Frame for a lithophane - Router Forums
 20Likes
post #1 of 11 (permalink) Old 11-20-2017, 01:58 PM Thread Starter
Gaffboat's Avatar
First Name: Oliver
Default Frame for a lithophane
I got the style of this frame from a recent Kreg newsletter. I didn’t construct mine the same way (mine’s smaller and doesn’t use pocket screws) but the look is basically the same. It is made out cypress and stained with mahogany gel stain.
The 5” x 7” light panel came from Evergraphs. The owner is an accomplished lithophane artist in her own right and provides exceptional customer service. She also has some nifty little attachments for making lithophane night lights which are on my Christmas To Do list.
This lithophane was cut out of 1/4” Corian. If you have a cnc and haven’t tried a lithophane yet, you should. I used Vectric’s PhotoVCarve to create the cutting files.
Name:	1 Frame Final.png
Name:	2 Lithophane.jpg
Name:	3 Litho Frame front.jpg
Name:	4 Litho Frame side.jpg
kp91, fire65, TwoSkies57 and 13 others like this.
Gaffboat is offline
post #2 of 11 (permalink) Old 11-20-2017, 02:40 PM
excellent Oliver...
post #3 of 11 (permalink) Old 11-20-2017, 02:46 PM
Semipro's Avatar
First Name: John_*
+1 on the excellent Oliver
Semipro is online now
post #4 of 11 (permalink) Old 11-20-2017, 02:55 PM
How difficult is PhotoVcarve to work with??
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is online now
post #5 of 11 (permalink) Old 11-20-2017, 04:12 PM Thread Starter
Gaffboat's Avatar
First Name: Oliver
Default Working with PhotoVCarve
Originally Posted by honesttjohn View Post
+2
PhotoVCarve is a pretty simple 4 step process. First you import your photo. In step 2 you set the material size you want, the XY origin, material thickness, and units (mm or inches). Step 3 sets the cutting parameters: bit, max depth of cut, line spacing, line angle, gives you the option to invert light / dark areas (for lithophanes) and calculate which gives you a preview. In the final Step 4 you can preview in various materials, see estimated machining time and save your tool paths.
The tool paths are then imported as vectors into VCarve, VCarve Pro, or Aspire so you can position them on larger pieces of material. I found some great guidelines for lithophane production on Vectic's Forum that I used for my carving. I'll be happy to send them to you.
MT Stringer and honesttjohn like this.
Gaffboat is offline
post #6 of 11 (permalink) Old 11-20-2017, 06:42 PM
First Name: Richard
Shop guy is offline
post #7 of 11 (permalink) Old 11-20-2017, 07:25 PM
I should be able to find them ......... maybe.
Thanx
HJ
Detroit Burbs
post #8 of 11 (permalink) Old 11-20-2017, 07:51 PM
hawkeye10's Avatar
First Name: Don
Oliver you guys with the CNC machines are coming up with more and more ways of turning out some excellent work.
MT Stringer likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #9 of 11 (permalink) Old 11-20-2017, 09:31 PM
old55's Avatar
First Name: Ross
What they all said Oliver.
Ross,
old55 is offline
post #10 of 11 (permalink) Old 11-24-2017, 09:18 AM
TenGees's Avatar
First Name: Paul
Very nice, looks like a hologram. The frame has clean and simple but effective lines.
Gaffboat likes this.
TenGees is online now
Picture frame kywoodchopper Project Plans and How To 4 11-06-2016 03:43 PM
Picture frame kywoodchopper Project Plans and How To 8 11-06-2016 09:54 AM
Finally, first frame finished! DesertRatTom General Routing 19 06-07-2016 04:46 AM
Fabric Art with Arts & Craft Walnut Frame TRN_Diesel Show N' Tell 15 07-28-2014 08:55 PM
How to Make a Decorative Picture Frame Using a Router learnexperience Tools and Woodworking 1 08-02-2011 11:47 PM
