11 11-08-2009 04:29 PM
Thickness planer stand AxlMyk AxlMyks' stuff 20 07-22-2009 01:35 AM
Thickness Planer Sled pmspirito Jigs and Fixtures 7 11-08-2007 01:44 PM
thickness planer mounting reds_21 Tools and Woodworking 4 08-07-2005 10:14 PM
Thickness Planer Wood Defect....... reds_21 Tools and Woodworking 3 05-15-2005 08:47 AM
