A Simple Ramp - Router Forums
 25Likes
post #1 of 15 (permalink) Old 11-20-2017, 09:51 PM Thread Starter
MT Stringer's Avatar
Default A Simple Ramp
I needed to make a ramp for mom's house so it would be easier to transition a step up from the sunken den into the main part of the house.
As it turned out, it was an afternoon project. I used a couple of 2x6 cutoffs I already had and a piece of 1/2 inch plywood. It is sturdy and assembled with glue and screws and a few 16 ga nails.
If I measured correctly, it should fit. I will find out in the morning when I take it to her house.
Negotiating the step up/down with a wheel chair should be a lot easier now.
Name:	2017-11-20 20.15.29.jpg
Name:	2017-11-20 20.15.37.jpg
Name:	2017-11-20 17.37.05.jpg
Name:	2017-11-20 20.16.02.jpg
Name:	Ramp Transition.jpg
Name:	New Ramp01.jpg
MT Stringer is online now
post #2 of 15 (permalink) Old 11-20-2017, 09:58 PM
Well done, your mom will thank you.
MT Stringer likes this.
<Chas>
I'll burn that bridge when I come to it
CharlesWebster is offline
post #3 of 15 (permalink) Old 11-20-2017, 10:39 PM
hawkeye10's Avatar
First Name: Don
She will like that. It does look sturdy. Will you be able to fasten it down where it will not slide?
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #4 of 15 (permalink) Old 11-20-2017, 11:20 PM
jj777746's Avatar
Another,professional job & nice gentle slope also.
You can't drive a bridge spike with a tack hammer(so I'm told)
jj777746 is offline
post #5 of 15 (permalink) Old 11-21-2017, 01:56 AM
Pounamu's Avatar
Country: New Zealand
First Name: Keith
Send a message via AIM to Pounamu Send a message via Skype™ to Pounamu
Well thought out. Looks strong, too.
If eating carrots improves the eyesight, how come there are so many dead rabbits on the roads?
Pounamu is offline
post #6 of 15 (permalink) Old 11-21-2017, 06:15 AM
Contributor of the Month
Looks good. I had to make a couple for my wife's mother. One is a small one like yours to be able to get her wheel chair down a short step. The other is 12 feet long that we use to push her wheel chair into our house which has a couple of steps and a 24 inch rise. I used 3/4" plywood and ripped a 2 X 4 with a matching angle at the bottom edge so that it 'dies' into the floor and there is no hump. I didn't have Sketch-Up at the time. I bought a book but have not taken the time to learn enough to be proficient.
JIMMIEM is offline
post #7 of 15 (permalink) Old 11-21-2017, 06:31 AM
difalkner's Avatar
First Name: David
Looks great, Mike! Are you going to paint it? If you do then you can sprinkle a little sand on top while the paint is still wet and have a non-slip surface.
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #8 of 15 (permalink) Old 11-21-2017, 09:54 AM Thread Starter
Yay! It fits.
It is a temporary solution. My sister says it can be moved out of the way when it isn't needed so no permanent installation. I have walked on it several times and it appears to be sturdy enough.
I cut the angles using the band saw. They turned out nice. I didn't know I had it in me!
I didn't paint it because there was an immediate need for it so I worked on it yesterday afternoon/night. Didn't stop until it was sitting in the back of my truck ready for delivery this morning.
Twenty one dollars later, it is in place. I'm happy...brother and sis are happy too. We will be able to move mom around a lot better now.
Name:	2017-11-21 08.24.55.jpg
difalkner, TenGees and Herb Stoops like this.
post #9 of 15 (permalink) Old 11-21-2017, 10:28 AM
I wonder if there's some sort of trim to attach that would smooth out the edge? It probably doesn't need it, but you could simply drill two holes through the ledge and into the ramp, drop a short length of steel rod, and it would keep it from slipping and not be obvious.
DesertRatTom is online now
post #10 of 15 (permalink) Old 11-21-2017, 10:33 AM Thread Starter
Thanks for the suggestion, Tom. Since the wheels on the chair are big, I don't think it will be a problem. I will test it later this morning.
Boat Ramp Antics! MT Stringer Lobby 10 03-29-2017 06:21 AM
Simple solutions are always the best answer Gaffboat Jigs and Fixtures 16 10-29-2016 11:51 PM
Cutting a thin wedge for a ramp. Ed Bray Tools and Woodworking 12 06-06-2014 08:45 AM
A Beginner's Simple Finish Jerry Bowen The Finishing Touch 4 07-15-2012 10:11 PM
Keep It Simple ??? Drugstore Cowboy Lobby 5 07-31-2007 10:01 AM
