CNC Cut Portable Wortable - Page 2 - Router Forums
 46Likes
post #11 of 63 (permalink) Old 01-31-2017, 10:05 PM
RainMan 2.0's Avatar
Originally Posted by MT Stringer View Post
OK, So I got to thinking...what am I going to use to protect the surface of these mdf tops?
I heard water base poly was a no-no.
What about lacquer sprayed on the surface?
Shellac?
What I want to do is protect the surface from glue and paint or stain messing it up, if that is possible.
Glue on Arborite , then drill out the holes and route them out flush again ?
I know , I always overthink things
currently washed up
RainMan 2.0 is offline
post #12 of 63 (permalink) Old 01-31-2017, 10:58 PM
Mike,
A couple coats of either shellac or laquer should do it. MDF already comes with a coating on it.
MT Stringer likes this.
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is online now
post #13 of 63 (permalink) Old 01-31-2017, 11:56 PM
roofner's Avatar
First Name: Gary
Mike your tops are made of 3/4 mdf correct not medrite and you were planning on using a sealer to protect correct.
roofner is offline
post #14 of 63 (permalink) Old 02-01-2017, 07:04 AM
Shellac?
Several coats of Bullseye shellac, sanding with fine paper between coats, finish with a buffed out coat of paste wax.
tomp913 is offline
post #15 of 63 (permalink) Old 02-01-2017, 01:16 PM Thread Starter
MT Stringer's Avatar
Yes sir.
MT Stringer is offline
post #16 of 63 (permalink) Old 02-01-2017, 01:36 PM Thread Starter
Just took inventory. I have about 1/2 gallon of the Bulls Eye Shellac, and two partial cans of Deft lacquer.
I think I will save the lacquer for another job.
So Bulls Eye Shellac it is. Maybe today, but most likely, it will be tomorrow.
post #17 of 63 (permalink) Old 02-01-2017, 06:44 PM
roofner's Avatar
First Name: Gary
I found a guy but his machine only has a bed of max 24 by 36 he has to do it in 2 passes . I will end up with 6ft by 2ft but I will leave the panel actual 3ft maybe even 40 inches width and from the off cut make a template to extend holes to full width of the panel. Hopefully the template will be accurate enough.
roofner is offline
post #18 of 63 (permalink) Old 02-03-2017, 06:17 PM
roofner's Avatar
First Name: Gary
Hey mike have you made any cuts with your tracksaw to see how well it works? Maybe I can get rid of my radial arm saw.
roofner is offline
post #19 of 63 (permalink) Old 02-03-2017, 06:28 PM Thread Starter
Not yet. I did lay out a 4 foot drywall square, and it is perfect.
post #20 of 63 (permalink) Old 02-03-2017, 07:12 PM Thread Starter
@roofner
Just for you!
I scrounged up a piece of plywood for a test cut.
It looks like I need to refine my cutting technique. The dowels I used had a little play (not much but just a little). And they could have been longer.
So, with the stuff I had on hand, I made a cut and it is off about 1/16th inch.
Tomorrow is going to be a busy day, so it may be next week before I can check things out.
One thing I noticed is my track has a lip on the outer edge. That may have been the culprit. Or, the holes may be off slightly. I hope not.
Name:	2017-02-03 18.48.59.jpg
Name:	2017-02-03 18.48.23.jpg
Name:	2017-02-03 18.48.38.jpg
Name:	2017-02-03 18.48.42.jpg
Name:	2017-02-03 18.50.26.jpg
tomp913 likes this.
