Clamp Mods! - Router Forums
 54Likes
post #1 of 29 (permalink) Old 12-15-2016, 05:18 PM Thread Starter
MT Stringer's Avatar
Default Clamp Mods!
Why buy expensive clamps when you have a buddy with a welding machine!
After seeing videos on how to modify the cheap clamps instead of buying the Fe$tool style clamps, I came up with a brand new plan.
I wanted to modify the clamps to fit 3/4 inch dog holes on my bench so I called up a buddy and asked if he could help me. He said yes! That was back when it was hot (mid 90's) so we waited...
Today he called and said come on over, so off I went.
I explained what I wanted and we got after it. He has a metal cut off saw so I cut the 5/16 inch rod to length and he did the welding.
Then it was time to do the fitting. I already knew they wouldn't fit so I explained my idea was to grind a radius on the back side of the bar so it would roll under the table.
Instead, Willie used the cut off saw to cut away most of the excess metal that was in the way, and then it was time to fire up the grinder and finish the job.
Yay! All four will fit nicely through a 3/4 inch hole and clamp the work piece with no problem.
Note: A couple of the clamps belonged to my dad so they are the real deal - Craftsman, circa 1960's - 70's. I will get a lot of use out of them.
And the HF clamps, yeah, under $5 for the 12 inch models. I told Willie I might be back with another handful.
I am a happy camper.
Name:	2016-12-15 16.38.59.jpg
Name:	2016-12-15 16.41.08.jpg
Name:	2016-12-15 16.40.35.jpg
kp91, JFPNCM, Jack Wilson and 18 others like this.
MT Stringer is online now
post #2 of 29 (permalink) Old 12-15-2016, 06:55 PM
First Name: Richard
Great idea, Mike. I've thought of doing something similar. Those wii come in real handy.
MT Stringer likes this.
Shop guy is offline
post #3 of 29 (permalink) Old 12-15-2016, 07:02 PM Thread Starter
Yes sir. Especially since I am fixin' to rebuild my work table. It will be a Ron Paulk hybrid...Mikey Style!
post #4 of 29 (permalink) Old 12-15-2016, 08:22 PM
First Name: Richard
Building to suit oneself is the best way. I'm sure it will be great. Don't forget pictures.
Shop guy is offline
post #5 of 29 (permalink) Old 12-15-2016, 11:52 PM
old55's Avatar
First Name: Ross
Agree with Richard Should be a great WIP.
Ross,
old55 is offline
post #6 of 29 (permalink) Old 12-16-2016, 06:44 AM
First Name: Steve
Your not a happy camper, you're a happy CLAMPER! Nice work. A great addition to the workbench. An ingenious way to use the cheaper HF clamps.
kp91, OPG3, MT Stringer and 1 others like this.
Knot2square is offline
post #7 of 29 (permalink) Old 12-16-2016, 01:49 PM
TenGees's Avatar
First Name: Paul
Those look very handy, Mike.
TenGees is offline
post #8 of 29 (permalink) Old 12-24-2016, 11:23 PM
Everend's Avatar
First Name: Everend
I'm going to try this! I don't have much experience with welding, any advise about welding on the bar? Anything special about the clamp metal (ie tempering?)
Everend is offline
post #9 of 29 (permalink) Old 12-25-2016, 12:41 PM Thread Starter
I can't help with the welding. I cut the 5/16 inch rod and Willie welded it to the clamp bar. Nothing special that I know of.
If you screw it up, grind it off and do it again!
I can already see I want some more of these in the 6 inch length. I have about a dozen of them so it won't hurt too bad to modify four more.
post #10 of 29 (permalink) Old 12-25-2016, 02:46 PM
If both parts are mild steel, just pre-heat to take the chill of and drive off any moisture. Use a mild steel rod, cool in still air after welding.
tomp913 is offline
sanding blocks PhilBa Project Plans and How To 20 08-25-2015 07:26 PM
Handscrew Clamp Mods MT Stringer Jigs and Fixtures 21 06-07-2015 07:21 PM
Rolling Clamp Rack todd628 Show N' Tell 11 04-25-2015 06:31 PM
Woodpecker's Aluminium Box Clamp Review timbertailor Jigs and Fixtures 12 10-11-2014 10:09 PM
Kelly's New Router Jig Dejure Jigs and Fixtures 1 01-19-2014 12:09 AM
