Side table with Granite Top - Page 2 - Router Forums
 21Likes
post #11 of 14 (permalink) Old 02-24-2018, 10:14 AM Thread Starter
First Name: Ravin
Originally Posted by DonkeyHody View Post
That's very well done! Are you cutting the granite too, or sending it out? If you're cutting it, HOW?
Yes I'm doing the granite fabrication as well. Circular saw outfitted with a diamond blade to section the slabs. Then angle grinder outfitted with a diamond blade to cut close to the circular line. Wood template to grind up to the circle using a z-wheel. Minor adjustments with a metal bond copper pad. Then route the upper and lower edge profile with a diamond profile bit pn my variable speed angle grinder. Just like wood working you can route a profile of your choice including bullnose, ogee etc. Then polish the edges using 9 step resin wet pads.
All of my stoneworking tools are outfitted with a water feed for wet working.
Anchoring to the wood base was done by drilling some holes in the stone, sinking machine screws into the stone, filling the holes with stone epoxy for bonding and then passing the screws through the stretchers and securing with nuts.
blue_can is offline
post #12 of 14 (permalink) Old 02-24-2018, 04:22 PM
Looks rock solid!!
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is online now
post #13 of 14 (permalink) Old 02-24-2018, 04:36 PM
RainMan 2.0's Avatar
I just took a better look at the construction. Very impressive work if you ask me . Id love to be able to do that someday, but for now Ill leave it to the experts
I don't know anything about CNC router tables , but I stayed at a Holiday Inn Express last night .
Plus I know Ger21
RainMan 2.0 is online now
post #14 of 14 (permalink) Old 02-25-2018, 08:22 PM Thread Starter
First Name: Ravin
I would not class myself as an expert at all - I have not done much woodworking - 2 or 3 items of furniture, hardwood floors etc. I'm sure you would have no problem doing something like this.
btw for those who may have seen my other thread asking about a plunge router and commented on the fact that they found the 3+ hp routers heavy - just to put things into perspective something like a Ghines router for stone weighs about 70lbs.
blue_can is offline
Track saw, should order one now? Everend Tools and Woodworking 45 06-19-2017 05:00 AM
Incra Left side router table top BowlBit General Routing 3 03-02-2017 10:51 AM
Table top display cse. derek willis Show N' Tell 16 04-13-2014 06:31 AM
Table Top (??) C-Russ Table-mounted Routing 9 02-04-2014 04:30 PM
Sold: Router Table or Table Top -Sam- Woodworking Classifieds 10 01-29-2005 09:15 PM
