Work bench pictures for Khal Tom - Router Forums
 25Likes
  • 16 Post By Cherryville Chuck
  • 2 Post By Stick486
  • 2 Post By TwoSkies57
  • 2 Post By DesertRatTom
  • 2 Post By harrysin
  • 1 Post By Cherryville Chuck
post #1 of 10 (permalink) Old 08-22-2017, 03:32 AM Thread Starter
Default Work bench pictures for Khal Tom
I've been communicating with Khal Tom about work bench design and not being able to post pictures in a pm I thought it would be better to start a post about the subject, not that it's the first one on them. Tom is concerned about racking in the design so I took some pictures of my bench which turned out to be rock solid and I'll post them so Tom and others can see. Feel free to join in on this. BTW it only took me an hour to clean it off enough to be able to post pictures.
Photo #1- Shows the stretcher that goes between the two halves of my bench (another photo will show that). It goes between stretchers that are between the legs going crossways on the bench. It also shows where I store most of my small clamps as well as some of my layout tools. There are slotted holders for 2 framing squares, one small framing square, 2 speed squares, a hook rule, and a center finding rule. One of the things you will be doing at the bench is layout so you might as well have those tools handy. Same goes for the clamps.
Photo #2- My bench has an L built into it. This photo shows where the main bench and the L meet. There is an apron on an apron here which solidifies the stability of the main bench. Maybe it was overkill but it worked.
Photo #3- This photo shows the stretcher at the front end of the bench where I mounted my twin screw Veritas vise. This is the Cadillac of vises in my opinion. The stretcher between the front legs and the structure for the vise jaws further solidifies the bench. Also in the picture (under the vise) are some Veritas Wonder Dogs. They allow clamping to just about any shape.
#4- This photo shows the opposite side of the main stretcher. Also with clamp storage for most for my spring clamps and a few smaller C clamps. Also shown is the stretcher across the middle of the bench.
#5- I saw an illustration of a bench before I built mine and it had a trough down the middle and it seemed like a good idea so I incorporated that idea in mine and I've never regretted it. Mine holds sandpaper, dowels wrapped with sandpaper, sanding sponges, pencils and markers, driver bits, utility knives, and my bench dogs. Yes it fills up with sawdust and needs to be cleaned regularly. Also in the picture is my power solution. Others have have used the same solution. I think one of them is Harry. Since I couldn't run a cord under the concrete floor I ran one across the ceiling and left an outlet box hanging over the bench. That turned out not to be enough outlets most of the time so a power bar gets plugged into it.
#6- The last shot is the far end of the bench. Also a wide member there. Also in this photo and the last is that Milwaukee 12" slider. Deadly accurate right from the factory and they say it will be. I started out with a 10" Makita chop saw which left lots of room on the "L". Next was a 10" slider which started encroaching onto the main bench. The 12' definitely encroaches onto the main bench so there maybe a change in the works.
Hope this helps Tom.
Name:	work bench 1.jpg
Name:	work bench 2.jpg
Name:	work bench 3.jpg
Name:	work bench 4.jpg
Name:	work bench 5.jpg
Name:	work bench 6.jpg
post #2 of 10 (permalink) Old 08-22-2017, 03:38 AM
that bench reeks..
of rock solid....
Cherryville Chuck and old55 like this.
post #3 of 10 (permalink) Old 08-22-2017, 07:24 AM
TwoSkies57's Avatar
A work bench that your not afraid to work on!! My kinda bench...
I'm working on a custom Moxon vise for my shop. Want to incorporate it into my workbench.
Problem is the vise is turning out very nice, too nice to take the abuse my work bench typically endures.
I suppose if this is the worst problem I run into this week, I will have had a pretty good week !
Skipper the Penguin
TwoSkies57 is offline
post #4 of 10 (permalink) Old 08-22-2017, 08:10 AM
hawkeye10's Avatar
First Name: Don
Very nice bench and I wish I had one like it. With what I already have I don't have the room. I think the lack of room is most wood workers problem no matter how much room you have.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #5 of 10 (permalink) Old 08-22-2017, 09:30 AM
Wish I had the space for something like that "Rock of Gibralter" bench. I like the way you've festooned it with clamps and need-it-right-now tools. Really handy.
vindaloo and Roy Drake like this.
DesertRatTom is online now
post #6 of 10 (permalink) Old 08-22-2017, 09:33 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Now that is what I call a BENCH Charles.
Harry
harrysin is offline
post #7 of 10 (permalink) Old 08-22-2017, 11:02 AM
Casual conversation overheard at the coffee shop yesterday:
#1..."So I hear you've moved into your new wood shop(?)."
#2..." Yeh; it's much bigger. 6,000sq. ft."
Me...*grinding teeth*
DaninVan is offline
post #8 of 10 (permalink) Old 08-22-2017, 11:11 AM
JFPNCM's Avatar
First Name: Jon
With that collection of clamps and the vise holding it together how can it be anything but rock solid?
Jon
JFPNCM is online now
post #9 of 10 (permalink) Old 08-22-2017, 01:46 PM Thread Starter
Even at 6000 sq ft I'm sure the rule that you will eventually overfill it still applies.
DaninVan likes this.
post #10 of 10 (permalink) Old 08-22-2017, 03:06 PM
That's exactly what the guy with the new shop said.
DaninVan is offline
My Ideal Work Bench pmspirito Show N' Tell 35 10-21-2011 09:28 PM
building a work bench reikimaster Tools and Woodworking 12 10-13-2006 11:12 AM
acorn work bench reds_21 Tools and Woodworking 6 02-14-2005 12:56 PM
Bench sized powertools JTsteelblu Tools and Woodworking 3 10-13-2004 01:31 PM
