Heavy Lifter - Router Forums
 18Likes
post #1 of 21 (permalink) Old 09-29-2016, 10:46 AM Thread Starter
Default Heavy Lifter
New release in limited edition series.
John Labaj is proud to announce the release of limited edition series of the model of "Heavy Lifter" Construction Crane.
There are six production items in the series, individually numbered with unique Serial Number. Each collector’s item comes with Certificate of Authenticity.
The model crane is constructed predominantly from wood, with some metal parts required by the method of construction.
Approximate physical size of the model is:
300 mm wide x 400 mm long x 300 mm high.
The boom is 960 mm long and elevates from 0 to 80 degrees (effective elevation). The "Heavy Lifter" have two hooks and the maximum reach of each hook is 900 mm at full elevation.
Crane rotates on the turntable to full 360 degrees.
JFPNCM, me5269, vzbingo and 10 others like this.
Holic46 is offline
post #2 of 21 (permalink) Old 09-29-2016, 11:00 AM
Truly a work of art ................. and it only won 3rd place?
kp91 likes this.
tomp913 is offline
post #3 of 21 (permalink) Old 09-29-2016, 11:17 AM
absolutely awesome..
post #4 of 21 (permalink) Old 09-29-2016, 11:27 AM
old coasty's Avatar
First Name: Bob
Man that is super
old coasty is offline
post #5 of 21 (permalink) Old 09-29-2016, 11:32 AM
Terrific construction. Congratulations on the prize.
post #6 of 21 (permalink) Old 09-29-2016, 01:33 PM
RainMan 2.0's Avatar
Incredible craftsmanship , should have gotten first prize . How the heck do you out do your build ?
Ok ,I never insulate
RainMan 2.0 is online now
post #7 of 21 (permalink) Old 09-29-2016, 03:13 PM
First Name: Doug
Send a message via Skype™ to vzbingo
Very impressive! Between the treads, access steps and the lifting arm, I think I would have lost 2 fingers and gone blind!! How long did it take you to build it?
Creator of high grade sawdust and artistic glue spots
"Opportunity is missed by most people because it is dressed in overalls and looks like work." T. Edison
vzbingo is offline
post #8 of 21 (permalink) Old 09-29-2016, 04:38 PM Thread Starter
All my models are produced in limited edition series of 6 items in series. If I was to make only one, it would take about two months, 6 items takes me about 3 months because preparation of templates and tooling is most time-consuming phase in the process.
Holic46 is offline
post #9 of 21 (permalink) Old 09-29-2016, 05:31 PM
JOAT's Avatar
First Name: Theo
Very slick. How much does one of those go for?
JOAT is online now
post #10 of 21 (permalink) Old 09-29-2016, 05:33 PM
hawkeye10's Avatar
First Name: Don
John that is beautiful. Wow!!!
Don in Murfreesboro,Tn.
hawkeye10 is offline
How to move HEAVY glass doors? Roloff DIY and Renovation 17 08-10-2013 07:19 PM
How to install a Makita 3612 C with a lifter and a Base Plate Julián Maldonado Table-mounted Routing 1 05-20-2013 07:43 AM
3 in 1 Heavy duty Tablesaw, Router Table, Drum Sander hubert_gut Tools and Woodworking 1 03-04-2012 08:47 AM
Heavy duty foot stool vikingcraftsman Show N' Tell 8 08-31-2009 12:45 PM
