Brush with disaster! - Router Forums
post #1 of 16 (permalink) Old 09-09-2011, 01:36 PM Thread Starter
First Name: Alan
Default Brush with disaster!
I made a start on the oak cabinets today but had a disasterous mishap with the planer! Stupidly I was rushing and feeding the legths of oak through the blades on my Elu P/T. Without thinking I brushed some dust off the table with a sweep of my hand as two of my fingers went pass the guard straight into the spinning block! :shock: ops: Initially I thought I had just hit the guard with my finger but as I jerked my hand back blood spattered across the workshop! Oh Dear! I didn't dare look to see what I had done. When I plucked up the courage to look I was amazed that I had got away with just cutting a flap on the end quite deep though. Here it is after it had stopped bleeding:
I have never liked those Euro guards on these machines now I think they are downright dangerous! Still I should have known better as I normally blow off any chippings. Well lesson learned and I WONT do that again. I consider myself very lucky and am normally a safe worker. Only the second accident in 20 years so not so bad. I did have the guard in place and low to the blade but nothing guarding the blade where the wood had been fed through, if it had been the pork chop guard this would not have happened.
mailee is offline
post #2 of 16 (permalink) Old 09-09-2011, 01:51 PM
DAM Alan
That makes me sick sorry
I'm glad you still have all your parts ..
post #3 of 16 (permalink) Old 09-09-2011, 01:55 PM
Dal300's Avatar
First Name: Dallas
Alan, I hate when that happens!
I have a bad habit of brushing off the router table top so I can make the next pass. I don't know how I picked up the habit because I use to blow it off. Luckily I haven't routed any fingers yet!
I hope the rest of your week goes better!
Dal300 is offline
post #4 of 16 (permalink) Old 09-09-2011, 02:08 PM
papawd's Avatar
First Name: warren
Glad You did not loose finger
papawd is offline
post #5 of 16 (permalink) Old 09-09-2011, 02:27 PM
BigJimAK's Avatar
Dang, Alan... It's sickening but a good reminder on how fast these things can happen.
FWIW, I've been working diligently on dragging an air hose over near my TS, jointer and router table when I work on them, to blow away the dust and chips. When I get my permanent shop I'll pre-plumb the air and have a coiled air hose with nossle permanently mounted by each.
Is it overkill? Probably so. The upside is that it's significantly reduced the nuisance splinters and keeps the hands away from the knives.
Just my $0.02.. YMMV.
Jim
BigJimAK is offline
post #6 of 16 (permalink) Old 09-09-2011, 02:48 PM Thread Starter
First Name: Alan
Thanks guys. I do count myself very lucky. I normally blow dust off just by blowing the chips away so why on earth I brushed them off I still don't know? there is one thing for sure that I won't be doing it in the future. I have to say that I much prefer the pork chop type of guard you have on the machines in the USA as these are much safer than the euro guard we have to have on our machines here. I have a smaller jointer which is fitted with this type but I have a problem with the tables on it at the moment so used the bigger machine, bit Ironic really. Still it was my own stupid fault and I should have known better. Just thought I would post this as a warning to others of my silly mistake. It is my second accident with a woodworking machine in 20 years so hopefully there won't be any more.
mailee is offline
post #7 of 16 (permalink) Old 09-09-2011, 06:45 PM
BigJimAK's Avatar
Alan,
I've only seen Euro guards advertised in magazines, having a porkchop on my little jointer. That said, I have contemplated some day replacing my jointer and my old lunchbox Delta planer with a Jet 12" JJP-12HH jointer/planer. That unit has the Euro-style guard.
Would you please compare/contrast the two for us (and tell me why you don't like them) to help me in my contemplation? <g>
Jim
BigJimAK is offline
post #8 of 16 (permalink) Old 09-09-2011, 07:43 PM Thread Starter
First Name: Alan
Well Jim, with the euro guard it covers the blades when planing the wide section and the idea is that you pass the timber under it straddling the guard with your hands. To use it while edging a piece of timber you retract the guard back from the fence just enough to pass the timberand the end of the guard pushes the flat face of the timber against the fence. I find it very difficult to pass the timber under the guard so had the guard retracted 6" to allow the timber to pass, but of course this left 6" of the block uncovered. I much prefer the pork chop guard which immediately springs back into place when the timber is removed. For some strange reason over here in the UK the pork chop type is outlawed by the HSE and the euro guard is the only one we can buy. I do have a small Grizzly jointer that I normally use for planing (jointing) and this does have the pork chop guard. Unfortunately the tables on this have a problem at the moment so had to use the other machine which I normally only use for thicknessing.
mailee is offline
post #9 of 16 (permalink) Old 09-09-2011, 09:19 PM
Silly boy...(VBG)....I am glad you did not do any permanent damage......
Sydney, Australia
jw2170 is offline
post #10 of 16 (permalink) Old 09-09-2011, 10:47 PM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Been there, done that Alan, mine ended with a skin graft. It happens so fast, before the brain has time to stop it happening. Mine was eleven years ago and I'm only just starting to get feeling back in the finger tip.
Harry
harrysin is offline
Brush replacement in a craftsman router mjm355 New Member Introductions 2 07-29-2011 09:05 PM
Brush Replacment 5625 dwall174 Milwaukee 0 01-16-2011 10:03 PM
Oil based brush on amber poly and water based acrylic paint ? Duane867 The Finishing Touch 6 01-14-2010 05:56 PM
What a disaster, need help taa800 Table-mounted Routing 10 04-21-2009 08:59 AM
What's wrong with my brush? JDługosz The Finishing Touch 12 11-11-2007 01:18 AM
