Super easy way to make a small drive belt (or O-ring) - Router Forums
 15Likes
  • 12 Post By Gaffboat
  • 1 Post By kp91
  • 1 Post By tomp913
  • 1 Post By firstmuller
post #1 of 9 (permalink) Old 11-01-2016, 02:11 PM Thread Starter
Gaffboat's Avatar
First Name: Oliver
Default Super easy way to make a small drive belt (or O-ring)
In a recent post about making pulleys I mentioned that I was going to make a drive belt for them and said I would show you how I do that. This technique could also be used to make an emergency O-ring of any size.
For my drive belt I used 2mm O-ring cord that I stretched between my pulleys and marked the spot to cut. Cutting was done with an exacto knife but a razor blade or utility knife would work as well.
Now, here’s the easy but surprising part: a tiny drop of superglue is applied to one end of the cord and then the other end is pressed against it for about a minute. When the glue has set you have a drive belt and/or O-ring.
I made a small test ring first and when it worked I moved on to my longer belt. The small belt is about 1 3/4” when measured between the two legs of a caliper. I was able to stretch it to over 2 3/8” without the join giving way.
[Sorry the close-up photo is the join is so blurry, I couldn’t get my phone to focus on it.]
There is enough stretch in the belt to give me the tension I need to drive the pulleys and it’s easy to make another if needed. Maybe you’ll find this technique helpful someday. The O-ring cord came from … (where else?) … Amazon.
Name:	1 O-ring cord.JPG
Name:	2 Drive belt.JPG
Name:	4 Lg and Sm belts.JPG
Name:	5 Joint test.JPG
paduke, OPG3, chessnut2 and 9 others like this.
Gaffboat is online now
post #2 of 9 (permalink) Old 11-01-2016, 02:27 PM
kp91's Avatar
First Name: Doug
I've used that method for making 'static' O-Rings, but never trusted them in moving applications. It's good to know that they're tougher than they look!
Can't wait to see the final project
OPG3 likes this.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #3 of 9 (permalink) Old 11-01-2016, 02:41 PM
If you're planning on making a lot of them, a jig like this comes in handy and gives good results - they have fancier - i.e. more expensive - ones but this will give satisfactory results.
https://www.zoro.com/value-brand-spl...Q&gclsrc=aw.ds
Gaffboat likes this.
tomp913 is offline
post #4 of 9 (permalink) Old 11-01-2016, 04:41 PM
Thanks for that Oliver. I always thought it had to a solvent based glue. Good to know.
post #5 of 9 (permalink) Old 11-02-2016, 10:32 AM
TenGees's Avatar
First Name: Paul
Very interesting but I wonder how that would withstand weather and UV from the sun???
TenGees is offline
post #6 of 9 (permalink) Old 11-09-2016, 01:52 PM
First Name: Allen
Thanks for this info. I may be able to use in on some of my wife's sewing machines.
Allen
Herb Stoops likes this.
firstmuller is offline
post #7 of 9 (permalink) Old 11-09-2016, 02:15 PM
That is good to know,wish I would have found out about it a few years ago when I needed it. Thanks for this post.
Herb Stoops is online now
post #8 of 9 (permalink) Old 12-14-2016, 01:08 PM
papasombre's Avatar
Country: Venezuela
First Name: Alexis
Hi, guys.
I use to use this trick when the "transmission belt" of my lathe is broken. See pictures 7, 8 and 9 here
http://www.routerforums.com/jigs-fix...tml#post384093
We, woodworkers are everywhere!!!
papasombre is offline
post #9 of 9 (permalink) Old 12-18-2016, 06:57 PM
ajmexico's Avatar
Great trick! Thanks. It's worth knowing just the simple fact that O-rings and drive belts of the same size can be interchangeable.
ajmexico is offline
The right tools make it easy harrysin Tools and Woodworking 15 01-22-2010 06:45 AM
Is it easy to make Mortises? kolias Tools and Woodworking 13 03-21-2009 05:46 PM
Simple way to make small mouldings. derek willis Jigs and Fixtures 58 03-02-2009 10:16 AM
Raised Panels Quick and Easy bobj3 Jigs and Fixtures 2 06-03-2006 12:56 PM
