wood and metal box - Router Forums
 25Likes
post #1 of 11 (permalink) Old 11-22-2017, 12:53 AM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Default wood and metal box
I'm starting to like the idea of combining wood and metal in my box making, so starting off very slow, I added some brass strips to the joints on this one.
This is as complicated as I can make at the moment. I used a birdsmouth cutter for the joints. The top and bottom are in dado slots, all done on the router table, and most panels are thicknessed on my router sled.
The box is made of Teak front and back, Walnut ends, and Bubinga top, bottom, and corners, with the legs edged with Sycamore.
i must admit the brass in the slits was an afterthought, and its not immediately obvious but i like the idea enough to have ordered some brass banding for future boxes.
I have a treasure chest in the pipeline and that will have a lot of brass on it.
This box is 13" x 6" x 4" high. I still have to find a latch for the front.
kp91, CharleyL, JFPNCM and 19 others like this.
sunnybob is offline
post #2 of 11 (permalink) Old 11-22-2017, 06:56 AM
difalkner's Avatar
First Name: David
Very nice work, Bob! What finish did you use?
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is offline
post #3 of 11 (permalink) Old 11-22-2017, 07:24 AM
CharleyL's Avatar
First Name: Charley
Very nice looking box. What did you use to glue the wood to the metal?
Charley
Central North Carolina
CharleyL is online now
post #4 of 11 (permalink) Old 11-22-2017, 07:30 AM
hawkeye10's Avatar
First Name: Don
Bob people will like that. Do you know why? Because I like it.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #5 of 11 (permalink) Old 11-22-2017, 07:56 AM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Used my usual home mixed wipe on poly.
But I'm starting to have problems sourcing oil based poly, many of our shops have gone "green" and stock water based now.
The brass is 12 mm x 1 mm cut from a sheet. Its a tight slot fit into the wood, but I roughed the surface on a grind wheel first and then ran CA (superglue) into the slot. And of course theres several coats of varnish been rubbed into the joints. It shines when the box is in a certain light. A bit understated and not immediately noticed, but I get nice comments when people do see it.
It should hold, but hey, its a prototype. i might use a 2 part epoxy next time.
I normally just make what ever shape box I want to and then see if anybody wants to buy it, but luckily this box has been claimed by a good friend, so if it comes apart she will just tell me.
And today someone else visited and has put in an order for the "same again please" (lol)
CabinCreek likes this.
sunnybob is offline
post #6 of 11 (permalink) Old 11-22-2017, 09:53 AM
Garyk's Avatar
First Name: Gary
Dressed it up just fine. Nice
Garyk is offline
post #7 of 11 (permalink) Old 11-22-2017, 11:55 AM
Very nice. Smart having a trial version in a friend's hands.
papasombre and jj777746 like this.
post #8 of 11 (permalink) Old 11-22-2017, 07:57 PM
JFPNCM's Avatar
First Name: Jon
Excellent work as always.
Jon
JFPNCM is online now
post #9 of 11 (permalink) Old 11-24-2017, 01:07 PM
CharleyL's Avatar
First Name: Charley
It's beautiful work, but I was concerned about the wood end grain to metal joints. It's much like a cross grain situation where the end grain expands in width, but the smooth metal doesn't change in size much at all. I was kind of hoping that you had found an even better solution than the epoxy that I have used when gluing wood to metal.
I hope it holds up well. If it's kept in a relatively stable temperature and humidity controlled environment, It shouldn't have any problems. Crazy glue is strong, but very brittle. Epoxy is strong and flexible.
Charley
post #10 of 11 (permalink) Old 11-24-2017, 05:41 PM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
yeah, it was a flight of fancy, time will tell.
sunnybob is offline
cnc wood frames with metal plasma art inserts woodman12 CNC Routing 2 09-24-2014 11:57 PM
A Wood Experience-Contest Woodworkers Source Contests Archive 2 05-14-2009 05:58 PM
Wood to metal bond S Bolton Jigs and Fixtures 15 01-18-2009 12:48 AM
