Shop Shuffle - Router Forums
 7Likes
post #1 of 18 (permalink) Old 12-20-2016, 08:04 PM Thread Starter
Default Shop Shuffle
Got busy in the shop yesterday, rearranging things, tossing out open base stand, moving the DC out of the way. Still more to go but this pix shows the progress.
All tools are now on cabinet stands with doors and on casters. This is so I can get under and around them to suck up the sawdust that hides behind the stands. The doors really help keeping the dust out of hiding places.
There is still more to do, including using the open space at the end of the shop to store flat goods. In the picture, that is the whole back wall. Starting from the left, the new Rikon 10 inch band saw, then the sander on a stand with all sanding material on it, then the Bosch 10 inch sliding miter, surrounded by a shower curtain to contain and collect sawdust into a box connected to the DC unit. Next is the HF 2hp DC unit, connected to a chip collector drum. The back wall, particularly up high, holds wide shelves for my various jigs and not so often used tools.
Behind the table saw there is a space sufficient to store flat goods. I will be setting up a slanted, flat backed stand to help keep this material flat. At present, they stand vertically, clampped together to help keep them flat, and blocking access to a long work bench and materials storage area with bins. Getting the flat goods out of there will open up the whole end of the shop. At some point, I will be enclosing the space under this bench to keep the sawdust out of there, which is impossible now.
Just to the right of the table saw is my router table, and out of sight, at the bottom of the picture is my workbench, which has a fold down back half for assembling larger items.
You get an idea of how bright the shop is now with all the LED lighting installed during 2016.
My other project in the works is a solar heater that will be mounted on the roof that will recirculate the air in the shop through a tube in a glass covered flat black box. I hope this will make the shop livable without running up the heating bill. It will have about 30 feet of 4 inch aluminum flex piping, painted black, with a small fan at the end to blow heated air into the shop through an insulated tube. The intake will come from the shop, probably from about waist height, through a filter of course, to reheat the same air. It will be a closed system with one way flap valves to keep hot summer air out. I will likely put a reflective cover on top during summer since this is a cold weather solution. If we had snow, I'd figure out a way to knock it off--that's for @RainMan 2.0 . He might be able to use this by insulating the box with foam on the bottom and sides. Winter sun will still heat the air enough to make this work, but I'd make it much larger. Attached are a couple of pictures of solar heaters. Mine will be more like the second picture.
The best thing about rearranging the shop and tools is the increase in open space so I can move without impaling myself on some protruding tool.
vzbingo likes this.
post #2 of 18 (permalink) Old 12-20-2016, 08:17 PM
RainMan 2.0's Avatar
Tom I'm liking that black tubing your using to collect the heat . I've googled this subject a lot , as the 26' side of my garage that is facing south is unobstructed . So this would be an ideal area for a collector . Thinking 4'-8' would be a good starting point seeing as plexi sheets ,styrofoam and plywood come in that size already .
My thought was closer to vertical, so that there's no issues with snow collection . Was going to mount it 3' off the ground so it's accessible .
Not sure if I'll build one , but it's tempting . I am going to use a 240 V heater to heat the garage , so a solar heater may reduce the bill enough to justify.
Seen tests using black screen , black ABS , to just having the inside painted black . I was shocked when the screen mesh won (Not by much but a few degrees ).
My thoughts were to use a solar cell to run a computer fan to help with circulating the air , although some systems work with plain old vectoring.
