Fire in the hole!!! - Router Forums
 4Likes
post #1 of 20 (permalink) Old 04-09-2015, 12:36 PM Thread Starter
First Name: Ron
Default Fire in the hole!!!
New experience today...
Hand routing a 3x6" cavity in nixie boxes (process posted elsewhere on the forum)...
Have done 100's of these without a hitch for several years, thx to help from Detroit Mike, Harry & Pat Warner's bases.
The cavity is routed in 3 - 1/4" deep passes with a 1/2" carbide spiral upcut bit using a DW618 w/vac attachment hosed to a dust deputy attached to a shop vac, which captures 95% of the dust and chips into the 5 gal bucket. Always been very efficient.
As I finished the last pass, I notice a smoldering wad of sawdust/chips in the corner of the cavity, not only smoldering but burning, as in fire!
Immediately dug it out, tossed on floor and stomped it out. checked the vac bucket, 3/4 full and no sign of fire...of course immediately dumped the bucket into a trash bag and tossed it outside.
Imagine, had the vac sucked up that small bit of burning embers into the bucket, could have spelled disaster if it had gone unnoticed, end of day, flame in bucket of sawdust, etc.
No clue the cause, the wood is hard (African teak, aka Iroko), the bit was reasonably sharp, perhaps a bit of hard mineral deposit in the wood causing a spark to ignite?
Going forward, the vac bucket will get emptied at the end of a days work, burning embers or not...and a couple of extra fire extinguishers are being added to the small shop.
Anyone else had a similar experience?
MT Stringer likes this.
rpludwig is offline
post #2 of 20 (permalink) Old 04-09-2015, 12:44 PM
Yikes! Close call, Ron.
I use my belt sander for both woodworking and metal (sharpening some blades etc.).
I'm paranoid about a spark getting into the fine sawdust still in the sander...I remove the dust bag for the metal use; hope that's going to be enough.
Now you've got me more worried.
DaninVan is online now
post #3 of 20 (permalink) Old 04-09-2015, 02:20 PM
I try to remember to go out to the shop an hour or two after I've finished for the day and see if I smell smoke. I figure if there is a problem I should be able to smell something by then. BTW, the table saw is also a prime contender for starting fires.
post #4 of 20 (permalink) Old 04-09-2015, 04:17 PM
They do make smoke detectors for dusty environments...
eg:
http://www.google.ca/url?sa=t&rct=j&...90491159,d.cGU
post #5 of 20 (permalink) Old 04-09-2015, 04:30 PM
First Name: Ray
Holy smoke!!! Close call Ron. Thank God you found it in time! Thank you for letting us all know. May it be a lesson vicariously learned.
Cheers!!!
Copyright©2015 A.D. (Anno Domini, Latin for "in the year of our Lord") e.g., historical FACT!
Life is a comedy for those who think, but a tragedy for those who feel.
Let your smile change the world. Don’t let the world change your smile.
RMIGHTY1 is offline
post #6 of 20 (permalink) Old 04-09-2015, 05:05 PM
Gaffboat's Avatar
First Name: Oliver
Wow, Ron, nothing like a little adrenaline rush to focus your attention! Glad you spotted it in time and were able to deal with it.
Gaffboat is offline
post #7 of 20 (permalink) Old 04-09-2015, 05:31 PM
Read the title and said to myself...
Now what are Dan and Rick up to...
Glad you caught the fire in time...
WHEW!!!
post #8 of 20 (permalink) Old 04-09-2015, 05:48 PM
Default Fire in the Hole!!!
"Now what are Dan and Rick up to..."
Beats me; I'm stumped.
post #9 of 20 (permalink) Old 04-09-2015, 06:05 PM
this is yours then...
and this one is Rick's...
post #10 of 20 (permalink) Old 04-09-2015, 06:59 PM
RainMan 2.0's Avatar
Geez Dan are these Americans ganging up on us ?
Ok ,I never insulate
RainMan 2.0 is online now
Hole Tolerance using a Hole Saw Kevin Witt New Member Introductions 11 07-17-2014 08:21 PM
How to make a circle (no center hole) myicq Jigs and Fixtures 15 10-17-2012 08:11 PM
Drilling large hole over small hole or vice-versa simplenik Tools and Woodworking 8 06-13-2007 07:57 PM
Routing a hole Learning Herb Tools and Woodworking 11 03-20-2006 04:29 PM
