Odd Safety Tip - Router Forums
post #1 of 15 (permalink) Old 08-01-2012, 06:29 PM Thread Starter
OPG3's Avatar
First Name: Otis
Default Odd Safety Tip
For more on this, you'll need to do research for specifics. I get an occasional e-newsletter from Highland Woodworking and a guy wrote this in there. . .
Avoid sparks around steel wool - especially the finer types - it is covered with a super light oil and can ignite easily.
OPG3
Tweak everything!
OPG3 is offline
post #2 of 15 (permalink) Old 08-01-2012, 07:56 PM
First Name: Doug
Send a message via Skype™ to vzbingo
Yes, it also works well for starting campfires in emergencies!
Creator of high grade sawdust and artistic glue spots
"Opportunity is missed by most people because it is dressed in overalls and looks like work." T. Edison
vzbingo is offline
post #3 of 15 (permalink) Old 08-02-2012, 03:14 AM
I did not know that.............
Sydney, Australia
jw2170 is offline
post #4 of 15 (permalink) Old 08-02-2012, 05:50 AM
japa62's Avatar
Started a camp fire with a grinder once (by design). Would've looked better with steel wool as tinder.
Under construction, always.
japa62 is offline
post #5 of 15 (permalink) Old 08-02-2012, 06:36 AM
Wildwood's Avatar
Country: South Africa
First Name: Rob
Otis - it has nothing to do with oil - the steel itself is highly susceptible to combustion when it is in a very fine form. Due to its fineness, individual strands will achieve red heat very easily, and with plenty of airspace between strands, combustion occurs.
I lost a whole roll of Liberon 0000 grade, when a spark from my grinder set it alight. They even warn you on the packing. Rob
Wildwood is offline
post #6 of 15 (permalink) Old 08-02-2012, 06:37 AM
First Name: Gene
I was not aware about steel wool. But I have seen titanium lighting up. Drilling it with power feed drill in the air craft industry. I was the operator and all of a sudden we had flames everywhere.
LiLRdWgn is offline
post #7 of 15 (permalink) Old 08-02-2012, 07:14 AM Thread Starter
OPG3's Avatar
First Name: Otis
Thanks everyone! Rob, you may be correct - I just restated "oil" from the article, but had never had the problem. It seemed like one of those "Wow! I didn't know that" kinda things. When speaking of this to a neighbor friend he said he actually starts campfires using fine steel wool and a 9 volt battery. I haven't seen this, but it does seem plausible.
OPG3
Tweak everything!
OPG3 is offline
post #8 of 15 (permalink) Old 08-02-2012, 07:30 AM
Talking
Starting a Fire With Steel Wool and 9V Battery - Urban - Suburban Survival - YouTube
Steel wool and 9 volt battery fire - YouTube
Sydney, Australia
jw2170 is offline
post #9 of 15 (permalink) Old 08-02-2012, 10:10 AM Thread Starter
OPG3's Avatar
First Name: Otis
James, Thanks for posting those YouTube links. It appears the stuff ignites easily and burns well, too. I had visualized the 9V battery taking a bit longer than that! The guy that had initially written the article that I read reported his actual inadvertant fire began as a result of grinder sparks landing in his container of steel wool. Sometimes sanding odd composites produce sparks, as well. I now know to keep my steel wool stored safely away from sparks or flames.
OPG3
Tweak everything!
OPG3 is offline
post #10 of 15 (permalink) Old 08-02-2012, 01:14 PM
First Name: Earl
One of the most impressive displays is using a lit cigarette stuffed in the end of an oxygen tube to light steel wool. Demonstrates the effect of introducing pure O2 to a small fire and the flammability of metal at the same time.
Aluminum shavings are pretty impressive too--but don't throw water on it once lit!!
greenacres2 is offline
Magnified Safety Glasses timbertailor Shop Safety 17 12-28-2012 09:01 AM
Safety Tip! Eagle America Shop Safety 1 06-18-2009 02:55 PM
Is workshop safety needed? Check twice! Shop Safety 18 07-12-2008 10:27 PM
Tip Rotator Mark Site Help and Suggestions 4 03-10-2008 10:22 AM
