Planing End Grain Cutting Boards on a Planer - Router Forums
 10Likes
  • 6 Post By Herb Stoops
  • 1 Post By Stick486
  • 1 Post By Cherryville Chuck
  • 1 Post By JFPNCM
  • 1 Post By JFPNCM
post #1 of 7 (permalink) Old 06-13-2015, 10:29 PM Thread Starter
Default Planing End Grain Cutting Boards on a Planer
I did a search on planing end grain cutting boards on a planer. There are equal amounts of folks doing it and against it.
I found a good video that shows the safe way to plane end grain cutting boards on a thickness planer.
This fellow has done thousands of them and stresses certain procedures to do it safely.
If you are going to use this technique,I recommend that you watch this U-Tube video and follow the safe techniques shown for your own safety.
It is 12 min long but worth saving your machine and yourself.
Don't Hurry and work patiently,
Herb Stoops is offline
post #2 of 7 (permalink) Old 06-13-2015, 10:47 PM
thanks Herb...
I won't be diagonally feeding any more..
Herb Stoops likes this.
Stick486 is offline
post #3 of 7 (permalink) Old 06-14-2015, 11:12 AM
Thanks herb. Lots of good tips there.
post #4 of 7 (permalink) Old 06-14-2015, 12:06 PM Thread Starter
And the other side of the story: End-grain Through the Planer? Bad Idea! - The Wood Whisperer!
Read the comments.
post #5 of 7 (permalink) Old 06-14-2015, 12:42 PM
JFPNCM's Avatar
First Name: Jon
Very interesting and informative video and comments on the Wood Whisperer site. Appreciate your presenting both sides of the story Herb.
What about using a drum sander instead?
Jon
JFPNCM is offline
post #6 of 7 (permalink) Old 06-14-2015, 12:50 PM Thread Starter
Yep, that is the way I do it.
To me planing end grain is like climb cutting on a router table and feeding boards into the table saw from the back. Yes you can do it, but ........
post #7 of 7 (permalink) Old 06-14-2015, 01:42 PM
JFPNCM's Avatar
First Name: Jon
Good to hear. I don't currently own one but neighbor does and we've used it successfully to prep the slabs made from my cut off bin that subsequently became boxes (see previous posts).
Because those slabs were glued up from the cut off bin they featured a combination of pieces oriented as to end, side and top grains as well as thicknesses. Once we had them uniform I then used a finish sander on the final pass.
Jon
JFPNCM is offline
Cutting boards for gifts.... gad5264 Project Plans and How To 16 08-17-2016 07:35 AM
Cutting Boards MT Stringer Show N' Tell 12 12-20-2014 04:17 PM
Glue in End Grain Box Joints Zurt Table-mounted Routing 4 01-29-2011 09:41 PM
Poly. Cutting Boards bobj3 Show N' Tell 4 08-17-2007 11:06 PM
Routing end grain Pop_pop1 Table-mounted Routing 8 09-22-2004 12:24 PM
