Weekend Project: Custom Pistol Grips - Router Forums
 17Likes
post #1 of 14 (permalink) Old 09-06-2016, 08:55 AM Thread Starter
richjh's Avatar
First Name: Rich
Default Weekend Project: Custom Pistol Grips
Besides woodworking, I shoot in a .22 pistol league at the local range. I had been searching for some target grips for my Ruger 22/45 Lite and was coming up short. I didn't like the few I found and they were also expensive so I decided to make my own.
I found some scrap wood I reclaimed from an old dresser I took apart. I don't know what species it is but I liked the grain pattern. I used the original grip panels as a template and did the rough cuts using my bandsaw and Japanese hand saw. I then did some rough carving using a rounded rasp bit in the drill press. I then sanded it to final dimension with the belt/disc sander and smoothed everything out by hand sanding to 220 grit. I finished it with some Pecan stain and some wiped on Poly.
It took me about 3 hours to make this first set. I may try making another set from a more exotic wood.
OPG3, chessnut2, DaninVan and 13 others like this.
Basically, a tool is an object that enables you take advantage of the laws of physics and mechanics in such a way that you can seriously injure yourself - Dave Barry
richjh is offline
post #2 of 14 (permalink) Old 09-06-2016, 09:28 AM
First Name: lee
Nice grips. Interesting barrel. Does it slide?
OPG3 likes this.
coxhaus is online now
post #3 of 14 (permalink) Old 09-06-2016, 10:29 AM
OPG3's Avatar
First Name: Otis
Hey Rich,
Those grips look really cool! I think they are pretty unique. Tedious work for certain and exacting work!
OPG3
Tweak everything!
OPG3 is offline
post #4 of 14 (permalink) Old 09-06-2016, 10:33 AM
RainMan 2.0's Avatar
Way cool !
Ok ,I never insulate
RainMan 2.0 is online now
post #5 of 14 (permalink) Old 09-06-2016, 10:59 AM
First Name: Ken
Very nice.
What wood are you thinking you'd like to use when you make another set?
kklowell is offline
post #6 of 14 (permalink) Old 09-06-2016, 12:56 PM Thread Starter
richjh's Avatar
First Name: Rich
The barrel is fixed. It is bolt operated so only the bolt slides back and forth.
richjh is offline
post #7 of 14 (permalink) Old 09-06-2016, 12:59 PM Thread Starter
richjh's Avatar
First Name: Rich
Originally Posted by kklowell View Post
Very nice.
I would like to try walnut next because it's easy to source locally at the hardwood lumber store near me. I am hoping I can find some Ebony wood to better match the color of the pistol. I also have plenty of 4/4 red oak on hand to practice with.
richjh is offline
post #8 of 14 (permalink) Old 09-06-2016, 04:39 PM
JOAT's Avatar
First Name: Theo
Nice work. You saved tons of $ over buying a pair.
Many moons ago I wanted to make a set of grips for a Colt house gun, revolver. Approached it a different way tho, seems I so often do. Found a can of wood filler my dad had bought. This stuff was fantastic - dried almost white, looked like solid plastic almost when dried, sanded nicely, and if you added some, it adhered like it had been part of the original batch, couldn't even see a seam. Anyway, after a lot of trial and error, and work, got a set that fit my hand perfectly, and didn't even really need the sights, just point my hand at a target, and it was dead on. Totally and completely customized for me personally.
I later traded that gun off, which I have since heartily regretted. And, can't remember the name/brand of woodfiller, and never been able to find any even close to that stuff.
JOAT is offline
post #9 of 14 (permalink) Old 09-06-2016, 05:44 PM
hawkeye10's Avatar
First Name: Don
Great job Rich. The pistol looks like a custom Ruger or a clone. You should show that off on Rim Fire Central if you haven't already. Those guys would flip out.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #10 of 14 (permalink) Old 09-06-2016, 07:32 PM
What a great job. Love to see stuff like this. I'll look forward to seeing the next version.
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 09:33 AM
