Big Mistake - Solutions Sought . . . - Router Forums
 34Likes
post #1 of 38 (permalink) Old 01-20-2018, 11:27 AM Thread Starter
DonkeyHody's Avatar
First Name: Andy
Default Big Mistake - Solutions Sought . . .
Well, you know what they say about the best laid plans . . .
I built the trestle lathe stand according to the design I posted earlier - incorporating suggestions from you folks. The top beam is 7" Wide X 5 1/4" Height. The legs are 7" X 3 1/4". I was certain I would never need to take it apart, so every joint is glued. Through mortise/tenons where the legs join the top rail and the feet. Even the stretchers across the legs are glued in place and backed up with lag bolts. The thing is massive and strong. It was all going so well until I put the lathe on top of it.
It's 5 inches too high. It seems that when I measured the spindle height on my lathe, I measured to the bed instead of to the surface of the stand. Anyway, now the thing is built and it needs to get 5 inches shorter. When I make a mistake like that, I've learned not to try to fix it immediately. The best solutions usually come after some gestation period in my subconscious.
The best plan I have come up with so far is to cut 5 inches out of the middle of the legs. Then I'll glue a scab on all 4 sides of each leg in such a way as to wrap the entire leg with a "cast", making the fix practically invisible.
However, recognizing the collective wisdom of the group, I'm asking if anyone has a better idea.
DonkeyHody is offline
post #2 of 38 (permalink) Old 01-20-2018, 11:49 AM
Other than building a 5" high platform to stand on then I have to agree with your plan.
kp91, harrysin, DaninVan and 2 others like this.
post #3 of 38 (permalink) Old 01-20-2018, 12:50 PM
hawkeye10's Avatar
First Name: Don
You could remove the wheels.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #4 of 38 (permalink) Old 01-20-2018, 01:38 PM
mimac's Avatar
First Name: Brian
Remove the lag screws on the legs at the base then saw down the glue joint keeping to the leg side as you're cutting 5" off anyway.
mimac is online now
post #5 of 38 (permalink) Old 01-20-2018, 02:02 PM
Just thinkin' outside the box here...
DaninVan is offline
post #6 of 38 (permalink) Old 01-20-2018, 02:54 PM
difalkner's Avatar
First Name: David
Along the lines of what Brian said I would cut the uprights at the line below. Take the bolts out, knock the 2x6's off (yes it will splinter) then cut the uprights. Get another 2x6 if those splinter badly (you can still use them for other projects later) and put it all back together.
Fwiw, an older woodworker told me years ago never to glue anything that you think you'll never need to take apart. It always has to come apart for some reason down the road.
Name:  Lathe stand.JPG
David
Gene Howe, Shop guy and Oakwerks like this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #7 of 38 (permalink) Old 01-20-2018, 03:22 PM
Andy, I like your plan. But instead of making the fix permanent, make it a height adjustment. Drill a hole through the leg and put a long bolt through. Then you drill holes every 1 1/2" so you can raise the lathe up or down to suit the user or operation. You could even cut off more than the 5" to get a lower height if you so desired in the future.
Just saying,
Herb Stoops is offline
post #8 of 38 (permalink) Old 01-20-2018, 03:22 PM Thread Starter
DonkeyHody's Avatar
First Name: Andy
Or just let the air out of the tires.
post #9 of 38 (permalink) Old 01-20-2018, 03:24 PM Thread Starter
DonkeyHody's Avatar
First Name: Andy
Another idea . . . .
Since the legs are 3 1/4 thick X 7" wide, I have plenty of room for several BIG dowels. I could just have a doweled butt joint just above the stretchers. Think that would work??
post #10 of 38 (permalink) Old 01-20-2018, 03:27 PM
I have a dumb question, What is that pipe across the front between the standards?
harrysin and Shop guy like this.
Fixing A Mistake Jerry Bowen Show N' Tell 20 04-26-2015 12:57 PM
Your wisdom is sought gcodom Table-mounted Routing 8 12-10-2010 07:03 AM
Solutions...what solutions? brucio Wood Scrolling 1 10-19-2007 03:22 PM
