Workbench Extension - Router Forums
 16Likes
  • 9 Post By MT Stringer
  • 2 Post By RainMan 2.0
  • 1 Post By JFPNCM
  • 1 Post By MT Stringer
  • 1 Post By tacomamactech
  • 2 Post By honesttjohn
post #1 of 9 (permalink) Old 10-30-2016, 10:37 PM Thread Starter
MT Stringer's Avatar
Default Workbench Extension
I decided to add an extension to my work bench. In short order, I will be ripping some poplar and plywood to build some cabinets so I am cleaning up and getting organized.
First things first. I removed the woodworking vise from the end of the table. I don't use it very often so it was an easy decision to remove it.
I already had a piece of melamine that I had previously mounted on the rear of my bench. Well, it was in the way.
So, I cut it down and remounted it to the end of my table using the same collapsible hinges as before. I had some melamine edge banding so I made it look like a factory piece!
The table top extends over the bench by 2 inches all around so I had to cobble up a spacer. I added a couple of 2x4 filler blocks to even out the bench framework. Then, a piece of leftover solid core door off cut was added...and a couple of pieces of 1/4 inch plywood. That worked great. After mounting the hinges, I clamped the extension to a couple of pieces of wood that was clamped to the table. The extension turned out level with the table top.
Now I have almost 66 inches x 30 of work surface. That should fix me up with any upcoming projects.
Here are a few pics.
Name:	2016-10-29 19.48.38.jpg
Name:	2016-10-29 19.48.28.jpg
Name:	2016-10-28 20.19.40.jpg
Name:	2016-10-28 20.44.40.jpg
Name:	2016-10-28 20.54.59.jpg
Name:	2016-10-28 21.02.36.jpg
Name:	2016-10-29 17.55.22.jpg
Name:	2016-10-29 19.19.02.jpg
fire65, RickPr, Danman1957 and 6 others like this.
MT Stringer is online now
post #2 of 9 (permalink) Old 10-30-2016, 10:41 PM
RainMan 2.0's Avatar
Nice addition Mike . You can never have too big of a work bench IMO
MT Stringer and jj777746 like this.
Ok ,I never insulate
RainMan 2.0 is online now
post #3 of 9 (permalink) Old 10-31-2016, 09:42 AM
JFPNCM's Avatar
First Name: Jon
@MT Stringer
Mike, how useful do you find those T-tracks? I've been thinking about adding some to mine but I need to bore the dog holes first. Also curious as to the spacing on the latter.
MT Stringer likes this.
Jon
JFPNCM is online now
post #4 of 9 (permalink) Old 10-31-2016, 02:18 PM Thread Starter
Originally Posted by JFPNCM View Post
@MT Stringer
@Jon - I use those tracks all the time, especially when building face frame cabinets. (Got 16 to build starting tomorrow!)
The dog holes are 7/8 inch in diameter. In my next lifetime, I will go with the 3/4 inch dia. But, 1/2 inch pipe will fit through it so I can have a vertical clamp if needed. I would much rather have more clamping ability so I am going to have a friend modify several of my clamps so they will fit the way the Festool clamps do.
The dog holes are 6 inches apart. And they are drilled close to a 6 inch pattern but not exact like a CNC machined top would be. I've seen some neat set ups that folks do using the Festool Multifunction Table. Too expensive for me.
Note: The Kreg Klamp Track is through bolted (not screwed) to the frame so keep that in mind. Two rows of 1/4 inch bolts every 4-6 inches apart secure the track to the table.
If I could raise the table top up enough, I would take a picture for ya, but it is a solid core door and heavy!
Hope this helps.
honesttjohn likes this.
post #5 of 9 (permalink) Old 10-31-2016, 07:29 PM
First Name: Joe
Get some plugs for your receptacle box. Somebody's kid puts a finger in there they'll get fried and your goose will be cooked!
tacomamactech is offline
post #6 of 9 (permalink) Old 10-31-2016, 08:38 PM
Been there done that . When I was a youngster I decided to see what would happen when you shove a paper clip across the terminals .
A flame spew out and a ran as fast as I could , and the draft I created caused the flame to chase me for the first yard or so .
Didn't do it twice lol
post #7 of 9 (permalink) Old 10-31-2016, 09:08 PM Thread Starter
I meant to do that. but forgot. Thanks for reminding me.
post #8 of 9 (permalink) Old 10-31-2016, 10:49 PM
Yah, Mike. You want to keep Blondie around.
HJ
MT Stringer and RainMan 2.0 like this.
honesttjohn is offline
post #9 of 9 (permalink) Old 11-01-2016, 02:00 AM
JFPNCM's Avatar
First Name: Jon
@MT Stringer
Mike: Appreciate the details and understand the heft of the table. I was thinking along the line of T-tracks vs the Kregs but it is easy to see the difference.
Cheers
Jon
Jon
Cast Iron Router Table Extension TRN_Diesel Show N' Tell 11 03-09-2014 10:51 AM
Bench Dog extension modification larrywilson Table-mounted Routing 3 05-06-2013 09:22 PM
Workbench - router table : connection dilemma. matt1710 Table-mounted Routing 22 12-26-2010 03:54 PM
Router Table Extension - Attachment and Alignment GarethR Table-mounted Routing 1 11-20-2009 01:47 AM
MLCS Router Bit Extension dimensions cadcraig Starting Off 4 08-27-2008 02:33 AM
