J Phil Thien's Cyclone...? - Router Forums
post #1 of 23 (permalink) Old 02-02-2013, 08:02 AM Thread Starter
Nickp's Avatar
First Name: Nick
Default J Phil Thien's Cyclone...?
I read through the Dust Collection sticky and am convinced I need more than a shop vac (even with the little I do with wood). It seems a good "picker-uper" is necessary no matter what.
Does anybody on this forum have any experiences with his design...? I like the idea of a cyclone action in a collection vessel and have used something like this when I sand the bottom of my boat. My experiences are only with putting a 5-gal can in line with some water in it to capture the bottom paint dust before getting in the shop vac. This has worked but I can see Thien's design being better...or something like it...
Your thoughts, please...and thanks in advance...
Nick
Nickp is online now
post #2 of 23 (permalink) Old 02-03-2013, 07:38 AM
First Name: Art
I build one several years ago but only use it in conjunction with my Dewalt 735 planer. It works fine the only problem is that the dust comes out where the top meets the can. I have it held down with two bungee cords but the dust still comes out.
mgmine is offline
post #3 of 23 (permalink) Old 02-03-2013, 07:55 AM
OPG3's Avatar
First Name: Otis
Nick,
This is an often spoken of topic. Send a PM to "allthunbs" - he is extremely knowledgeable about dust collection. You can locate him quite easily, as he's at the alphabetical top of my "friends list". I am actually working on some designs for him here in my shop. The pulmonary long-term affects of breathing dust are atrocious.
OPG3
Tweak everything!
OPG3 is offline
post #4 of 23 (permalink) Old 05-17-2013, 10:37 AM
First Name: Frank
I just built a two stage dust collector using the Thien separator. I used a 2hp HF dust collector and a Wynn .5 micron filter. The strongest thing I can say is 'incredible'. I have a table saw, band saw, and planer that have 4" dust ports. I built the dust collector on wheels with a 10' hose. I just move it where I need it, hook up the hose and go to work.
The Thien separator is built under the lid of a 30 gallon galvanized garbage can. I have only a 1/4" foam weather seal strip attached under the lid, but no leakage. I have emptied the garbage can twice and still have no sawdust in the clear poly bag under the Wynn filter.
More importantly, no fine dust layer on anything in the shop.
OldGuy54 is offline
post #5 of 23 (permalink) Old 05-17-2013, 10:43 AM
First Name: Dave
Hi Frank Welcome to the forum. It sounds like a real nice setup you've put together.
adot45 is offline
post #6 of 23 (permalink) Old 05-17-2013, 02:58 PM
First Name: Larry
Do you have more information on how you built yours?
woodie26 is offline
post #7 of 23 (permalink) Old 05-17-2013, 09:10 PM
JudgeMike's Avatar
Nick
I built one a few months ago and posted some info about it with photos. I'm a woodworker rookie but got it done and it works very well. You can see what I did here.
http://www.routerforums.com/project-...separator.html
JudgeMike is offline
post #8 of 23 (permalink) Old 06-04-2013, 05:37 AM
allthunbs's Avatar
First Name: Ron
Default shop vacs
About a year ago I managed to pick up a Ridgid WD1450, 168 cfm shop vac. I put it on my LeeValley Tools cyclone lid and it worked a charm. However, at some point it was running too long and it got hot without my noticing and I burned out the armature. Just yesterday, I installed a brand new WD1450 on the cyclone lid and it wasn't long that I noticed that it too was getting too warm.
I'm using a plastic garbage pail under my cyclone lid and it deforms about an inch so the only thing I'm thinking is that vacuum cleaners of any type require a minimum airflow to cool them. If you're using a shopvac or equivalent, be cautious that it's not getting too hot.
If you're one of the engineers on this site, would you please add your thoughts. More to come...
Allthunbs
Allthunbs
allthunbs is offline
post #9 of 23 (permalink) Old 06-04-2013, 05:55 AM
Cassandra's Avatar
First Name: Cassandra
Hi Allthunbs:
I don't see why the set-up should cause problems. What size are the hoses leading from the tool (saw, router, drill press) to the separator? The set-up you described is not too unlike using an Oneida Dust Deputy. They're made to go on shop-vacs.
In my case (http://www.routerforums.com/tools-wo...tml#post128460), I used a large Rubbermaid bin as the base of my separator and have had no trouble with the system. I use a 590 CFM King dust collector on top, to do the sucking. Never has got overly warm.
Big difference between our systems is that a shop-vac is low-volume, high-pressure whereas a dust collector is high-volume, low-pressure.
Cassandra
Carpe diem, quam minimum credula postero
http://www.panoramio.com/user/5924351
Cassandra is offline
post #10 of 23 (permalink) Old 06-04-2013, 04:56 PM
allthunbs's Avatar
First Name: Ron
[QUOTE=Cassandra;337743]Hi Allthunbs:
The hose diameter to the tool is 2.5" and the length about 7'. The hose diameter from the vacuum to the cyclone lid is 2.5" and the length is about 4'.
I'm using the same bin. Does the sides of your bin flex when under suction?
At 168 CFM, I'm hoping that it will be more than just "low-volume". I can only assume that high volume low pressure would require 4" or larger hoses????
I need a bit of explanation pls.
Allthunbs
Allthunbs
Cyclone dust collectors TomB19 Tools and Woodworking 7 11-13-2012 08:15 PM
DIY cyclone experiment giltic General Routing 24 10-21-2011 12:19 PM