Will be interested to see how your system turns out
Ok ,I never insulate
RainMan 2.0 is offline
post #3 of 18 (permalink) Old 12-20-2016, 08:24 PM Thread Starter
BTW @RainMan 2.0 , sorry about mentioning the I word, but I couldn't avoid it. Beside, I think this might really help your heating situation. Just increase the size of the unit, or add a couple of them. It will cost about $120-$140 or so (US) in materials. Exterior ply, paint tubing, an inline fan if you want to fancy it up a bit and the one-way valves at a hardware store. Some sort of mounting brackets. Have it tilt toward the South since late fall, winter, early spring is when you'll likely be using it. Even if it doesn't really make the shop warm, it will at least assist the heater, giving you at least a few hours of shop time. Recirculating the air will help as well, just add a filter box to the intake port. I'm going to put the inline fan indoors so I don't even have to worry about wiring. I'll unplug it when not in use. Hope this post helps all my cold weather friends.
post #4 of 18 (permalink) Old 12-20-2016, 08:30 PM
First Name: Ken
I like that solar collector too, but where my garage sits it doesn't get much sun.That's great in the summer, but doesn't help much this time of year.
kklowell is offline
post #5 of 18 (permalink) Old 12-20-2016, 08:40 PM Thread Starter
@Rainman 2.0, I wish I had a clear southern exposure on the shop wall, but at least I don't have snow to worry about. Interested in your black screen comment. Where did you find that info?
post #6 of 18 (permalink) Old 12-20-2016, 08:42 PM Thread Starter
Mount it on the roof? Tilt it south. Even if you only get 10 or 12 degrees improvement, it would cut your bill a lot during the day.
post #7 of 18 (permalink) Old 12-20-2016, 08:59 PM
Price wise Tom , seeing as I'm Canada it will closer to triple when the smoke clears I'm sure . I'm not doubting around the $1000 mark .
Just price that pink foam board and 1/4" plexi out north of the border, and that a major dent already , and that's not even tsing into consideration the BB and solar cell and other misc stuff.
Here's the link . I'll have to re read it again to confirm I'm remembering this right .
Comparing Solar Air Heater Designs & Performance ? Stonehaven Life
post #8 of 18 (permalink) Old 12-20-2016, 10:43 PM Thread Starter
Double Screen Type: From somparing solar air heaters.
screen type solar air heater section - stonehavenlife The screen collector is another common type that’s frequently used and it’s the easiest and least expensive to build.The black mesh screen provides lots of contact surface for transferring heat to the moving air, while adding very little resistance to the air flow. In most instances, the screen is tilted within the box so the screen is closer to the glazing at the top of the unit. A layer of black window screen can be stapled to each side of a wooden frame and mounted within the box.
In the tests that Gary and Scott ran there seemed to be no appreciable difference in performance between metal and fibreglass window screen material. As with all solar heaters, try to keep as much air as possible away from the glazing to reduce heat loss.
The double layer black screen is apparently what transfers the heat into the air. But you'd definitely want to have a filter over the intake to prevent dust from collecting and blocking the screen. You'd also want to make it easy to remove the glass cover to clean the screen.
post #9 of 18 (permalink) Old 12-20-2016, 10:52 PM Thread Starter
I have the double glass assembly from an old sliding double door that is about 36x76 inches that could be used for the cover. That would determine the size. Maybe hinge the thing in some way to make it easy to lift off for cleaning. Maybe just taping it in place to seal it in place would be enough, using aluminum duct tape. Cut through it to lift the glass. I like the simplicity of this, and the tests showed the design was efficient.
post #10 of 18 (permalink) Old 12-20-2016, 11:01 PM
JOAT's Avatar
First Name: Theo
Years back I had a ton of info on solar heating. Not sure, but I think a solar heater would be more efficient on a wall, rather than the roof, if you can. The theory is, you send out the cool air at floor level, and as it heats it rises, and is expelled into the shop. Don't even need a fan for it, if you just have straight airflow.
Gather the villagers, pitchforks, torches; we march at dusk!
JOAT is offline
Many questions for new shop and hopefully the right place to post bclarknc Tools and Woodworking 24 07-13-2016 06:08 PM
Almost Finished My Wood Shop stan2602 Workshop Showroom 6 08-31-2013 12:21 PM
New shop...where to put router...need two tables? Froglips New Member Introductions 1 06-12-2012 01:59 AM
Shop Organization Marco Tools and Woodworking 8 10-07-2011 07:57 AM
Old timer upgrading shop jbertelson New Member Introductions 5 09-26-2009 04:19 PM
