drill press depth stop - Router Forums
 38Likes
post #1 of 18 (permalink) Old 01-25-2018, 03:57 AM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Default drill press depth stop
middle of last year I bought a bench top drill press. nothing too expensive, but it was time.
Then i realised that the depth stop rubbish. It was a one piece plastic unit incorporating a face shield, but any downward force on the handle meant that the stop bowed and dropped almost a 1/4" below what it was supposed to.
So i made a steel replacement.
Didnt want the plastic guard as its only me and I wear goggles if i'm drilling wood anyway.
trying to take the original off it snapped in half (picture 5)
I dipped the finished item in red hammerite to match the press.
Now its stronger than the rest of the press.
sunnybob is online now
post #2 of 18 (permalink) Old 01-25-2018, 07:00 AM
N'awlins77's Avatar
First Name: Lee
Nice! Can't believe they would make that out of plastic!!
N'awlins77 is offline
post #3 of 18 (permalink) Old 01-25-2018, 07:17 AM
Knothead47's Avatar
It's cheaper to mold a zillion plastic parts than make one out of metal. Example- I have an old Craftsman sander that has a zinc die cast body. I have a new belt sander that has a plastic body.
Herb Stoops likes this.
John T.
Knothead47 is offline
post #4 of 18 (permalink) Old 01-25-2018, 07:25 AM
Country: France
First Name: Gérard
bad plastic sh.t
How much did you pay that?
I'd like to see a pict from the right side of this drill, it's usually
on the right side that they got a rotative depth scale , with a stop function.
Regards.
Gérard
ggom is offline
post #5 of 18 (permalink) Old 01-25-2018, 08:34 AM
Country: France
First Name: Gérard
Ok!
Sorry, went to see some at harbor freight, those drills just got nothing on the right side .
I had never seen a drill press made like that. Ours always have a rotary dial on the right side
same axis as the rotary levers , and this carries a screw for depth- stop.
This allows for about 0.5mm repeatability depth - stop
Regards.
Gérard
Name:	Drill press dial and stop.JPG
ggom is offline
post #6 of 18 (permalink) Old 01-25-2018, 08:36 AM
hawkeye10's Avatar
First Name: Don
Bob you must have a machine shop or have acess to one. It looks like it was made with a CNC. Great work on your part. I also made one but I made it out of white oak. It doesn't look to good but it works.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #7 of 18 (permalink) Old 01-25-2018, 09:46 AM
John; to be fair a lot of the plastic casing used on modern tools is part of the 'double insulated' design function. Absolutely necessary in order to keep the operator isolated from the electrical components.
And honestly, it does make the tools lighter (in weight).
MT Stringer likes this.
DaninVan is online now
post #8 of 18 (permalink) Old 01-25-2018, 10:14 AM
This seems to be another case of tool designers and engineers who don't use the power tools they design. Nice build.
DesertRatTom is online now
post #9 of 18 (permalink) Old 01-25-2018, 10:20 AM
The depth stop should be standard equipment. I'm drilling cup holes for Euro style hinges right now in 5/8 melamine and a depth stop is an absolute necessity.There is so little material left below the cup before blowing out the other side that it leaves no room for error. Mine is a Delta floor model but the quill, depth stop, and pointer are so much like Gerard's that I'm betting they were made in the same factory under different names.
post #10 of 18 (permalink) Old 01-25-2018, 11:57 AM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
The press was a cheap one. i knew that and was prepared (or so I thought) for it to be less than perfect.
Turned out to be considerably less. I had to do a lot of work to make it even function.
The NVR switch was wired backwards, the motor adjusting tension knob thread was stripped out. The bolts for fixing the column to the base were the wrong size. All of those should not have been there, but i fixed the problems quite easily, but the depth stop was just unusable.
Don, no machine shop. All hand cut and filed apart from the main hole which i cut on the drill press using a hole cutter.
i always enjoyed making stuff with metal.
Benchtop Drill Press Modification JimS Tools and Woodworking 23 07-19-2018 12:51 PM
How to Drill a Hole without using a Drill Press MT Stringer Jigs and Fixtures 4 04-20-2017 01:24 AM
Delta 11-990 drill press older model question braunthrax Tools and Woodworking 11 05-19-2012 02:22 AM
Craftsman Drill Press - 3/4 hp 17'' Drill Press (22901) ARCJR Tools and Woodworking 10 04-11-2012 11:50 AM
Had my drill press going Glenmore Tools and Woodworking 2 08-20-2005 09:07 PM
