Sometimes the old-school ways simplify a cnc project - Router Forums
 20Likes
  • 12 Post By Gaffboat
  • 3 Post By difalkner
  • 3 Post By Cherryville Chuck
  • 1 Post By RainMan 2.0
  • 1 Post By Roy Drake
post #1 of 7 (permalink) Old 12-09-2017, 09:53 AM Thread Starter
Gaffboat's Avatar
First Name: Oliver
Default Sometimes the old-school ways simplify a cnc project
I made a business card holder using a left over bit of 2 x 8 cedar for the card holder. I spent a lot of time on the pc in V Carve Pro trying to figure out how to create a tool path that would cut a curved dip in the front of the holder. Perhaps it could be easily done with Aspire but I wasn’t having any joy using V Carve Pro.
As I futzed around it suddenly dawned on me that I could do it easily if I treated it like a bandsaw box project. So, I simplified my V Carve file to only pocket out the card holding area and mark a cutting line for the shape. The pocket was carved with a 1/4” spiral bit and the outline of the shape with a 45ļ V bit.
After the cnc work I went to the bandsaw and cut out the shape by following the scribed line and then sliced off the front of the holder so I could cut the curved area. After cutting and sanding the curve I glued the slice back in place. Then I made another V Carve file for the backdrop panel which was carved out of a left over piece of cedar fence board.
A quick little project that let me use my bandsaw and spindle sander in addition to the cnc. Obviously a cnc machine is just another tool in the creative process.
Name:	1 CNC Work.jpg
Name:	2 Shape Bandsawed.jpg
Name:	3 Front slice.jpg
Name:	4 Final.jpg
Gaffboat is offline
post #2 of 7 (permalink) Old 12-09-2017, 10:03 AM
First Name: Jerry
Originally Posted by Gaffboat View Post
I made a business card holder using a left over bit of 2 x 8 cedar for the card holder. I spent a lot of time on the pc in V Carve Pro trying to figure out how to create a tool path that would cut a curved dip in the front of the holder. Perhaps it could be easily done with Aspire but I wasnít having any joy using V Carve Pro.
As I futzed around it suddenly dawned on me that I could do it easily if I treated it like a bandsaw box project. So, I simplified my V Carve file to only pocket out the card holding area and mark a cutting line for the shape. The pocket was carved with a 1/4Ē spiral bit and the outline of the shape with a 45ļ V bit.
After the cnc work I went to the bandsaw and cut out the shape by following the scribed line and then sliced off the front of the holder so I cut could cut the curved area. After cutting and sanding the curve I glued the slice back in place. Then I made another V Carve file for the backdrop panel which was carved out of a left over piece of cedar fence board.
Absolutely fascinating to me.
Jerry
Jerry Bowen is offline
post #3 of 7 (permalink) Old 12-09-2017, 10:41 AM
difalkner's Avatar
First Name: David
That looks great, Oliver! Simple yet very effective, and as usual, well carried out.
Btw, 5 minutes in Fusion 360 got me to this, no fine tuning, obviously -
Sometimes the old-school ways simplify a cnc project-business-card-holder.jpg
Sometimes the old-school ways simplify a cnc project-business-card-holder-toolpath.jpg
Sometimes the old-school ways simplify a cnc project-business-card-holder-finished-part.jpg
But you can do things in V-Carve Pro that I would only, uh, Aspire to do... LOL!
David
kp91, Gaffboat and TenGees like this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #4 of 7 (permalink) Old 12-09-2017, 10:58 AM
I keep thinking back to what David said a little while back. "It's just another tool in the arsenal." If it's the best tool to use then use it. If something else will work better then use that one.
difalkner, Gaffboat and Roy Drake like this.
post #5 of 7 (permalink) Old 12-09-2017, 11:21 AM
RainMan 2.0's Avatar
I love your business cards too Oliver , pretty unique
Roy Drake likes this.
Ok ,I never insulate
RainMan 2.0 is offline
post #6 of 7 (permalink) Old 12-10-2017, 09:27 PM
First Name: Roy
Where there's a will...
RainMan 2.0 likes this.
Roy Drake is offline
post #7 of 7 (permalink) Old 12-13-2017, 12:11 AM
TenGees's Avatar
First Name: Paul
Nice solution, Oliver.
I was wondering if you could CNC cut that last curve by mounting the part the other way. I guess you'd need a second drawing/tool path.
TenGees is offline
