Modified bench top saw horses - Router Forums
 17Likes
  • 17 Post By Gaffboat
post #1 of 6 (permalink) Old 01-04-2017, 04:51 PM Thread Starter
Gaffboat's Avatar
First Name: Oliver
Default Modified bench top saw horses
About two years ago I made a pair of bench top saw horses out of some scrap plywood and they work well when I need to raise my work off the bench. However, they often require clamping in place to keep them from sliding around and then I have to clamp my work to the top of the horses.
Recently I saw where Woodsmith made some bench hooks out of 2 x 4s and the way they worked looked interesting so I used that concept to modify my bench top horses.
The modification is simply adding a removable hook to one end of the horse and a hole for a bench dog in the top of the opposite end. I made my hooks out of 1 x 2 poplar with two holes drilled in the face: one for a 1/4” bolt and one for a 1/4” dowel. The bolt attaches the hook to the horse and the dowel keeps it vertical and prevents it from turning. I’ll probably add a knob to the bolts for convenience. The end of the horse riser has a threaded insert for the bolt and a shallow hole for the alignment dowel. I’m able to leave the hooks attached when I store the bench top horses so I won’t misplace them.
Maybe you can adapt the concept to suit your bench top needs.
Name:	1 Modifed Horse.jpg
Name:	3 Horse end.JPG
Name:	4 Horse parts.JPG
Name:	5 In use.JPG
Gaffboat is offline
post #2 of 6 (permalink) Old 01-04-2017, 05:25 PM
hawkeye10's Avatar
First Name: Don
Very nice idea Oliver. It's nice to have someone like you to help the less fortunate out. ""Like me""
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #3 of 6 (permalink) Old 01-04-2017, 08:13 PM
old55's Avatar
First Name: Ross
Good one Oliver.
Ross,
old55 is online now
post #4 of 6 (permalink) Old 01-05-2017, 12:09 PM
whimsofchaz's Avatar
First Name: Chuck
Nice Oliver I think I may make one like it. Thanks for sharing
whimsofchaz is offline
post #5 of 6 (permalink) Old 01-05-2017, 04:04 PM
First Name: Roy
Thanks, Oliver. That'll work.
Roy Drake is offline
post #6 of 6 (permalink) Old 01-05-2017, 04:25 PM
P.A. Gosselin's Avatar
First Name: Pierre
Simply brilliant or is it brilliantly simple. Leonardo would be proud!
No day has been worth living unless I learn something new, no matter the source.
P.A. Gosselin is offline
Rochler table top or Bench Dog? jnahman Table-mounted Routing 10 10-02-2012 12:57 PM
Bench top router table stand dezzrtrider Show N' Tell 9 12-30-2011 08:57 PM
Bench Dog BenchTop vs. The Super Bench, Bench Top Router Table emergencyshutdown Table-mounted Routing 8 11-14-2011 01:58 AM
Bench Dog 40-016 ProLift Max Dejure Tool Reviews 1 08-04-2009 04:26 AM
