Safe or Not Safe - Page 7 - Router Forums
 39Likes
post #61 of 66 (permalink) Old 06-24-2016, 11:24 AM
Talking Noomi Popcorn For You, Matey!
I need to get out more...
https://www.amazon.ca/dp/B004R9Q2EI/...d_i=B006G89C0O
Probably cheaper S. of 49.
DaninVan is online now
post #62 of 66 (permalink) Old 06-24-2016, 11:47 AM
Originally Posted by DaninVan View Post
that is now on the BARD list...
post #63 of 66 (permalink) Old 03-22-2017, 02:02 AM
Kate396's Avatar
First Name: Kate
Safety reminders are always a good thing.
Kate396 is offline
post #64 of 66 (permalink) Old 03-22-2017, 03:22 PM
Just re-read this, some good information and a strong reminder to pay close attention. BTW, I did rearrange my shop so wood isn't falling on me anymore. Biggest problem is the stuff that winds up on the floor. Don't know how it keeps filling up with little junk just about as fast as I manage to clean it up. Not quite enough shelf space, and things get pushed off the edge of the workbench.
DesertRatTom is online now
post #65 of 66 (permalink) Old 05-19-2017, 07:16 AM
Originally Posted by Seldonman View Post
Thought I would share this Safety Message with you as it might help someone be a little more safe in the shop. This is basically a copy of the e-mail I sent my Father-in-Law, whom as you may recall gave me most of my wood working tools.
Well Monday was an overcast and cool (high 80's) day so I decided to go out into the shop and start her up for the season. As I started to do some work I stopped myself and said, "You know Jim, you have been meaning to upgrade your safety equipment and you have been putting it off." So off I went to Home depot and bought a new 3M half face mask industrial filter. I have been using your old one and it works fine but I can no longer buy new filters for it and the straps are getting old and worn. I also bought ear muff for hearing protection as I have been using ear plugs that you have to roll up. Then I bought a new pair of hard plastic eye protectors to replace your old soft plastic protector that was hard to see through along with a dust mask for sawing operations.
I know the eye protectors are a one hundred percent improvement because I went to put them on and could not find them; that's when I realized I was wearing them. Also, the ear muffs are quick and easy to put on and I really like them. So, after spending a good chunk of money was I safe? Unfortunately, the answer was no as I got what I think is my worst shop accident to-date, if you don't include the time I jammed the newly sharpened chisel into my thumb. You see, I was ripping and crossing cutting some wood on the table saw for about a half hour when all of sudden I was done and turned off the saw, cleaned up and put the saw back. Quick aside, I am getting very good at using the table saw and making precise cuts. Anyways, I put the saw away and cleaned up the shop when I decided to pull out my router table. No problem there, the table is on wheels and its unplugged. However, as I was pulling the table out into the middle of the garage I lightly brushed a 2 x 2 piece of 3/4 MDF leaning against the wall and it fell over. In the process of falling over a corner brushed my leg like a knife and left a 3 to 4 inch scrap; not a gash. But boy did that thing start to bleed so I went inside and cleaned it with rubbing alcohol and headed to the drug store for some spray on bandage. I had to go to two different store but finally found it and when I went home and applied it I nearly went through the ceiling! So I am fine but who would ever have thought I would get hurt moving the router table. I may have to start wearing long pants in the garage. And yes, I have moved that piece of MDF and other pieces of wood to a safer location! There is a good ending to the story in that I shared my story at a safety meeting at work and won two movie passes. However, I think I would have like not to have had this happen in the first place!
Thanks for sharing.
DuanePhillips is offline
post #66 of 66 (permalink) Old 05-19-2017, 01:32 PM
RainMan 2.0's Avatar
I have to clean my garage out , as it looks like a bomb went off . Can't be safe when your tripping over wood everywhere you step
The owner of WP here in town had his worse injury from arborite believe it or not .
He was rolling up a sheet for a customer , when it broke and slashed his hand open , requiring 17 stitches
Ok ,I never insulate
RainMan 2.0 is offline
Basement cabinet for gun safe DelDave61 New Member Introductions 60 11-26-2014 08:41 PM
Is it safe to "back route"? thumb_trimmer General Routing 6 10-06-2013 12:08 PM
Post #1 from new member - be safe sache New Member Introductions 4 02-22-2012 09:00 AM
A safe router table Mike Shop Safety 6 07-19-2009 11:40 PM
Safe Speed of 1 5/8" dia. bit...? Joe Lyddon Router Bits - Types and Usage 2 10-02-2006 10:17 AM
