How Does Soap Clean Hands? - Page 2 - Router Forums
 12Likes
post #11 of 18 (permalink) Old 07-01-2019, 08:39 AM
chessnut2's Avatar
Very interesting. Thanks!
chessnut2 is offline
post #12 of 18 (permalink) Old 07-01-2019, 09:40 AM
roxanne562001's Avatar
First Name: Roxanne
Welcome to the forum Jessica. I never thought of soap that way
roxanne562001 is offline
post #13 of 18 (permalink) Old 07-01-2019, 10:21 AM
CharleyL's Avatar
First Name: Charley
This is a post that originated in 2013. I doubt that the originator even frequents this website any more. An interesting post though.
When working in the printing industry, I found that using waterless hand cleaner was a great way to get printer's ink, oil, and grease stains out of my work clothes as well as my hands. A little bit worked into the stained areas before throwing the clothing into the wash, removed the offending material, usually in just one washing. Oil and water don't normally mix, but waterless hand cleaner is a water soluable kind of oil and it will mix with the ink and grease easily, then it will mix with the water, assisted by the laundry detergent. The result usually completely removes the stain in one washing, but stubborn stains might require a repeat of the process. Sweat stains also come out easily with this process. I frequently wear baseball type caps and my engineers caps when driving the train in my avatar, and when they get sweat stained and dirty I add a little waterless hand cleaner and a scrub brush to work it into the stained areas before washing them. I end up with nice clean hats this way. Nothing else that I've tried on sweat stains has ever worked this good.
Charley
TenGees and Herb Stoops like this.
Central North Carolina
CharleyL is offline
post #14 of 18 (permalink) Old 07-01-2019, 11:36 AM
Welcome Jessica. Interesting post. My understanding is that soap simply makes it hard for bacteria to stay attached to the surface of skin, so particles of all types are rinsed away.
On septic systems: A septic system only functions effectively only when it maintains the right balance of beneficial bacteria. This bacteria helps to break down solid waste, and prevents your septic system from backing up.
When you introduce certain chemicals into your septic system, the growth of good bacteria can be slowed, or the bacteria may even be completely eliminated. Less bacteria in your septic tanks means more odor, a slower system, more frequent pump outs, or even a costly and inconvenient repair.
Antibacterial soap is made to kill bacteria. This is great for cleaning, but terrible for your septic system. A septic system requires two types of bacteria to do its job: anaerobic bacteria, which doesn't require oxygen, and aerobic bacteria, which does require oxygen. Inside your septic tank, anaerobic bacteria is needed to break down solid waste, while aerobic bacteria in your system's leach field destroys harmful pathogens which can cause disease. Antibacterial soaps kills both types of bacteria.
Almost every homeowner uses antibacterial products. Besides antibacterial hand soap, septic system damaging antibacterial products include:
tile, sink, shower and tub cleaners;
toilet bowl cleaners;
laundry detergents;
drain cleaners;
counter-top cleaners, and
commercial and industrial cleaners.
Does this mean I have to sacrifice cleanliness to keep my septic system running?
No. In fact, the value of using antibacterial soap is highly disputed. The FDA states that antibacterial soap is not shown to be better at protecting against disease or infections than correctly washing with normal soap and hot water. In addition, there are multiple studies which conclude that the use of antibacterial soap may actually decrease the ability of user's immune system to fight off sickness, and may not be safe for long-term use. --https://www.septicsafe.com/blog/the-dangers-of-antibacterial-soap-in-a-septic-tank/
I have started using Dawn for hand and dish washing. This is what they use on animals after an oil spill. Since all soap makes skin too slippery for germs to get a grip it's basically as effective as the antibacterial stuff. Rinses off easily and doesn't kill bacteria in the septic system, gentle on skin...what's not to like?
We had "risers" installed for quick and easy access to the settling tanks, covered by artifical rocks. We get a discount on having it pumped since they don't have to dig. The real problem is with the paper products., which is why we pump regularly despite low flush toilets. Paper that gets into the deep tank will clog and fill it in fast.
post #15 of 18 (permalink) Old 07-01-2019, 03:22 PM
Country: South Africa
First Name: Biagio
@CharleyL , should you run out of waterless hand cleaner, a few drops of dishwashing liquid and a pinch or two of baking soda do a marvelous job of removing grease, paint and varnish from hands. Better than some of the commercial hand cleaners, which somehow do not get into fingerprint ridges, nail folds and hair follicles. Very light brush with a. Soft brush, and you will not believe the results. Don’t know about on clothing - have not tried.
@DRT, the FDA made the point, although the soap companies are still rabbiting on about killing 99% of germs. What some of the “antibacterial soaps” do, is to affect skin pH, etc, and lead to dry skin, or worse, dry eyes - there seems to be an epidemic of the latter. Then they try to counteract by adding oils, “moisturizers”, etc. I have never understood why one would want to wash to clean off oils and dirt, and in the process make things oily again. But I suppose several billion women can’t be wrong.
DesertRatTom likes this.
Biagio is offline
post #16 of 18 (permalink) Old 07-02-2019, 09:08 PM
Originally Posted by Biagio View Post
@CharleyL , ...But I suppose several billion women canít be wrong.
Oh no, it's always the man who's wrong. Just ask my wife.
CharleyL likes this.
post #17 of 18 (permalink) Old 07-04-2019, 02:33 AM
Any wife, Tom; any wife.
And on the remote chance that you are right, do not say "See, I told you so." Unless of course you enjoy sleeping under the stars.
DaninVan is offline
post #18 of 18 (permalink) Old 07-04-2019, 12:32 PM
The original post was correct. Soap is a somewhat long molecule that is water soluble on one end and oil soluble on the other end. Therefore able to dissolve in both.
True. For that reason I have a drain pit that my washing machine drains into that is separate from my septic tank. The chemicals from the washer are terrible for the septic tank, particularly chlorine bleach, so I only have my toilet, tub, and bathroom sink draining into it. Grey water with plain regular soap isn't that harmful to it. I haven't touched my septic system in the 35 years since I set it up.
laundry detergents;
drain cleaners;
No. In fact, the value of using antibacterial soap is highly disputed. The FDA states that antibacterial soap is not shown to be better at protecting against disease or infections than correctly washing with normal soap and hot water. In addition, there are multiple studies which conclude that the use of antibacterial soap may actually decrease the ability of user's immune system to fight off sickness, and may not be safe for long-term use. --https://www.septicsafe.com/blog/the-dangers-of-antibacterial-soap-in-a-septic-tank/[/I]
If you remember back about 25 to 30 years ago Phisohex was very popular. Then they discovered that regular use of it was harmful. It had side effects in some people such as skin irritation. Other possible side effects were suggested coupled with studies that showed anti bacterial soaps were no more effective at cleaning your hands: https://www.webmd.com/cold-and-flu/n...ntibacterial#1 Soap doesn't make your skin too slippery for germs to stick to, it dissolves the oil that they stick to. That coupled with friction of rubbing your hands together breaks them loose so that water can rinse them away. https://www.todayifoundout.com/index...e-getting-rid/
jw2170 likes this.
what do you use to clean bits? allthunbs General Routing 26 11-30-2017 01:48 PM
Clean your hand's! Tiny Shop Safety 8 11-14-2013 04:58 PM
Soap bowl finish? bobbotron The Finishing Touch 9 03-22-2012 02:35 PM
Top 10 Tools maintenance Plan!! Mike Dawson Tools and Woodworking 0 08-17-2010 06:12 AM
